Closeouts at Bailey hyd
/ Closeouts at Bailey hyd #1
agjones
Jessup Mill, NC
Rk55HC, Kubota kx040, power-trac 425d, Bobcat L23, Yanmar 401w, bx1880, IHI 30 and Fiori D40 dumpers, Magnatrac mh5000, Dew-eze ATM72LC Slope Mower, Terramite t6 4wd, DR Power brush mower
Not sure if any of you are contemplating upgrading, repairs or changing your pt hydraulics but Bailey has some useful discounts on components...
https://www.baileyhydraulics.com/products/clearance
grabbed a 2 spool joystick valve and selector for pretty cheap...
Happy new year
Andrew
/ Closeouts at Bailey hyd #2
Thanks for the heads up. Just ordered a selector valve for a little less than I've seen it elsewhere.
This might be batter placed in the hydraulic forum.
/ Closeouts at Bailey hyd #3
I was just looking for two 2x24 welded cylinders and found what I need in the Closeouts.... EXCELLENT deal!! Thanks!
/ Closeouts at Bailey hyd #4
Thank you, found a joystick to convert my old JD loader from 2 stick in closeout for 1/2 price . Customer service was excellent in helping me determine which unit I needed.
/ Closeouts at Bailey hyd #5
Nice post, thanks
ordered 2 4x8 cylinders yesterday and a selector solenoid yesterday.
My joysticks, manual selectors and rotary selectors averaged 40%off. Shipping was reasonable and really fast.
For power-trac owners... This is a cheap path to select the quick attach or grapple function... Instead of moving those quick disconnects under pressure...
/ Closeouts at Bailey hyd #7
Ordered Wednesday afternoon , valve was at my house when I got home yesterday.
/ Closeouts at Bailey hyd #8
Got my valve yesterday. 2days. ;)
I did have to call in my order. Couldn't get the online cart to accept my card. Same card went through fine over the phone and shipping was 4 bucks less than online calculation.
/ Closeouts at Bailey hyd #9
I have already installed mine. Works like a champ. Did have to make 2 trips to town for fittings but all total I have 200.00 in a joystick conversion. I am tickled
/ Closeouts at Bailey hyd #10
agjones -
I'm mostly ignorant when it comes to hydraulics but willing to learn if it could simplify the QA/Grapple process.
Can you specify what I'd need to do what you refer to?
- 2 spool joystick valve (I see there are 1, 3 and 4 spool also but not sure what the differences are)
- Selector (Manaul and rotory) do you need both or each performs a different function?
- Do GPM and PSI have to be matched to the machine (mine is a PT-425)
I probably don't know enough to even be asking the right questions so your input would be much appreciated.
Thanks - Andy
Hey Andy - great questions... Pretty much the same starting place as me... I was flat footed on hydraulics when I bought my pt 425.
There's a ton of ways to do this... I'll start a new thread and reference another one that covered the cheapest way to do this upgrade a few years ago... Things have changed...
The core of the solution is a selector valve, a six port one will let you choose which of 2 connected cylinders is actuated when you move the controlling lever.
Of the options in the Bailey clearance, 220962, is in my opinion the simplest way...
Details in a separate thread... I'll try to post tonight...
/ Closeouts at Bailey hyd #12
Thanks again for posting this Andrew. As I had mentioned, I was just shopping for two 2"x24" welded cylinders when you put this on TBN. I had in fact even looked at Bailey's but for whatever reason the closeout cylinders didn't show up when I searched their store the first time.
The best deal I could find ( and what I was going to order) was $118 each including shipping ( $236 total). The ones I ordered from Bailey's came out to $158.66!!! I'll take a 33% discount any day!!!!!
You bet Darryl. Glad it's helpful. Shipping can be rough on hydraulics these guys are fair and really helpful when you have questions in my experience.
/ Closeouts at Bailey hyd #14
Y Shipping can be rough on hydraulics these guys are fair
Indeed!! I got free shipping (arrived in 2 days), no tax and at check out they gave me an additional $15.50 (9% off) that I wasn't expecting. I have shopped Bailey's for years but never bought from them, I always ended up buying from Surplus Center, Ebay, Maxim, etc.. I am SOOO pleased with the deal I got from them!!
Wooden End Table (A61569)
Wooden End Table...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A61567)
2025 Wolverine...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
