Compact Tractor Diesel Particulate Filters (DPF)
/ Compact Tractor Diesel Particulate Filters (DPF) #11
BTW.....good thread. I’m happy to see no mention of a heavier DPF being a critical deciding factor on purchase of machine
Just kidding. But I am looking forward to learning a little more about them. What I’m real curious about is “how long do they last?” Does the DPF that came on it last lifetime or after X hrs or Y regen cycles it has to be replaced. And if it does have a limited lifespan, does it have to be replaced or can you just drill it out like you could (illegally but would function) a catalytic converter on a car?
As a rule, The DPF is good for about 200 regens or 3000 hours
I had an interesting conversation with a mechanic friend of mine. He works for a dealership and told me that about half of the warranty calls they get are for emissions systems. Here is a example of the stupidity of it all. If the computer senses that the DEF heater isn't working properly it will turn down the horsepower of the tractor. Even in summer when a DEF heater isn't needed. It would only be a few lines of code to tell the computer to ignore the DEF heater malfunction in summer but that would be too simple so a farmer has to wait until the service mechanic can come out to fix the problem. This doesn't go over good with customers who can't get their crop off because someone was too lazy to write a few lines of code. My friend tells me that any used tractors that get sold have the emissions software deleted.
Just to be clear, neither subcompact nor compact tractors have DEF/urea.
I would prefer to focus this thread on Diesel Particulate Filters and compact class tractors for simplicity and clarity. Few tractor neophytes will purchase a utility class tractor as their first tractor.
Diesel Exhaust Fluid (DEF) as an auxiliary to DPF begins on Utility class tractors, the next heavier category of tractor.
I have no experience with DEF.
"Diesel Exhaust Fluid (DEF) is a non-hazardous solution, which is 32.5% urea and 67.5% de-ionized water. DEF is sprayed into the exhaust stream of some diesel vehicles to break down dangerous NOx emissions into harmless nitrogen and water. ... DEF is not a fuel additive and never comes into contact with diesel."
"A 32.5% solution of DEF will begin to crystallize and freeze at 12 deg F (-11 deg C). At 32.5%, both the urea and water will freeze at the same rate, ensuring that as it thaws, the fluid does not become diluted, or over concentrated. The freezing and unthawing of DEF will not cause degradation of the product."
As a rule, The DPF is good for about 200 regens or 3,000 hours.
The average residential tractor user operates eighty engine hours per year, according to industry surveys.
3,000 hours / 80 hours = 37.5 years of residential use prior to DPF replacement.
I speculate that DPFs in warm climate areas like Florida, may last longer than DPFs used in cold climate areas where tractors in winter may warm at idle for thirty minutes prior to use, and tractors are used for snow removal in very cold temperatures. The DPF will be colder between winter regenerations in the northern tier of states.
I have yet to read anything here regarding my speculation. I do know my three cylinder Kubota L3560 runs sixty engine hours between regenerations.
/ Compact Tractor Diesel Particulate Filters (DPF) #14
This might sound a bit dumb, but most agree that breathing in diesel fumes, weather they have been through a DPF or other process, is not best for our lungs. But many tractors have their exhaust pipe right in front of the driver. This means that whilst travelling into the wind the driver is breathing in the exhaust fumes. Many have cabs, OK but still the cab is in the `fume cloud`. This leads to a question of, `would it not be better to move the exhaust pipe to somewhere else.` and `does the pipe have to be where it is or is just traditional, because that's where our fore fathers put them`
In the USA new compact tractors usually have exhaust routed under the tractor. My Kubota L3560 exhausts under the tractor to the front.
New Kubota utility tractors in USA have vertical exhausts. Hot exhaust wants to rise. Vertical exhaust may disburse processed exhaust before it contaminates organically raised crops during harvest. (??)
(During my working years I was tangentially involved with the production of certified organic wine grapes.)
My DPF equipped Kubota does not produce the diesel smell nor diesel smoke of pre-Tier 4/final emission technology tractors. The DPF is there to reduce particulate emissions. Today's diesel fuel in most, not all, of the world is ultra-low-sulphur fuel.
/ Compact Tractor Diesel Particulate Filters (DPF) #16
Generally once every sixty engine hours. (Very consistent in Florida due to warm weather.)
60 hours X 60 minutes = 3,600 minutes.
16 regeneration minutes /3,600 = .00444 = 4/10s of 1% of engine time is consumed during parked regeneration.
Fuel cost for sixteen minute parked regeneration @ 2,200 rpm ~~$1.00.
My L4060 has averaged 57 hours per regen across 5 so far.
Not that it really matters, but doesn’t the regen process use additional fuel by injecting it directly into the dpf ? I thought that was the case, but I checked the manual, and there is no mention of it.
When my Kubota L3560 regenerates during operation it is when I have planned mowing or Disc Harrow work in anticipation. When mowing or discing my tractor operates at nearly full throttle and the engine and DPF are hot. In this scenario I doubt any supplemental diesel fuel is used to increase DPF temperature.
In woods work, the largest segment of my tractor work, the engine seldom operates at a wide throttle setting for more than three or four minutes at a time, which would be towing a Oak trunk free from clinging vines and underbrush in HST+ LOW/LOW and 4-WD, using the rear/center drawbar.
In driveway regeneration it takes 3 - 4 minutes with the throttle manually set at 2,200 rpm before the engine and DPF are hot enough to activate regeneration cycle, which shows with a readout on the L3560 Intelipanel. Once regeneration commences, the tractor takes control of the throttle. My interpretation is the additional fuel is used to increase the tractor rpm to 2,200 while parked. I may be wrong.
The gauge monitoring engine temperature does not move up during regeneration, dynamic nor static. This puzzles me. Perhaps this is due to the large volume of fluids in diesel tractors and transmissions acting as a heat sink, while the DPF replaces an engine muffler and is directly connected to the engine exhaust manifold. (??)
Regeneration may use fuel directly injected into the DPF in colder climates. I do not know.
/ Compact Tractor Diesel Particulate Filters (DPF) #18
200 regens or 3000 hrs.....3000 hrs would always hit first unless something did a regen every ~15 hrs? I put about 120 hrs/yr on mine so that's roughly 25 yrs - regen about 40 hrs, 3000 hrs expected life. Doesn't seem too awful looking at it that way.
I do wonder what would happen if the DPF was just replaced with a straight pipe. Not that I have any intention of doing so, just curious.
As to the exhaust location....mine is front lower left. Tractor speeds are generally so slow that direction of travel vs placement isn't so much the issue as wind speed and direction. To the rear would be nice, but then all those hot gases on an implement or muffler/pipes mounted too low under machine getting damaged. Seems the traditional straight up from the hood or front/side are best overall locations. Everything is a compromise...... Mine is generally far enough away I rarely notice it. My old JD BH was center of hood and I'd get stinging eyes from it at times. Bigger older tech engine so a lot more exhaust, but I don't ever get that with this placement. I get that burning paint smell from regen cycles that I notice, but in general seldom notice exhaust.
For most, replacing worn tractor tires will be a greater expense than DPF replacement.
/ Compact Tractor Diesel Particulate Filters (DPF) #20
What? I have to replace the tires too?
Sadly, I'll have to replace my rears probably WAY sooner than normal. When I first got it....maybe 10 hrs on machine....was ripping some virgin ground with box blade teeth fully lowered. That's how I found out my hydraulic toplink leaks down really fast. Box blade was up, toplink fully retracted, didn't think much of it. 30 min later realize the teeth are now in contact with tire lugs. Chewed out some real big chunks of the industrial treads. Just a matter of time until a screw, pointy rock, shoot, something finds one of those spots and pokes a hole.
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
2018 HINO SA (A58214)
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
