Box Blade Tips
/ Box Blade Tips #1
SpaceRage
Member
Newcastle, NSW
Kubota B26
Hey Folks,
Ordered a 5ft box blade for my B26 last week, hopefully receiving it today!
Does anybody have some tips for getting this thing set up correctly?
Apparently the length of the top connector is very important to get effective results, any advice is always welcome....... I am going to try and clear up this area with it:
Thanks :dance1:
/ Box Blade Tips #2
Hey Folks,
Thanks :dance1:
I've got a 5 foot BB and have used it for years - both on a driveway and on raw ground. It works well and, really, is pretty obvious in its use so you shouldn't have much problem. You will want to keep it level with the tractor wheels - unless you want to make a ditch. I've used my to make really nice ditches. The top link rocks the blade back and forth. If you shorten the link the BB will ride up on its sides and be useful for smoothing gravel or finishing dirt. If you rock it back, it will dig in more and fill up pretty quickly. If you put the teeth down, it is handy for that plot your picture shows - unless you have a lot of roots or rocks.You can - again - adjust the angle of the teeth to do what you want them to do - dig deeper or stay shallow - and you can adjust their depth by sliding them up or down and pinning them where you want. My suggestion would be to leave the BB fairly flat at first and put the teeth down a few inches. Work the ground a bit then - depending what you ultimately want to do with it - try different settings and see what happens. Experience is the best teacher. I played with mine for a month or two and now find it an awfully useful tool for all sorts of things.
/ Box Blade Tips
I must be missing something. What are you doing with it?
It is not a clearing tool, it is a grading tool.
I'm planning to clear up the area, break up the top soil (it gets baked hard as down here in Australia), then try and flatten it out for some grass perhaps.
Its probably not the best photo as you cant see all the uneven areas down the back :)
/ Box Blade Tips #5
what are you going to do with the trees
/ Box Blade Tips
Planning to leave some of the healthier ones then cut the others down and dig out the stumps, hopefully can just bulldoze a few over.
Long term plan is to leave the taller trees and turn the area into a sort of shade garden with a watering system!
/ Box Blade Tips #7
There are quite a few threads on using a BB. The people who have a hydraulic top link rave about the ease of use with that added. "Luckily" for me, my dealer would not install the rear valve I needed so instead of spending $1000 for the hydraulics and $650 for a BB I have made so with a blade and York rake for my grading duties. But I am not having to move large amounts of material.
BTW, I also have many small trees to clear. I will be purchasing the item below and adding a diverter valve to my curl function to ease moving brush and also to handle logs for firewood. Something you may also wish to consider if you are doing a lot of clearing.
The Thumb - Add-on Grapple Attachments
Good luck with your project and welcome to TBN!
/ Box Blade Tips #8
I'll share a couple of vids by some valued EA customers to show you what to expect when hooking up a box blade for the first time and using it. This one shows the process of hooking up a box blade.
Travis
/ Box Blade Tips #10
Here's the classic Ted n Peanut video showing you how to use a box blade. Over 1 million views!
Travis
/ Box Blade Tips #11
Look at the ETA videos, then plan on wrecking some ground & burning some diesel converting learned data into usable wisdom. The nice thing about the box blade is you have the tool to fix your mistakes already hitched up, once you get it figured out.
My biggest recomendation is go slow so you can adjust the impliment before it starts cutting in ways you dont want.
/ Box Blade Tips #14
One of the most important tips I can give you is to not turn tightly when the knives are in the ground. You will twist the whole box up into a parallelogram before you know it. Run it slow and flat for a while until you know you won't catch small stumps or roots that can grab it and stop you quickly.
/ Box Blade Tips #15
Great tip guy .Am also looking to by a box scraper I see every one using a 5 foot wide.. Is a 6 foot to big for a B2650 or not .If you get a 6 ft that is the same wait as a 5 foot is the 6 ft still too much for a b2650
/ Box Blade Tips
Thanks for the tip - I hadn't even considered about twisting the box!
Videos are great, especially the one about connecting up to the 3PL.
Well time to hit the yard and get some work done...............
/ Box Blade Tips #19
Get a hydraulic top link if possible. Go about 4" longer than is recommended for your tractor if you have a set of Pat's on. I didn't and can't quite get it as long as I'd like.
CAT 225BLC Excavator (A61166)
CAT 225BLC...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2018 Ram 1500 4x4...
UNUSED WOLVERINE SB72-72" ROCK BKT (A62131)
UNUSED WOLVERINE...
2015 Nissan Quest Van (A61569)
2015 Nissan Quest...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
1999 Van Hool Transit Bus T2100 Bus, VIN # YE2TC63B3X2043319 (A61165)
1999 Van Hool...
