Snow Blade 3rd Function valve HAUNTING me
/ 3rd Function valve HAUNTING me #1
Fromjim
Northern New Brunswick Canada
Kubota M 108X
Part One, The first part is from my original problem, so people will know what I am talking about,
Re: 3rd function valve on Kubota
Quote Originally Posted by Fromjim View Post
Hi Everyone,
I sent an email to ALO, Sweden, the maker of loaders for kubota, they call them Quickie S40, Kubota calls them M40 loaders, after explaining my problem I asked for help in finding out the problem with my hydraulics, this morning I received a phone call and their troubleshooter asked me a few questions and came up with this response, the third valve is usually installed by the factory but sometimes it is installed by the dealer, installing a third function valve simply involves installing a servo valve and the plumbing for the hoses that would angle my plow, also connecting one of four plugs for electric control from the joystick. The problem comes when the servo valve is installed, it is round and has two possible ways of being installed, if you are not careful making sure the ports on the servo valve match the ones on the hydraulic spool valve you have a problem like mine, I was told to remove the servo, check the matching of the ports and if not matched to rotate the servo valve, each part has 5 ports, two on one side of the face and three on the other, seems simple if you know what you are looking for, the problem is that the wires come from the left when facing the valve and one would assume the Solenoid would be on the left, which if done this way causes the ports not to be in alignment, the reason my valve had limited use, is because two of the ports are slightly oval and when installed wrong will still partly cover the three holes but will not operate properly.
I removed the servo valve, rotated it 180 degrees, re-installed and now everything works perfectly.
If anyone needs more information just post or email me.
Thanks for your interest and help
Jim
_______________________________________________
Part Two: My Current request for help
Back to view this old problem, today, Dec 24,2018 I decided to try and find out what is wrong now, having not used this plow since 5 or 6 years I now find that my plow will not angle, so decided to read and see what the original problem was, the valve body at that time had to be rotated and my problem was solved, this time nothing works using the switch and buttons to activate solenoid that diverts the hydraulic oil to angle the blade, my problem has to be, either electrical or mechanical, I need help details in doing both.
Thanks for your help and patience,
God bless all and have a Merry Christmas, Jim
/ 3rd Function valve HAUNTING me #2
Check for voltage (use volt meter) at solenoid while operating switch/buttons.... IF you have voltage at solenoid its probably mechanical (solenoid?), if no voltage at solenoid with switch/buttons operated, its probably electrical...
IF you don't have volt meter, this will do... Connect across solenoid, light "on" you have power, light "off" you have no power....
I have various volt meters from really cheap to quite expensive and for basic 12 volt DC trouble shooting this is simplest tool (not good for digital/computer circuits however)...
Dale
/ 3rd Function valve HAUNTING me #4
Ahhh - I would guess the electrical contacts are corroded. First attempt to clean, if access is available. If still - no joy, replace.
I would have to remove the connection block at the solenoid valve to check for power, correct?
/ 3rd Function valve HAUNTING me #6
Two checks one at valve, next is power straight to the valve. If valve does not work, disconnect both wires and measure ohms. If you read a few ohms resistance it might be stuck, smack a few times both with and without juice, might fix itself.
Thanks, I'll do this when I can get someone to help, don't think I can manage alone. Would I just tap the side of the solenoid with a light hammer ?
I'll let you know the results
Have a Merry Christmas
Jim
/ 3rd Function valve HAUNTING me #8
I would tap with hammer handle, not too hard on the plastic -
Hope everyone had a very Merry Christmas, I just want to update my problem getting my 3:rd function to work, at first I thought it was a faulty switch in my joystick, since after removing the switch cover I could see there was no power going to the 3:rd function solenoid valve connection and also no power at the disconnect ,( seven contact plug feeding loader), there had been power earlier, so I decided to trace to the source and found that this wire is connected directly to the tractor on the left side and an odd type fuse is OK and there is power at the fuse, I have never seen this type of fuse, it is made of black plastic and has pointed metal ends with a thin strip of exposed metal on one side joining the ends, 10 amps is stamped on it, I then went to the connection this wire feeds, the seven contacts, and it no longer has any power, what I find odd is this 7 contact plug had a loose connection and I took the plug apart to make a secure connection, I re-assembled the 7 contact plug, checked the contact that brought power from the tractor to the solenoid and had power, but some how I lost power after assembling the plug, no power to this plug, no power to the joystick, no power to the solenoid, I will disassemble it tomorrow, make sure there is power at the 7 contact plug, and the joystick and it should work. I can't understand two things, why this odd fuse, what is the fused wire connected to, can't really see where it connects, just the wire coming from what I thought was the alternator but now I don't think it is, it is on the left just about a foot from the oil dipstick. I'll check tomorrow with the engine off to see if there is power, I have always been testing with the tractor running so far
I forgot one thing, I see a safety switch in the attachment, does anyone know where it is on the tractor, and what it does, or does it have to be reset, I don't have a clue where or what it is.
Thanks
God bless
Jim
/ 3rd Function valve HAUNTING me #12
One thing to be aware of, if you are using the bucket dump circuit to angle a standard truck plow with two single acting cylinders, it will NOT work if your loader valve is in "fast dump" or "regenerative dump" position.
Not sure if that is the case, but I hate to see someone chase their tail around in circles for something that their system cannot do.
Aaron Z
I am not changing any original wire connections, simply trying to get the signal from the joystick to the loader through the original wiring, I am about to go out again and try getting power from the tractor source to the solenoid at the 3:rd function valve. seems simple enough, had power there a few days ago but for some reason power failed after I had everything connected, try again today. Have any ideas"? let me know, I'll report when I am done for today.
Thanks
God bless
Happy New Year
Jim
/ 3rd Function valve HAUNTING me #14
Wish I could come over and give you a hand, but it is a long drive from Texas, especially this time of year.
Hi Everyone,
I started from the source, and it is the alternator, power to and after the fuse, about 6"from the alternator, went to the 7 connector and had power to and after the 7 connector plug, checked at the joystick and no power after the switch in normal mode, but when using the button to angle the plow I had power, hooked up the plow and Thank God had power to angle the plow, can't figure out why there was no power last night, must have been too tired and forgot to connect some wire, but all is well today, plowed all our drive and yard, worked real well, think I'll use the plow when we have small storms, it's quick and does a real good job. It's sure nice to know you can get help from you people, Thanks again, May God bless you and have a very Happy New Year.
Jim
/ 3rd Function valve HAUNTING me #16
Thanks
God bless
Happy New Year
Jim
Safety switch...the seat does it cut power to hyd solenoids?
Still don't know what the safety switch does, only see it mentioned in the wiring diagram, someday I drive to my dealer and find out, unless someone on here knows.
Well the new year is finally here, have a Happy Blessed New Year All
God bless
Jim
2018 CATERPILLAR 303E CR EXCAVATOR (A65053)
2018 CATERPILLAR...
Jack Daniels Sign (A64557)
Jack Daniels Sign...
2024 HITACHI ZW95-6C WHEEL LOADER (A65053)
2024 HITACHI...
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
2011 GMC Acadia SUV (A64557)
2011 GMC Acadia...
2020 CATERPILLAR 306CR EXCAVATOR (A65053)
2020 CATERPILLAR...
