Buying Advice I am looking for the "most" stable CUT for my hillside avocado orchard
   / I am looking for the "most" stable CUT for my hillside avocado orchard #41
Thanks for the info. The ground clearance seems to be about the same as many small tractors. It would be nice if they came with a std cat1 3pt hitch and a mechanical 540rpm PTO shaft for versatility.
Most of us PT owners have no need for a 3pt hitch or mechanical PTO on the PT.
However, if you need to use a 3pt implement, it's very ease to weld a PT quick attach plate directly to a 3pt implement and off you go.
Or, you can weld a 3pt adapter to a QA plate.
You can also get PTO splined hydraulic motors if you need to drive some adapted 3pt implement. Or you can direct mount a hydraulic motor to a 3pt implement. Where there's a need, it's easy to adapt.
   / I am looking for the "most" stable CUT for my hillside avocado orchard #42
Any specialty machines that have their own attachments are usually an expensive proposition. I think there are budget considerations here.
It's very easy to adapt old 3pt implements to use on a PT.
   / I am looking for the "most" stable CUT for my hillside avocado orchard #43
This works well for me on the hillsides, but not big enough to lift what you need to lift. 20130629_160809.jpg
I would like to thank EVERYONE who replied to this thread.
Your ideas and experience have expanded my understanding and offered a wide range of potential solutions for my particular application.
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
Jacobsen three wheeler mower (A56857)
Jacobsen three...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
DEUTZ MARATHON...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
