Buying Advice I am looking for the "most" stable CUT for my hillside avocado orchard
   / I am looking for the "most" stable CUT for my hillside avocado orchard #41
Thanks for the info. The ground clearance seems to be about the same as many small tractors. It would be nice if they came with a std cat1 3pt hitch and a mechanical 540rpm PTO shaft for versatility.
Most of us PT owners have no need for a 3pt hitch or mechanical PTO on the PT.
However, if you need to use a 3pt implement, it's very ease to weld a PT quick attach plate directly to a 3pt implement and off you go.
Or, you can weld a 3pt adapter to a QA plate.
You can also get PTO splined hydraulic motors if you need to drive some adapted 3pt implement. Or you can direct mount a hydraulic motor to a 3pt implement. Where there's a need, it's easy to adapt.
   / I am looking for the "most" stable CUT for my hillside avocado orchard #42
Any specialty machines that have their own attachments are usually an expensive proposition. I think there are budget considerations here.
It's very easy to adapt old 3pt implements to use on a PT.
   / I am looking for the "most" stable CUT for my hillside avocado orchard #43
This works well for me on the hillsides, but not big enough to lift what you need to lift. 20130629_160809.jpg
I would like to thank EVERYONE who replied to this thread.
Your ideas and experience have expanded my understanding and offered a wide range of potential solutions for my particular application.
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A55315)
2020 John Deere...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
M998 (A55852)
M998 (A55852)
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
