Rounded off drain plug
/ Rounded off drain plug #1,241
Whew...for a minute I thought this thread had died!
/ Rounded off drain plug #1,242
It is so cold, I don't think a welder or torch will work in this cold.
/ Rounded off drain plug #1,244
/ Rounded off drain plug #1,245
I keep one of those in the tractor toolbox, it works well for replacing shear bolts.
Aaron Z
Thanks because I can seldom find a nut with enough room to use ours.
/ Rounded off drain plug #1,246
/ Rounded off drain plug #1,247
The torch regulators might freeze up, but I didn’t know there’s a limit on how cold you can weld?
/ Rounded off drain plug #1,250
/ Rounded off drain plug #1,251
A different owner.
Now that is a good idea. Still think that those of you in kando's neighborhood should have put him out of his and our misery long ago!
You don't really want to know... Well, maybe you do.. He started the Pallet thread, and didn't have guts enough to ask the farmer why the pallets were stacked in little inverted V's in the field.. A major disappointment for all of us.
You can start on page one... See you in the spring...
https://www.tractorbynet.com/forums/rural-living/299453-pallets-fields.html?highlight=pallets
An almost great read... but please don't focus on those crazy conspiracists who contributed more than their fair share to that thread.
/ Rounded off drain plug #1,252
Maybe Kando should be laying on a pallet while under there with his pipe wrench :confused3:
/ Rounded off drain plug #1,253
I know! It was, and is, the scientific endeavours to explain the inverted V pallet phenomena which contributes to the collective knowledge of humanity.
(They could still be the roofs of avian sport-team Mascots. Where else do they live during the off-season, eh? Where else do new ones come from?)
/ Rounded off drain plug #1,254
It has been a few weeks without a report on the drain plug. Any news?
/ Rounded off drain plug #1,255
The news is there is no news. About every fourth or fifth post is to ask if it's been solved, so that's the news. Snow and cold weather has apparently caused no news!
/ Rounded off drain plug #1,260
That is only because we have not come up with a way for Kando to get the drain plug out. If we had, the plug would be removed.
:stirthepot: :stirthepot: :stirthepot:
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
iDrive TDS-2010H...
3pt 20' Cultivator (A64119)
3pt 20' Cultivator...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-350...
2023 Case TV380 (A62177)
2023 Case TV380...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
