Ballast AG tires ballast
/ AG tires ballast #21
Beet juice is non-corrosive and heavier than water...hence the 50%...Windshield washer/water may be corrosive so you need to cover the rim...which is approx. 75%...ie. to the top of the rim itself...I do the windshield washer stuff....as I'm not gonna fool with oozzing/stickiness of the beet juice if I have a flat...Shrps74
/ AG tires ballast #22
Power hop is corrected by adjusting inflation pressure and axle weight (ballasting) to the needs of specific applications. Blanket statements concerning tire fill levels having a linear effect on power hop are incorrect.
Correct. Some ballasting to alleviate requires less than 40% fill and further differentiates whether the tractor is mfwd or 4wd.
All and all, not applicable to the way I use my tractor as probably for a lot of others here.. They should have filled them to 75% as their blanket "theory" doesn't effect my skidding logs out as much as weight.
I didn't "power hop" once while pulling this stem out nor with the other 100 stems.. Must have been the 50% tire fill :)
/ AG tires ballast #23
Wonder why they are saying only 50%?
That's what I'm wondering. Our son has 2 tractors over 100hp and both have loaded rears to the top of the rim or about 75%. It's never caused a problem. One runs 18.4 x 38's and the other is running 16.9 x 38's. His L3940 with R4's is also filled to the top of the rim. His JD 5065M has enough weight in the rear that it's never needed filled tires or weights.
/ AG tires ballast #24
Just a guess but it may have more to do with the harmonic syncopation of 4wd tractors moving at speed tilling certain soils. I think Rick B is correct is that tire filling companies grabbed onto the "latest findings" and using that as a blanket excuse to use less fill for the same money. I've read that some larger 4wd tractors are recommended to fill tires at only 38% full.
This is like saying that everyone should be doing the same thing even if it has "zero" pertinence to others because it's advantageous to whomever has a stake in the matter..such as mandated ethanol use for inner city pollution but mandating it also for places like Vermont or Idaho.
