polemidis
Gold Member
On my both splitters I used W8-35 beam
I have mainly maple, ash and beech. I would like to process 200 face cord per year.
My budget is 7000 Canadian dollar. I need to purchase almost everything.
I want to have a log table infeed, something like this:
Theses models are driving by the PTO of the tractor.
Why should they have gearboxes? It does not make sense to me. They size the hydraulic pump accordingly. There is no need for mechanical gearing down since the hydraulic pump's displacement will be sized to match the load and flowIf you notice those have a PTO shaft on them. That means the pump is left on the processor l the time. Do some research on them and see but I would not be surprised if they don't have a gear box running that pump. That way you can use lower RPM's on your tractor. E mail the company or talk to a dealer that is the best way to get info to build what you want and then you can use ideas from several to make yours
Just use a higher gpm pump and turn it slower to accomplish the flow you need.
I have a new question:
Do you think that the valve of the hydraulic chainsaw need a motor spool (work ports A and B connected when valve in neutral) ?
Or there is not enough inertia to have this kind a valve?
Thanks
