nightdevil
Oh wow... Not sure that's possible though...
Final tire. All posts real time. If you have an option, do this on a hot sunny summer day.
Groovy!!!
Another great repurpose idea! :thumbsup:Watcha gonna do with all of them "fishing worms"![]()
I don't get how guys think that grooving your tires is going to make a big difference. Winter tires are made of a softer rubber compound which conform to the road more efficiently. That's what makes a winter tire. Grooves in a harder rubber wont flex anywhere near as much as the micro grooves you see in winter tires. Little to no improvement and you just marked up your tires causing them to degrade faster. Think about it logically.
Using turf tires to maximize your surface area or putting chains on is the best thing you can do.
How about you read through this thread and see that your "think about it logically" isnt quite right.I don't get how guys think that grooving your tires is going to make a big difference. Winter tires are made of a softer rubber compound which conform to the road more efficiently. That's what makes a winter tire. Grooves in a harder rubber wont flex anywhere near as much as the micro grooves you see in winter tires. Little to no improvement and you just marked up your tires causing them to degrade faster. Think about it logically.
A good few members have had good luck with grooving their tires.
Sometime logic doesn't apply.
My tractor seems to have better traction in the snow/ice we currently have. And when I was working in the dirt mud before the snow it also seemed to slip less.
And these are not like cars, where we can have one set of rims/tires for winter and another set for winter. We have to work with what the tractor came with, at least until they wear out. Then I could consider turf tires.
You have data to support your claim? Many folks have reported much better traction on snow after adding grooves. I don't have data but I would be willing to bet that the more grooves the better. And I have been thinking about it logically. Do turfs wear faster because they have more grooves?I don't get how guys think that grooving your tires is going to make a big difference. Winter tires are made of a softer rubber compound which conform to the road more efficiently. That's what makes a winter tire. Grooves in a harder rubber wont flex anywhere near as much as the micro grooves you see in winter tires. Little to no improvement and you just marked up your tires causing them to degrade faster. Think about it logically.
Summary: you have not tried this yourself and thus dismiss the effort.The only empirical evidence I can show is that my old man ran his tractor clearing snow, for 25 years up a steep road, 1/4 of a mile without grooves, without a problem. Any solid data I could link to here from tire manufacturers proving that that type of rubber is what makes a winter tire a winter tire. Not the pattern. I have also decided to use turf tires to plow up a significant grade, without issue for 3 years in both snow and ice. I never use chemicals.
I won't argue to say that pattern does not have any bearing whatsoever, but not enough to merit a marked difference in adherence. Snow binds to snow better than snow binds to rubber. When the tire spins it will break the contact. Kinda like when you run an machine with tires through mud, it fills up the grooves with mud, creates a smooth surface and the tire by its own virtue will spin, not create a situation where it will grab that much better.
I get it. I like to get my hands on things and make them better in any way I can. Save some money. Make it better, stronger, faster. Give myself the satisfaction that proven or otherwise, I can make a difference. If it makes you feel better go for it. Kinda like AMS oil.
