Implements rebuild questions.
/ Implements rebuild questions. #1
Mowens
Member
Mitsubishi MT160
Ok 2 questions. Assuming no cost for steel.
1. I have a 5' bush hog the top is toast the gearbox is top notch. Frame kind of sketchy as well. So is it worth rebuilding into a 4'? I figure i can cut 6 inches off each side and narrow it it down. Figure length does not matter.
2. I also have a 4' disc that was built for a draw bar. Is it feasible to convert to 3 point? I think the best way would be to make a frame the gangs to bolt too.
/ Implements rebuild questions. #2
The tip speed would be lower as a 4ft. And have to rebuild the stump jumper or shorten blades. Unless I needed to get into narrow spots, I think I would leave it 5ft and go slower or partial cut if needed.
For the disc, I would look at other 3pt discs and copy the one I liked.
Bruce
Thanks. Yea its the trails im working through they run about 4+ feet. That's the whole issue. It's leased land I can't go chopping trees down to widen the trails.
Thanks for the advice. I think the land pride tube frame looks simple just a square frame with arms for the gangs and the 3 point
/ Implements rebuild questions. #4
Do you have a boom pole? Perhaps leave it as a towed disk and use a boom pole to lift it up?
Aaron Z
/ Implements rebuild questions. #5
on the cutter you would at least need to buy new blades and possibly even a stump jumper + your labor to repair it.
Im not sure how the used implement market is in your area but down here Ive seen 4 ft disk, and cutters $300-400
Well no boom pole.
It already needs new blades so that's going to happen either way. It dosent have a stumpjumper at all just a straight bar mount.
I'm in South Alabama on the coast. 4' implements seem hard to find. New I can order at 6 or 700 but that gets pricey.
Appreciate all the advice.
I think I'm just going to cut the sides down make it 4' wide leave it longer and get shorter blades. Keep it easy.
Make a box frame. And move the gangs over.
JCB 510-56 TELESCOPIC FORKLIFT (A64279)
JCB 510-56...
2020 Deere 544L (A60462)
2020 Deere 544L...
Four R207782 John Deere Wheel Weights (A63116)
Four R207782 John...
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
