Standing seam metal roofing over existing asphalt shingles?
/ Standing seam metal roofing over existing asphalt shingles? #1
IHDiesel73L
Anyone ever do this? We have an older farmhouse that had a major renovation done 20 years ago in which some new roof was installed over the new addition and the old roof was torn off and replaced over the existing house. The shingles are standard 30 year three tab that are 2/3 of the way through their life, I'm just thinking ahead and if we have the money to do it in the next couple of years I'd like to cover them with metal roofing rather than wait for a leak to develop. We don't have any leaks currently, but we do battle with grey squirrels and flying squirrels which have chewed through flashing and fascia boards and found their way into the attic and soffits. This is one of my motivations for metal roofing aside from the look.
We are out in the woods with no other houses around so we're not worried about "fitting" with the neighborhood. Our barn has grey colored standing seam roofing that is old and weathered and I'd like the house to have the same look. The barn roofing was simply bought in 12' x 3' sections and installed over purlins spaced 2' OC. The runs on the roof are 12' and 16', so with 12' panels on the 16' runs I would just plan to lap the section closest to the peak over the lower section according to manufacturer specs, seal the joints with silicone, and stagger the seams (ie: 4' panel at peak, 12' panel to edge of roof, 12' panel at peak, 4' panel to edge of roof, etc...). It seems to me that this would probably the last roof I'd ever put on this house (I'm 37 years old and plan to stay here for rest of my life)-am I missing anything here?
/ Standing seam metal roofing over existing asphalt shingles? #2
I see no problem to your approach. Check with the company selling the metal roofing. They may recommend a single layer of tar paper, or the like, before you lay on the metal roofing.
/ Standing seam metal roofing over existing asphalt shingles? #3
I've done standard 5 rib over shingles. Laid 1x4s over the shingles, nailed through to the decking, then laid the roof panels on them. My panels are screwed down which gets into another debate, or two, or three.
/ Standing seam metal roofing over existing asphalt shingles? #4
Use a synthetic felt between the metal and shingles. The only time wood lathe strips are needed is If your deck is not level. The manufacturer approves either application but all recommend the separation sheet y
To make sure the back of the panel is not scratched. If you do not know for certain that your deck does not have any weak spots it's best you tear off completely.
/ Standing seam metal roofing over existing asphalt shingles? #5
Could foam board insulation be added to reduce heat transfer into the Attic?
Would it be coat effective?
/ Standing seam metal roofing over existing asphalt shingles? #6
Money is better spent making sure you have proper ventilation. If your attic is not conditioned make sure you have excellent air flow and add more Batts or loose fill to the ceiling.
/ Standing seam metal roofing over existing asphalt shingles? #7
I have heard that one big issue is the condensation that forms on the back side of the metal. Personally, I would rather do a complete tear-off, repair any wood, waterproof, then install the metal with ventilation behind it.
Use a synthetic felt between the metal and shingles. The only time wood lathe strips are needed is If your deck is not level. The manufacturer approves either application but all recommend the separation sheet. To make sure the back of the panel is not scratched. If you do not know for certain that your deck does not have any weak spots it's best you tear off completely.
Makes sense. The roof over the new addition is in very good condition (no sag in the ridge, etc...) so I could go with just the felt there. The original part of the house has some sag to the ridge and waviness in the roof itself. It's all solid, just settled a bit over the last 130 years or so, so I would do lath to make the steel appear nice and straight.
Attic is unconditioned but has fully vented soffits. It is a walkup with 2x10 ceiling joists, so the joist bays were filled with 10" of fiberglass which is covered by 1/2" plywood throughout. There is also a gable fan.
It would seem to me that the waterproofing is already there in the form of the existing asphalt shingle roof, so why rip it off? I guess in the case of as M5farms pointed out, if you don't know/can't assess the condition of the underlying sheathing you might want to, but luckily in my case since it's a walkup, I can see every inch of sheathing from the underside. Since the asphalt roof had no trouble shedding the record amounts of rain it saw last year I would guess that some condensation from the undersides of the metal roofing panels would pose little challenge.
/ Standing seam metal roofing over existing asphalt shingles? #9
The barn roofing was simply bought in 12' x 3' sections...
FYI: If 3' wide, it's probably NOT standing seam.
All the standing seam I've seen is 16" or so wide per pc. If it went much wider, the hidden screws on the one edge covered by the 'standing seam' wouldn't be enough to hold the metal down.
3' wide metal goes by the name "Century drain" (among other names), does have raised ribs about 8" OC, and has rows of exposed metal screws across the panels.
Standing seam makes a much better roof, IMHO, due to the screws not being exposed, (each point a potential leak) and is often 26ga versus the normal 29ga of 3' wide metal, but it's more expensive than the 3' wide metal.
/ Standing seam metal roofing over existing asphalt shingles? #10
Maybe it's just terminology, but to me, standing seam is the type of metal roof that you don't see the screws and each piece of metal is a foot wide. Because of it's size, you have to install it onto decking. Plywood or OSB. R panels come in 3 foot widths and you can usually span 4 feet with it, so your purlins are installed every four feet. This is more cost effective and fairly common when going over an older roof. Any moisture that develops under the R panels is handled by the existing asphalt shingles. The drawbacks to leaving the shingles in place and putting R panels over it is that moisture the may develop under the metal. It can build up on the Purlins and create mold, and then rot. I've also seen moisture come out from under the metal, onto the porch and people not understand that their roof isn't leaking, it's just a lot of condensation.
If you go with standing seam, you really need to remove all of the shingles and have perfect decking in in place, then covered with felt paper or some other equally approved material. There are a lot of them out there to choose from.
/ Standing seam metal roofing over existing asphalt shingles? #11
I asked about all that when I did mine. Everybody said it wasn't necessary as long as there was enough ventilation under it and that was provided by the 1x4s and ridge cap. Air would flow up from the eave edge behind the 5rib panels and out the ridge cap. Mine has been on for a few years now and I haven't noticed any problems.
My roof deck was in terrible shape. Very old boards, a random mixture of 1x4s, 1x6s and 1x8s, some of which were rotted and cracked to the point they wouldn't hold nails for shingles. The new 1x4s and metal panels just spanned over all of that. Would it pass inspection in a coded area? I have no idea. Part of living out here in the sticks is that we can do what we want without all that trouble.
/ Standing seam metal roofing over existing asphalt shingles? #12
There is some condensation on back side but it's really not enough to be concerned with. Like I said the separation layer is there for drainage and to keep granules from scratching the metal and causing the metal to rust. Standing seam comes in 3 sizes 12" 14" and 16" as standard. Ask for pencil ribs or wave ribs this will reduce oil canning. 24ga is preferred but 26 ga is suitable for residential. Gonna be over 3.00 a lf .but it is the best metal roof you can install and likely never have to touch again other than cleaning it. 3' wide metal will need fastneners tighten or replaced in 15 to 20 years. I am selling replacement screws now for roofs I sold 15 to 18 years ago. There are no perfect roof systems all have pros and cons , if there was a perfect system I would sell it once and be out of business. If you want to talk in more detail pm me and I will send you my number. I've been in roof distribution for 19 years .
/ Standing seam metal roofing over existing asphalt shingles? #13
^^ Do you get into the sectional panels that are stamped to emulate shingles? I've also seen them in stone or brick for walls. A whole lot more expensive from what I've seen though.
You're right, I am referring to R panels, not standing seam.
/ Standing seam metal roofing over existing asphalt shingles? #15
Yes , I have sold alot of them. They are excellent systems but your gonna pay upwards 500.00 a sq just for materials
I'm good with a plain old barn style roof and don't mind the exposed screws, etc... It adds character IMO.
/ Standing seam metal roofing over existing asphalt shingles? #17
Pricey, yes, but I think there's a misplaced decimal point in there.
At any rate, the 5 rib works well for me, generally under $2/ linear foot, plus screws and trim.
/ Standing seam metal roofing over existing asphalt shingles? #18
Make sure to spend the extra and request ZAC screws .they will protect the washer and you will get long life out of them .
/ Standing seam metal roofing over existing asphalt shingles? #19
If 3' wide, it's probably not standing seam. All the standing seam I've seen is 16" or so wide per pc. If it went much wider, the hidden screws on the one edge wouldn't be enough to hold the metal down.
3' wide metal goes by the name "Century drain" (among other names), and has rows of exposed metal screws across the panels.
Standing seam makes a much better roof, IMHO, due to the screws not being exposed, but it's more expensive than the 3' wide metal.
/ Standing seam metal roofing over existing asphalt shingles? #20
No they are around 500 a sq. 3' wide is gonna run around 75.00 a sq just for panels. Galvalume is around 60.00 a sq
Echo SRM2620 Gas Trimmer (A60352)
Echo SRM2620 Gas...
2007 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2007 JLG 600S...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A61568)
2003 Ford F-150...
