DK50se Loader quick connect fittings
/ DK50se Loader quick connect fittings #1
liberty2701
Lakes region,NH
Kioti Dk50se hst
/ DK50se Loader quick connect fittings #2
My loader quick connect fittings all leak. I flushed them out with no luck. The o rings must have damage. I think I will probably just purchase new fittings. I did replace the o ring once on one of them but it leaks again.
Same problem on my DK40SE, I have 2 of the 4 that leak. I replaced the o-rings in them and they are leaking again. I am going to replace the female fittings only and see if that works.
I just updated my post above. They seem like a cheap replacement.
/ DK50se Loader quick connect fittings #4
I buy from discount Hyd and everything I have purchased has been good. On my new grapple it came with flat face fitting . At first i did not like them but once I figured out how to make the connections easy I like them
/ DK50se Loader quick connect fittings #5
My leaky quick connect turned out to be a leak at the NPT adapter, not the actual coupling. I think the threads on the adapter were not machined right and it took a lot of teflon tape to stop that leak. Thread sealer paste would not do the job.
Good point but mine is definitely coming from the quick connect itself. I have more than once had them disconnect on me while working in the rough stuff probably letting dirt get in.
/ DK50se Loader quick connect fittings #7
I've had good luck with discount hydraulic as well. On rare occasion, I've had some female JIC fittings from them crack before the appropriate number of flats have been turned on installation, but their customer service replaced them with the appropriate amount of effort. So we continue to do business. They have been a great resource for me.
Because I feel like rambling, I'm partial to the series A Quick Disconnects (ISO 7241) You'll find them worldwide on a multitude of general purpose applications. They are a bit more durable than the Agricultural (ISO 5675) which are lighter duty, typically not seen outside of North America, but are appropriate for light duty ag applications. A great argument can be made for the flat face skid steer QD's (ISO 16028), They are expensive, but very functional in practice, and gaining ground in the worldwide market.
A Series: ISO 7241-1 Series A (6 Series)
AG: ISO 5675 Agricultural
Skidsteer: ISO 1628 Flushface
I would say these are the most common 3 you'll find around tractors, skid steers, excavators, ect.
The B series which is very similar to the A series, and shares the same ISO, will be found among more industrial applications like onboard drilling rigs equipped with ring line systems. Same flow rates, pressure ratings, and durability as the A series, but you just won't find them around our applications very often. I could see this being an easy accidental purchase, as they are fairly similar.
/ DK50se Loader quick connect fittings #8
So my tractor is down in TN where we are building a house. Any idea what size the couplers are for the FEL QD? I believe 1/2" but what size threads? The ISO 5675 sets on the site have multiple offerings for 1/2" coupler sets with different thread sizes but the ISO 7241 sets only list them as 1/2" couplers with no reference to thread sizes.
/ DK50se Loader quick connect fittings #10
This should be the female coupler, it will be 3/8” NPTF threads.
Set at discount hydraulics
6-6-6S | Set of 3/8" Hydraulic Quick Disconnects (Steel): DiscountHydraulicHose.com
Just the female
61-6-6S | 3/8" Female Coupler x 3/8" NPTF Female (Steel): DiscountHydraulicHose.com
/ DK50se Loader quick connect fittings #11
If your talking about the couplers for the factory loader, they are 3/8”not 1/2”
Part # 31 is the male end
https://partstream.arinet.com/Mobil...yJe2KyHS_XeN0XoIpCbZhcF5wJ3eZQARld2OimA1.html
So the QD's for the FEL are different sizes than the rear remote? I thought the rear remote was 1/2"
Thanks for the info, I can order these and take them down with me next time I head down.
Oh, that link didn't work, looks like a mobile only link. I tried finding that hydraulic box in the parts under hydraulics but couldn't find it.
OK , take that back, I found them as part of the FEL, shows both male and female connectors there.
/ DK50se Loader quick connect fittings #12
Yes the loader quick connects are smaller.
Sorry the link didn’t work, yes I guess it was a mobile link, I was on a iPad.
/ DK50se Loader quick connect fittings #13
No problem
I got the couplers already but here is my next complaint
I ordered new dust caps since the stock ones got torn off, the caps are listed right with the 7241-1 couplers. So I pick the following one and get 4 of them for the female couplers (ones that go on the tractor end of the FEL connection), 6-6-CAP | 3/8" ISO-A CAP For Female Coupler: DiscountHydraulicHose.com
When I get them, they are caps for the 3/8" male connector. What gives? am I reading this wrong?
I don't see any other dust caps to order for the female connector.
/ DK50se Loader quick connect fittings #14
The description is not correct, it’s says cap in the part number, but at the end of the description it says “ For female coupler” which would be a plug. The one after that one says plug in the part number but then it says “ for male nipple” which should be a cap. I would call them Monday and let them know about it, they will get you the correct ones.
This should be the correct number.
6-6-PLUG | 3/8" ISO-A Plug For Male Nipple: DiscountHydraulicHose.com
/ DK50se Loader quick connect fittings #15
Update: I called DH and they are sending out the right covers, actually plugs. They agreed, website has wrong description.
Mini Universal Trailer Mover (A65640)
Mini Universal...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2011 FORD F-150 (A65643)
2011 FORD F-150...
2014 BRENNER 210 BBL CRUDE TRAILER W/ PUMP (A65643)
2014 BRENNER 210...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
