Anyone Own A L6060?
/ Anyone Own A L6060? #21
As mentioned, ROPS models have a toolbox.
Extremely slow lifting of the FEL is due to misadjustment of three point mechanism. Been fighting this off and on for nearly three years now. Do you have draft control?
SDT
Mine is a cab model. Kubota does not offer any toolbox for the cab models.
I do not have draft control. Do you have draft control? Is that part of the problem?
/ Anyone Own A L6060? #22
Light compared to what though? Weight-wise they're in line with LS and others. If you're really having a problem with rear traction that sounds like something that a little ballast off the 3pt could solve.
Maybe my frame of reference is all wrong coming from a 2.5-3k lb tractor to the L4760 but I have zero traction problems. I can run around w/ 600lb round bales out front with nothing on the 3pt all day. With our snow storm this month I was pushing 20" x 6' x 15-20' of snow out of driveways without issues.
I've been chipping away at the giant dirt pile left behind out house from excavation and I can run at full throttle into that pile and the tractor will stall out(w/ stall guard off) before I spin the wheels in M + HDS-L. No problems getting a full load of dirt in the HD bucket.
I'll be the first to admit that I'm no expert but that doesn't line up with my experience on the L4760 at least.
Light as compared to other 50+ HP farm tractors, e.g., MF, NH, etc.
Not complaining, just stating the obvious.
I have a large Kubota ballast box for use with mine as well as two cast iron weights on each side, but it's a CUT and is not designed for pulling.
My 2WD 1955 Ford 860 will pull my 6060 into the next county. Admittedly, the Ford is fully weighted and has R1 tires whereas the 6060 has R4s, which will not pull the hat off of ones head, but the Ford is designed for plowing, whereas the 6060 is not.
SDT
/ Anyone Own A L6060? #23
Yes, and FEL problem showed up after the draft control was added.
Tinkering with the three point feedback linkage (not part of the draft control system) can make the problem go away but it comes back.
Tech has told me that he has seen this issue on similar tractors without draft control.
SDT
/ Anyone Own A L6060? #24
On my cab L4060 I just use a canvas tool bag behind the seat.
With filled R4’s I don’t notice any issues with rear weight. With fel frame and front / rear plows, I weigh in right at 7k for snow duty.
(6300 lbs with just the bucket).
I think the 6060 weighs like 300 lbs more than a 4060. For my use weight was more a factor than hp.
One thing that has come to mind is that the alternator doesn’t put out any amps at anything lower than about 1200 engine rpms. When I’m operating at night it would become painfully obvious at idle. I set the hand throttle to 1500 rpms or so, then use the Auto Throttle Advance to tie the hst pedal to the throttle.
“$50,000 tractor and no tool box??? Hard to believe.”
Well, A lot of new automobiles have no spare tire or jack....one is supposed to have AAA so the dealerships tell us. Next time you are out in the field and need a spare Lynch pin just phone AAA and see what they say! :)
/ Anyone Own A L6060? #26
I bought a Kubota L6060 in late 2016, it now has about 400 hours on it and it has been a great machine. I have 4 sets of rear wheel weights and 55 gallons of windshield washer fluid in each of the rear tires, traction isn't a problem for the use I have for it. Inside the cab, left of the seat and to the rear is tool storage area. Cab is great, hydrostatic drive is great, hydraulics are great. Phone Pics 010 (2).jpgIMG_1945.JPG
/ Anyone Own A L6060? #27
I bought a Kubota L6060 in late 2016, it now has about 400 hours on it and it has been a great machine. I have 4 sets of rear wheel weights and 55 gallons of windshield washer fluid in each of the rear tires, traction isn't a problem for the use I have for it. Inside the cab, left of the seat and to the rear is tool storage area. Cab is great, hydrostatic drive is great, hydraulics are great.View attachment 593134View attachment 593135
How heavy are your wheel eights? I have two sets a side as well, but yours stick out more; dealer said I could only use three each side, but I don't need it.
/ Anyone Own A L6060? #28
The Kubota weights are 106 Lbs. each + bolts.
I have two on each side as well and plan to add a third to each side because a third will extend only slightly beyond the rim.
I never use liquid ballast because I repair/change all of my own tires.
SDT
/ Anyone Own A L6060? #29
We must have our wheels set differently. We fix flats on ours too, but we still put fluid in. Now when we get one on our M8540 we call a service truck; just one flat and we decided, naw too old. As time passes, we'll probable take the tire off and trailer it to the dealer.
Here are the steps I got.
Do you find the steps on the right side useful? After 55 years of driving tractors I don’t ever remember getting out on the right side.
/ Anyone Own A L6060? #31
The only time I use the right side is if I can't get out the left, but my son uses whichever is closest. We have a bit over 150 acres of woods and quite a few washouts.
Here is what they replaced.
/ Anyone Own A L6060? #32
The weights are listed as 103# each and Kubota does show that three sets are the maximum recommended for that tractor, but I don't always follow all the rules, heck, I didn't always color within the lines as a kid. Now that I think about it, I used to play with tractors as a kid and I still play with tractors...hmmm! To add the additional weights just buy the weights and a bolt kit, works great.
/ Anyone Own A L6060? #33
After we quit farming we sold all stuff not realizing what twists and turns our lives can make.
/ Anyone Own A L6060? #34
Could you explain the misadjustment of the three point mechanism? I do not understand? Thanks....
My 3pt feedback rod was apparently mis-adjusted when I got my L4060. Listed the 3pt, then the loader all but stopped working. Dealer promptly figured it out & fixed it. Not entirely clear how that worked unless the 3pt is before the loader in the power beyond loop. And usually the 3pt is the last part. At any rate it hasn't been a problem since.
/ Anyone Own A L6060? #35
My L4060HSTC with loaded R4s is a good power to traction ratio. For most pulling tasks it's about right, which makes 20hp more on a L6060 excessive for its traction. However I wish I had more HP as I do a lot of mowing & roading, which arent traction limited. I'm over 15% down on power due to lack of oxygen at 7,000' here in Colorado.
My rear hydraulic valves suck & I hear most other Grands have lots of internal leakage on them as well. My 3rd function hoses are worn down to the braids under the tractor from driving over brush. I'm planning on picking up one of the recently announced skid plates from Paul that was previously linked.
Generally I'm happy with the machine. It's a good weight for my needs & bigger would be harder to haul with minimal benefits for me. I wish I got more HP due to the mowing, but budget wise it was the right call.
/ Anyone Own A L6060? #36
I have neither pump nor tank so cannot R & R liquid ballast.
SDT
/ Anyone Own A L6060? #37
Do you find the steps on the right side useful? After 55 years of driving tractors I don稚 ever remember getting out on the right side.
I like to be able to mount/dismount from either side of the tractor without walking around the mower.
This is easy enough to do on my vintage Fords but not on my Kubotas aside from my B1750.
SDT
/ Anyone Own A L6060? #38
We get it, your Fords are obviously better than any Kubota ;).
If you're limber enough the right loader arm makes a good handle, although that's probably easier to do on the rops model. I tend to get in on whatever side is closest to the house.
/ Anyone Own A L6060? #39
Technically you could get in from the right side on the cabbed Grands, but as a practical matter not really. The loader joystick is in the way as well as the HST go pedal. I'm not sure if I've really ever used the right step. I use the right door plenty when starting the machine or hitching things up, but not to get in or out of.
/ Anyone Own A L6060? #40
When did I say that?
In the past three years, I've sold three vintage Fords and bought four Kubotas.
That said, mounting/dismounting an M9960 (or even L6060) ROPS model from the right side is not easy for most folks. A step on the right side would be much appreciated.
Of course, we can blame the plaintiff's bar for the lack thereof.
SDT
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
120 GALLON WATER TANK (A62131)
120 GALLON WATER...
2008 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A61568)
2008 Chevrolet...
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
UNUSED WOLVERINE PT-16-01C UNIVERAL ATTACHMENT (A62131)
UNUSED WOLVERINE...
