Handling railroad ties
/ Handling railroad ties #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
Found out from a friend who used to do this kind of thing. He says I need 4 8x8 railroad ties. He says that was what he used to support his 3500 # tractor over a stream. He bought 16 footers and told me where to get them. I'd cut them (or hire the lumber Co. to do it) to about 10' before loading in the pickup, as this is the length needed. Probably be around 200 # each, as an 8' tie is 170 #.
He no longer does that kind of thing because of his age. Been trying to find bridge builders. No bites so far.
So, think we'll have to do it ourselves, me and the mighty wife. Been thinking about how to handle the railroad ties. First chore will be to get them out of the pickup. A boom pole may help for that, but what how to attach a rope to a tie? Have Googled "grapple on a rope" and "hanging grapple" with no success in finding a smaller (200-300 # capacity) grapple. Could use a long rope looped up to the boom pole and all the way back, but then how to raise a tie to get the rope under it.
To get the tie across the little stream, can use the boom pole. Found out they have a 7' reach past the 3ph. That would be about right to get the approximately 10' tie across, holding it just past the half way point so the back end at the tractor will stay down, etc.
Then again, how to hold onto the tie: grapple or rope loop. Could use something like the tow hook that came with both Mazdas, e.g. screw into a tie and lift with it (could weaken the tie). However, comes the problem of how to get it out once the tie is in the middle of the stream. Where the stream is is maybe 5' deep with the water in it a few inches. A rope loop would work. Could lift a tie with the FEL and then prop it up and put rope loop under it. Maybe screw in a small bolt into the tie, to ensure the loop won't slip.
Any ideas? Also thought about putting some small bolts into the tie end near the stream and lift with the FEL and plop the tie onto the other side. This is how I did the 4x4s for the people bridge. Ties could slide sideways on the FEL, maybe not be held by the bolts digging into the soft, grassy ground.
Ralph
/ Handling railroad ties #2
Look for a handyman or friend to help you out- work with you instead of doing the whole project.
I’m concerned that if getting the ties out of the truck is challenging you you need help that is physically there.
/ Handling railroad ties #3
I put them across the loader bucket and strap them down to move them around.
If you have vehicle access to both sides of the stream, try dragging them across from the other side. Use a tow strap wrapped around one end at least twice.
/ Handling railroad ties #4
Log skidding tongs from Northern Tool will do everything you are talking about.
/ Handling railroad ties #5
Should be able to just strap the Ties to the bucket and use the bucket to lift them out of the truck bed. Make sure you have some counter weight on the 3 point. A 200 pound load should likely not need one, but it will make you more stable and secure. Of course make sure your straps have a WLL of at least 200 pounds and use 2 or 3 of them for redundancy and safety in case one happens to fail.
Think I'll get a set of these: log skidding tongs from Northern Tool + Equipment
Thanks.
Don't see how one would get a tie strapped onto the FEL from the side of the pickup. Have access to both sides of the stream, but the thing is about 5' deep in the middle. No easy way to man handle them. Got a good friend who is big and strong and have hired him as a handy man in the past, but need a couple of ones like him. That's why I was looking at hiring it done.
Ralph
/ Handling railroad ties #7
I bought a set of lifting tongs from Northern Tools several years ago. On sale for $29.00. They work really well. I hang them off of a chain from a hitch on my FEL arms. Don't have to get off the seat. I just drive up and lower them down onto the log, bounce the control a bit and they'll open and slide right around the log. Lift up and off you go.... unless the log weighs more than the machine.... or the grapevines won't let go!
:laughing:
564366d1532699857-firewood-gathering-power-trac-1c9bd345-4e50-47c0-967c-c1a808562124
/ Handling railroad ties #9
I've been reading about the Suburban and the ToolCat for years, yet I believe this is the first picture I've actually seen of them. :thumbsup:
/ Handling railroad ties #11
Those lifting tongs have no problems with standard telephone poles, so RR ties should be no problem. The only problem will be balancing the load so it hangs evenly. When moving, it'll tip back and forth. So just be careful when you lift and move near your truck or it could swing up or down and hit things. That's why a two-point lift with straps would be better. Or forks from the side. Or forks from the side at the back of the truck and slid the ties onto the forks.
/ Handling railroad ties #12
Not a tool cat, a PowerTrac. I'd like a tool cat, though! :thumbsup:
/ Handling railroad ties #13
One more plug for the tongs...
Please excuse the shakey iPhone video and one-handed tractor operating. ;)
/ Handling railroad ties #14
Railroad ties here, are 7" x 9" x 101" long,
In some area's of the track they need longer ones, but when I was going to saw out ties, the above spec is what they wanted.
SR
/ Handling railroad ties #16
Those ties weigh 200+ pounds each, so it's a fairly heavy load...
SR
/ Handling railroad ties #18
SR
RR ties weigh rather different depending on the species of wood. An oak tie is much heavier than fir, tamarack, etc. Not sure just which species are used here but I hauled and placed around 60 Pick one end of one up and slide into truck with only a little gurnnting and the next one wouldn't even move wiht the same effort.
/ Handling railroad ties #19
Instead of a grapple and boom pole the simple way is to use your loader bucket,
Use a heavy ratchet strap, pull up with your loader with the tie making a tee shape lower the bucket
down on top of the tie, say 3 feet from the end, loop your strap under the tie and back to your bucket,
with the strap to the front side of the bucket tighten the strap, lift with your loader,
the heel of your bucket will hold the end of the tie down and you can drive right up with the tie extended
set it down and be done with it.
I hope my description is clear, it will be similar to a clamp on fork lift arm, only the strap replaces the clamp bolt.
your bucket .
/ Handling railroad ties #20
I plan on making tongs out of flat steel welded into shape just to pick up logs onto the splitter and dragging some branches out.
Youtube has a channel for Unemp.loyed Redneck Hillbillly Creations and he has innovaative log movers which would probably work too.
He has some nice gear too.
2022 EZ-GO ELITE...
(1) 40 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 40 Yard Roll...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2018 Chevrolet Suburban 4x4 SUV (A64557)
2018 Chevrolet...
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
