Ballast AG tires ballast
/ AG tires ballast #1
Haneyman
Member
John Deere 3038e
11.2X24 ag tires
Put in 24 gallons washer fluid
How full is that ?
80% ?
Was way simple to do thanks for the advice
/ AG tires ballast
Thanks very much!
Chart says 75% with 24 gallons.
Still amazed how easy it was.
Thanks,Mike
/ AG tires ballast #4
Where I bought my tractor and the company he uses to fill tires stated that he now fills tires at only 50%-60%. This is with beet juice.
/ AG tires ballast #5
That's what I've always been told, not to exceed 50%
/ AG tires ballast #6
I have read here and elsewhere it is 75% because that would completely cover the rim and can be filled with the valve at 12 o'clock.
/ AG tires ballast #8
New Kubota WSM show wheel aligned with stem at 12 pm fill till water comes back out so less than 75%
/ AG tires ballast #9
Wonder why they are saying only 50%?
/ AG tires ballast #10
That would just cover the top of the rim & is about 75%.
/ AG tires ballast #12
Two reasons. 1. Allegedly filling tires at 50% provides for smoother hwy travel and 2. To alleviate power hop when plowing or using draw bar implements at high speed.. Neither circumstance applies to many here.
/ AG tires ballast #13
Up to valve level is the norm. 50% is a scam when new tractors have ballast added for “free”.
Mine wasn't free but I didn't think to ask about how much was actually used or else I would have asked for more had I known they were only filled to 50%. Got charged a "standard fee" so you could call that a scam I suppose.
/ AG tires ballast #14
Agree on leaving room for air so that there is something to absorb shock when the tire hits an uneven surface. Just to the top of the inner wheel is where mine is.....how much is that?????? 50 gallons of water and AF in a 16.9x28 becsuse the tire service guy had 2 55 gallon drums in the back of his truck where he mixed up the brew and I used 1 per tire.
Want to know where yours is, wait for a warm humid morning when the atmosphere is warming faster than the tire.....fluid will sweat, air won't.
/ AG tires ballast #15
Exactly how I found out where my fluid level was.
/ AG tires ballast #16
Unless you live in Colorado. Where we have no humidity, ever.
/ AG tires ballast #17
A lot of different meaning in the word allegedly. Down in Louisiana where I farmed with my Dad till I was 24 years old and where it seldom gets cold enough to freeze a tire solid, we used pure water and always filled the tire a bit over full then with the valve stem at 12 o'clock, drained it till we had just air coming out. That is considered 75% fill. Never had any issue with highway travel, dont have a clue what you mean by power hop and have pulled drawbar pull implements all my life usually putting over 1000 hours per year on each of our tractors. If you mean the tractor tire jumping then gaining traction, slipping again, then more weight would lessen that effect better than less weight.
We always had our Ag tractors fully ballasted with water in all tires (front and rear), full sets of front and rear weights which usually equated to around 1000# in front and about that much on each rear wheel plus running duals on the rear when using ground engaging equipment. We never had power hop as you call it because we had the traction to prevent slippage to not more than 5%.
Actually I could see how 50% fill might cause more problems with liquid sloshing in the tire than a 75% fill since you have less air space for it to slosh in. Mostly the liquid just stays put and the tires rotate around it, pretty hard to make water run uphill but beet juice just may tend to a bit more than water or water/antifreeze mix.
/ AG tires ballast #18
You can slap the sidewall with the flat of your hand and determine the liquid fill level. The filled portion will have a dull thud, the air portion will have a distinct ring.
/ AG tires ballast #19
I say "allegedly" because I have not experienced the deviation myself. Less liquid means more space for air which serves as more of a shock absorber at speed as opposed to a more stiffened tire caused by more liquid. 2. Power hop is not "what I call it" but an actual term. This is "power hop" which is not a traction issue as much as having to do with harmonics.:https://www.google.com/url?sa=t&rct...=-tdObZ6jQoo&usg=AOvVaw30JV1m3y4ZwiqG-0WWs-9G
/ AG tires ballast #20
Power hop is corrected by adjusting inflation pressure and axle weight (ballasting) to the needs of specific applications. Blanket statements concerning tire fill levels having a linear effect on power hop are incorrect.
2022 EZ-GO ELITE...
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
KUBOTA L2501 TRACTOR (A64280)
KUBOTA L2501...
UNUSED MINI EXCAVATOR (A64281)
UNUSED MINI...
49" X 74" TAILGATE (A64280)
49" X 74" TAILGATE...
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
