Miller Plasma Cutter
/ Miller Plasma Cutter #1
Big Barn
Super Member
Victoria, B C
More than 40 over the years. Ten at any one time. Mostly Ford and New Holland
I have to admit that I frequently comment on how Miller exaggerates the cutting capacities of their machines compared to Hypertherm whose cutting specs actually seem to be realistic and sometimes even underrated.
I picked up this used Miller 1251 plasma cutter last fall but it wasn’t until last week that my electrician got around to running a (3 phase) circuit and plug/receptacle for me.
(It’s on an extra welding cart I have until I build a smaller suitable one)
I also had to order a new body and trigger for the torch handle and with some helpful advise from yomax , here’s a pic of the first cut I made on a Miller “recommended “ cut thickness of 1.25 inch.
I didn’t think to time it but the 3 inch cut took well under 10 seconds. And NO dross. To say I was surprised AND impressed would be an understatement.
/ Miller Plasma Cutter #2
nice...
We had a hypertherm 1000 3 phase at work, but it got sold with the project before I could use it. My former boss told me it was almost too much, meaning you couldn't keep up with it's cutting ability and keep a good line if done freehand manually.
/ Miller Plasma Cutter #3
That ain’t nothin. I can cut that faster with a hacksaw and file. I just karate chop anything under 1”!
Enough about me though! Did you end up with a phase converter or do you have 3 phase at your place.
I am fortunate that my dad brought 3 phase down the street for the farm in the early 1950’s. I can’t imagine what it would cost today.
Thanks, I know I will!
/ Miller Plasma Cutter #7
Terry, in the first picture, I see you have spiral wrap on your torch cable. Looks to be nice and smooth (rounded edges). Do you know the brand? I assume you put that on. Spiral wrap that I have used in the past had sharp edges and easily pinched my hand.
I don’t see a brand name, Mark. It may be Greenline. I just bought 3/4” ID hydraulic hose spiral wrap from my hose supplier.
Here’s a close up
I used the same wrap and enclosed the (upgraded) 6 gauge ground cable together with the torch cable for my smaller plasma cutter.
/ Miller Plasma Cutter #9
I think that sharp edge stuff was Heli-Tube. Victor had a sharp edge type too that was blaze orange. I like this black stuff much better.
/ Miller Plasma Cutter #10
I've posted these pics before of cutting 3/4" with my Miller Spectrum 625.
This was probably the outside limit of my machine but it did cut it slowly. I am very happy with it.
Where it really performed for me was cutting 3/8 and 1/2 bolts covered with mortar.
It melts the mortar instead of spitting and popping like with O/A.
On a side note I have found better prices on consumables on ebay for my machine.
/ Miller Plasma Cutter #11
Who is the eBay seller that sells the consumables?
I have spectrum 375 xtreme and I have been very happy with it for 10 years. It cuts 1/2” steel much better than Millers spec sheet would seem to indicate.
/ Miller Plasma Cutter #12
Just go to ebay and do a search with your Miller part numbers and you can even google the part numbers for deals.
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
UNUSED RAYTREE RMH680 HYD HAMMER (A62131)
UNUSED RAYTREE...
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
4 Shelf Rolling Cart 6ft x 3ft (A61165)
4 Shelf Rolling...
Bull Horns (A61569)
Bull Horns (A61569)
