Slow fel
/ Slow fel #1
guitarman
Coarsegold, Ca
Jinma 454// other equipment husqvarna rancher 61 chain saw & model 460 both with 24 " bar, 2 husq trimmer, greemworks 40volt trimmer and pole saw. 20 ton wood splitter, various welders metal saws and drill press
My loader on my 2005 JM454 works fine plenty of power just operates slow any suggestions
/ Slow fel #2
How slow? Time from flat on the ground to full height?
/ Slow fel
Haven't cleaned the valve it takes a screw on filter which I replaced still slow
/ Slow fel #5
Check if the lever have full travel when move in and out (up and down ) off controlevalve ? Dirt in the endcap ?
/ Slow fel
Time is not terrible maybe 15 to 20 seconds which I can live with. Just know it could be quicker my son's JD 420 E is almost twice as fast. I know some of might be just peculiar to the Jinma.
/ Slow fel
Yeah has full travel. Probably should check some of the lines
/ Slow fel
Does move quicker when I throttle it up from idle
/ Slow fel
Have checked lines as far as kinks or crimped all are fine.
/ Slow fel
I got tractor with around 280 some hrs have just over 400 now has always been a little slow.
/ Slow fel
I haven't found any all seem to be screw on, threaded fittings
/ Slow fel #15
Often the QDs will get a chunk of crap in them and slow things down. That is a “choke” point for debris. You have to pull them to inspect them.
/ Slow fel #16
Faster RPM means more flow from th pump. Are you sure there is a 菟roblem or is this particular loader on this particular tractor just designed to run this speed ?
/ Slow fel
Unfortunately I think you may be right and it's just a peculiarity of a JM454
/ Slow fel
Was out using yesterday after finding what was problem with it dying which turned out to be accumulated water in the main screw on filter going to have to install a separater. Anyway I ran loader up and down curled it even tip it back while lifting all worked fine just not real fast.
/ Slow fel #19
I suggest you buy two gauges. Put one on each side of the lift cylinders. You should have pressure on the lift side while lifting and no pressure on the return side. If you stop lifting and there is pressure on the return side there is an internal leak.
/ Slow fel #20
isn't there a hydraulic speed knob under your seat? or is that just for the 3 pt hitch?
2023 Boxer 700HDX Compact Skid Steer (A63116)
2023 Boxer 700HDX...
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
2019 John Deere 4044M (A62177)
2019 John Deere...
STORAGE FEES (A59910)
Knapheide Service Bed (A61165)
Knapheide Service...
1997 Jaguar XK8 Convertible (A61569)
1997 Jaguar XK8...
