Experienced Deck Builders?
/ Experienced Deck Builders? #101
What are you referring to as a screw with no threads on it? I like the screws without threads on the last inch. They pull 2 boards tight together where the screws with threads in the whole length are more problematic.
Sounds like you have a good plan.
When you buy screws, be sure to NOT get the new style that doesn't have any threads on them. Look close to the picture in the link and you will see all sorts of extra garbage added to the screw that they claim will help them screw get through the wood, but what it actually does is remove materiel so the screw threads don't have anything to hold on to. Easily half of every one of these things will strip out on you.
https://www.homedepot.com/p/Deck-Ma...ad-Wood-Deck-Screws-1-lb-Pack-DM3G1/300884054
No matter how far you have to drive, be sure to get screws with the traditional, normal looking threads. Star drive are the easiest to install, but whatever you do, just make sure not to get those new style screws. They are the worse design ever thought up!!!!
Thanks for the heads-up. I haven't screw shopped for a while, so I'm not familiar with these. Doesn't seem like a great idea....maybe for the volume builders that want to get in/out of jobs faster. I will steer clear of these for sure.
/ Experienced Deck Builders? #103
Appreciate all the information, but I'll be sticking with pressure treated for this project. It's the best "value" for what I'm doing. As mentioned earlier, the PT deck on the back of my house is 25 years old, still solid & looks great. I don't mind a little maintenance every couple years.
Bravo!
As I suggested earlier, staple some strips over the joists B4 you deck it.
In that way water that works its way between the decking wont rot the joists, in fact wider gaps even aid the drying process.
The easiest is self adhesive membrane strips but many other products that shed water will suffice.
I have even used black poly usually sold for window and door openings (cut to 3-4" widths).
My own porch deck is poly strip protected and it is 22 years old. Mind U I have good air circulation which helps.
(And at 22 years I have not had to change one board to date, mind U maybe next year a few)
/ Experienced Deck Builders? #104
The screw photo in the link has left hand threads. ???
Bruce
/ Experienced Deck Builders? #105
Bruce
They have right-hand threads for most of their length then at the top 1/2" of LH threads and 1" of no thread. The idea is that if you are putting them into 2x lumber when the head of the screw touches the top board the LH threads will be right where the top board joins the bottom board and the threads in opposite directions will draw the two boards tight together. As Eddie points out by the time this happens both the LH and the RH thread will have gone through the top board, making the hole bigger.
/ Experienced Deck Builders? #106
Looks all LH to me, but two different pitches.
Bruce
/ Experienced Deck Builders? #107
I wonder if someone reversed the photo. I can't imagine it actually has left hand threads.
/ Experienced Deck Builders? #108
Fasteners:
[video]https://www.nachi.org/home-inspectors-evaluating-problems-with-fasteners.htm[/video]
/ Experienced Deck Builders? #109
Bruce
I made the mistake of buying a big box of these things one time and it's taken me years to find something to do with them. After the first dozen or so, I realized how horrible they are and gave up on using them. It cost me half a day of being productive to drive to Lowes to get some good, old fashioned, deck screws and use them instead of these horrible things.
The picture is a mirror image of what they look like. No idea why, but the threads are all right hand. There just isn't very much thread on them as you can see in the picture, and in between the threads, there are little bits of metal that remove even more wood so what little threads there are, have less to hold onto. It's kind of like drilling a pilot hole that is too big, and there isn't anything left to bite into.
Avoid these things at all costs, regardless of how far out of your way that you have to drive to get good screws. Home Depot has gone all in on these things and there really isn't any decent alternative in my store to buy instead if you are working on an exterior project. They do have some decent interior screws to use instead, just nothing for outdoor stuff.
/ Experienced Deck Builders? #111
Those screws are made for composite decking.
Quote from the link provided. "Make the most of your of your outdoor project with Deckmate brand exterior screws. Designed for use with all treated lumber and all exterior projects to connect wood to wood. A lifetime polymer coating provides extra corrosion resistance that is guaranteed for the life of your outdoor project."
/ Experienced Deck Builders? #112
Don't go cheap with screws. Stainless is the only option. I made the mistake of using those ceramic coated screws on my entryway. It was around 2012, two years before I built my Tigerwood main deck. The summer after (3 years after building it) I removed the deck so I could make it larger and with Tigerwood decking. Since I wasn't too worried about longevity I used a combination of stainless and "new" decking screws. The stainless just needed to have the dirt removed from the head while every one of the ceramic screws were rusted. Most rusted to the point where they were about half the diameter they started off at and broke. With stainless you just need to understand that you can't overdrive them (or they will snap) and you must have a good bit to drive them in or you will strip the head.
Can't do much but plan the project right now....all this crappy wet/snowy weather.....
Getting my tool list together, I did realize I was in need of a new 48" level, as my old 2 footer somehow sprung a leak, and was probably too small anyway. (good excuse to buy a tool...)
So, after doing some level research, settled in on an Empire e55. Still made in USA, lifetime guarantee, and affordable (~$30). Haven't used it yet, but happy with the quality & feel of it.
Hope to start rounding up materials soon!
Empire Level - Built On trust
/ Experienced Deck Builders? #114
Dalola,
When shopping for a level I would prefer to buy in a brick and mortar store. You want a level that is dead on. In the store you can check for accuracy. Some levels in the rack are not perfect.
To check; Find a flat spot that appears to be level, and take a reading. Then turn the level 180 degrees and place it in the Exact same spot. If the bubble is not in the exact spot in the vial, the level is not true. You are not checking the bubble, you are checking the marks on the vial.
/ Experienced Deck Builders? #115
This is what I do when buying a new level. It's kind of shocking how many of them wont give you the same reading when you flip them around 180 degrees.
My favorite levels are Bostitch that I bought at Home Depot. But for some unknown reason, they are no longer sold there.
One of my most frustrating things with stores is when they have a really good brand, and then they get rid of it and start stocking a junk brand.
Dalola,
Yep, bought it at Home Cheapo. First one I grabbed was spot-on. Did find out their storage rack upright wasn't plum.... ;)
/ Experienced Deck Builders? #117
I see that all the time at Lowes and HD. It's especially frustrating with some building materials -- if you want to match up something, install another of something a few years later, replace a part, or add an option to what you already bought, it's a gamble whether they'll still carry that brand or item anymore. Been burnt by that so many times I stopped having any expectation of future continuity with those purchases.
I remember years ago putting in a storm door from Lowes. Within a year or so I needed to replace the lockset that broke. Well it was a custom lockset very specific to that storm door and they no longer carried the brand, nor could I find it anywhere else. I told my wife I'd replace it with a rope rather than get a whole new door. I ended up rigging up a fix that sort of worked, but was annoyed I couldn't get a new part. I've had that happen with other stuff too, including plumbing and lighting. They just don't stick with the same suppliers for very long.
/ Experienced Deck Builders? #118
Same here with a Lockset... finally tracked it down and made in China... $120 plus shipping.
Also, did a patio cover for my Grandmother and a few years later there were 100 mph gusts that damage two of the panels... have not been about to buy replacements... no longer carried.
Tracked down the manufacture and I would need to buy a case and have trucked shipped... it was cheaper to buy all new.
/ Experienced Deck Builders? #119
Stuff like that irks me bad. But I guess places are accommodating our throw away society.
I CAN'T STAND owning something you can't get parts for. I try to always buy common things.
I repainted our storm door and was able to adapt a new lockset from lowes using a die grinder and a carbide burr.
Ha, just realized I never updated this old thread, once I finally did get around to building the deck!
Very happy with the result, got it knocked out in a day....and it's even level! Nice small deck to watch the sun set over the next ridge. Will stain & seal once the wood dries out, latter this summer.
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
CASE TV380 (A67714)
CASE TV380 (A67714)
2023 Kubota KX057-5 Midi Excavator (A66734)
2023 Kubota...
2017 Ford F-450 XL (A64911)
2017 Ford F-450 XL...
1996 INTERNATIONAL (INOPERABLE) 4700 (A67714)
1996 INTERNATIONAL...
2005 Bobcat B950 Hydraulic Breaker Skid Steer Attachment (A66734)
2005 Bobcat B950...
