Added a hydraulic top link today
/ Added a hydraulic top link today #21
Just curious how you use that setup? I don't see much good having a bucket on the back, especially without a hydraulic toplink. Are you simply using the bucket to carry the forks? Cause you would do so much better with a actual forks. That bucket takes away from capacity, and pushes the load out pretty far
I don’t use it often yet but did it for using the bucket as a carryall mostly with the grapple on the front. I had plans (and am in the middle of) adding 4 remotes for which two are dedicated as TnT.
Yes. SSQA forks would be even better but I had my unused bucket and slide on forks not being used. I tend to leave the grapple on most of the time I’ve noticed.
/ Added a hydraulic top link today #22
Only 4? You need more so you can add cylinders to the QA and QH :D:
/ Added a hydraulic top link today #23
You only need a 3rd function & a pair of manual 3 way valves to do that. Leave the valves pointed to the SSQA cylinder by default. After you hitch up (and latch) an impliment requiring hydraulics you have to get off the machine to hook up the hoses anyway. So you can just manually actuate the valve then. When you need to un-hitch, get off, disconnect hoses then throw the valves back to default to you can unlatch.
I've got METRO Six Port - Two-position Double Selector Valves: 2 GPM, 1/2-14 NPT Port Size, 3 PSI, 28376 & Maxim 3 PSI Welded With Swivel Ball Ends | Bore 1in. Bore - 3 PSI 1 X 8 WLD CYL .625 ROD SVBALL 4-52 sitting on a shelf. Waiting for warmer weather & motivation to start the build on my newish L4060HSTC.
My previous power SSQA build. https://www.tractorbynet.com/forums/customization/321704-linear-actuator-power-ssqa.html
/ Added a hydraulic top link today #24
I want to see pics of the setup on your 4060 when you get it done. The ssqa on our tractors is a little different.
/ Added a hydraulic top link today #25
Will definitely post something. But really the SSQA on all Kubota tractors (loaders) is the same. My hydraulic setup will look like the linear actuator setup only with a hydraulic cylinder in the same spot instead of the linear actuator. Plumbing will look a bit different though.
/ Added a hydraulic top link today #26
Same idea I had, only thing different is mine uses a single handle release for the latches.
/ Added a hydraulic top link today #27
I was refering to the picture of the bobcat. that handle is definitely different than the regular two handled ssqa . I will check out your other thread. Kubota wants a rediculous amount of money for their hydraulic actuation of the ssqa.
/ Added a hydraulic top link today #28
I posted the picture from Bobcat. That picture angle doesn't show the other side.
Here is mine from the front:
If the cylinders are not there (it is an option), it operates manually.
/ Added a hydraulic top link today #29
Think it's over $1,200-1,500 for the option. The cylinder alone costs over $850. Mindblowingly expensive. Ya, it's probably custom, but so were my pair of TnT cylinders from FitRite that were cheaper & came with lots of hoses, fittings & other stuff. I'll be using a small 1" Bore x 8" Stroke - 0.625" Rod cylinder that was $41 new.
I couldnt find one that was really any smaller. A 300lbs rated actuator could do the job so no need for a lot of force to break things. 1 square inch of piston will generate 2,500lbs of force. I dont need to do the math to figure out the area of a 1" circle to tell me it will have plenty more than the 300lbs of force its proven to require.
Update after some use this weekend: I'm definitely happy with the hydraulic top link. It has saved me from getting on a d off for adjustments on my latest project....but more importantly it has given me just the clearance I need when in tight spots that would usually cause my box blade to catch. 20190323_184620.jpeg
/ Added a hydraulic top link today #31
Fallon,
are you planning on using a pressure relief valve to limit the force or just a stroke limiter. I took a closer look at my ssqa after taking the bucket off for the first time and it seems a lot simpler to implement now that I see how the handles are made.
The problem I see will be sourcing a cylinder with the right stroke length and attaching it to the handles. You can't bolt the cylinder onto a bracket because both handles need to move. unless we use two smaller cylinders
Limiting the force could be an issue if I can't find a relief valve that adjusts low enough. I wouldn't want to mangle the pins that move into the lower bracket if for some reason the attachment was not aligned properly before actuating the locking mechanism.
/ Added a hydraulic top link today #32
Fallon,
I got the smallest cylinder I could to minimize pressure. I do have a crossover relief valve to install, but I more got it for my hydraulic post hole digger & was planning on setting it to 2,500psi or so.
On my linear actuator build I measured out the stroke length & got the actuator based on that. It was to short, but I made mounting brackets to fit. I made them adjustable, so could tweak it so it bottomed out the actuator before hitting stops on the handles.
As the setup goes over center to hold the SSQA pins in place there is extra motion in the system. The actuator/cylinder will hold things in place if it stops a bit soon before the handles would go over center
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
2005 Polaris Sportsman 700 EFI (A66408)
2005 Polaris...
Skid Steer Trencher (A65640)
Skid Steer...
Coleman Go Cart, 2 Seater, Gas Engine (A65640)
Coleman Go Cart, 2...
