Autosteer For Compact Tractor Retrofit?
   / Autosteer For Compact Tractor Retrofit?
Another area where GPS control would be useful on the CUT's would be ground speed controlled spray and broadcast for herbicide and crop nutrients.
   / Autosteer For Compact Tractor Retrofit? #14
Clearly you are in the majority. And sub-inch gps is expensive even for those with a defined need.
Yes. A "consumer grade" GPS and autosteer would not be a good match. They lack the precision needed to safely steer a vehicle.
I wonder what factors make gps autosteer so expensive. It seems like all the "components" are in place and probably paid for. Not enough competition, perhaps? Maybe the CUT market is simply not large enough to compete.
   / Autosteer For Compact Tractor Retrofit? #16
In my experience as a retired Navy Electronics Tech (Systems), particularly in Mine Warfare, a straight-up GPS System is accurate to placing 'you' within a few yards of where you actually 'are'. Which is fine for general navigation, including land vehicles which are controlled/steered by a human operator.
To truly narrow your position down to feet, or even inches, requires a "differential" reference (an accurately surveyed, geographical point - with a dedicated reference point transmitter of that point) to that vehicle's GPS System in order to do this. This is referred to as DGPS.
Add on top of this that, in order for autosteer to properly navigate your vehicle, the field would have to be precisely surveyed, with all fencing and obstacles pinpointed.
It's 'do-able' but the cost is prohibitive.
   / Autosteer For Compact Tractor Retrofit? #18
Know there was a link to one brand and think they are the company who makes if I am correct an auto steer you could use on compact tractor I think. It had motor that turns the tractor's steering where and would flip away from wheel for manual steering.
I have a B2710 Kubota with hydro transmission. Have done a good bit of spraying with it and no issue to keep my speed steady, I just set pressure where I need it to be to run tractor at the ground speed I am running with my hydro pedal fully pressed. Works great. Where I think GPS (have no desire for auto steer on any of my tractors but don't raise a crop that needs that precision) would be most beneficial on a compact tractor would be for spraying to prevent over lap or skipping. I can imagine if you have ball field quality lawn auto steer for mowing to keep the lines straight could be neat, but with good gps you should be able to do very very well.
My understanding is that the tractor operator can "teach" the GPS the field layout to some extent. My knowledge is very limited on the subject, however.
Establishing an A-B line for the tractor to follow in subsequent passes is part of the procedure. Obstacles such as mud holes, trees etc can be steered around manually followed by auto mode to get back on line.
   / Autosteer For Compact Tractor Retrofit? #20
I saw many years ago a guy buried a wire around his yard at the proper spacing that guided his mower with a radio signal on the wire. If you want to follow the same path every time it would be very accurate.
2012 Audi Q7 Premium Plus AWD SUV (A55853)
2012 Audi Q7...
Caterpillar CB24B (A53317)
Caterpillar CB24B...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
UNUSED FUTURE PDQ 40" LAND LEVELER (A57193)
UNUSED FUTURE PDQ...
2007 Volvo VNL Truck Tractor (A55315)
2007 Volvo VNL...
