Slow fel
/ Slow fel #21
If you have your 3 pt hitch lifted all the way up try setting it a bit lower, then try operating your FEL. It may affect it.
/ Slow fel
The knob under seat controls 3 pt. And fel moves and operates same speed no matter if 3 PT is up or down I have even tried letting it down as I operate fel no difference. Even my tractor guy I got Angus from said it's just the way it is has to do with the volume of the Chinese pump.
/ Slow fel #23
Rereading some of the posts; Unless I missed something, you do not say that it was faster, only you think it should be faster because your son's is faster.
Is that correct?
If so, I still think gauges are needed. I got gauges with fitting for under $100. I put them in the loader disconnects.
If you are not getting enough pressure, it might be an adjustment on the relief valve. If it is by passing inside a cylinder then you will know which one to take off, before it makes more metal to contaminate you system and do more damage.
/ Slow fel
Haven't tried adjusting just talked to one I bought tractor from he has been dealing in Chinese tractors and doing equipment repairs for many years and says the pump on these doesn't put out the rate of flow to make system quick. I check and change the filters no metal really and power is not a problem.
2016 Deere 180G (A60462)
2016 Deere 180G...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
John Deere 7230 (A64126)
John Deere 7230...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
