Would you touch this with a 10 foot pole? Wood floor that IMO should be concrete
   / Would you touch this with a 10 foot pole? Wood floor that IMO should be concrete #21
Re: Would you touch this with a 10 foot pole? Wood floor in a job that IMO should be
Can you access site with concrete truck.if yes fill void with low strength mortar and then slab jack to get slab to final elevation
   / Would you touch this with a 10 foot pole? Wood floor that IMO should be concrete #22
Here, that would be five thousand bucks or more in concrete. Can that be right? Man, someone would curse and swear some day, if that had to be removed. And what of the pipes?.
I’d only need about 4 yards of concrete on the top. The rest would be cheaper fill.
Not within 50 yards. I’d have to transport it with my backhoe bucket.
   / Would you touch this with a 10 foot pole? Wood floor that IMO should be concrete #25
I thought you said something about 40 yards!
   / Would you touch this with a 10 foot pole? Wood floor that IMO should be concrete #26
I thought the owner wanted a wooden deck. Why plan for concrete?
   / Would you touch this with a 10 foot pole? Wood floor that IMO should be concrete #27
Pump truck?
That’s how much fill it would take to fill in the currently hollow underside of the floor.
He does and I want to concrete it. That was the whole point of this thread.
   / Would you touch this with a 10 foot pole? Wood floor that IMO should be concrete #30
If he wants a wood deck, tear out the concrete one, address the moisture issues, fix the brick, and put in a wood deck. Saves you the 40 yards of fill, compaction, etc.... probably a lot faster, and much less expensive than the concrete option.
MASSAGE CHAIR (A58216)
Tiger Mowers Mulching Head Attachment (A55973)
Tiger Mowers...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
20 UTILITY TRAILER (A58216)
20 UTILITY TRAILER...
2003 Big Tex 10PI...
2009 International 7400 T/A 6 Yard Cement Mixer Truck (A55973)
2009 International...
