Buying Advice First tractor recommendations
/ First tractor recommendations #1
bboyette
Lacrosse, Alachua County, North Florida
N/A
After stalking posts on this forum for a while I figured I would finally make my first post with the hope of some advice from those more experieanced than I (Which will be most anyone on here).
I am located in North florida on 5 acres of flat mostly cleared land. There is a 1/2 long road/driveway from the hard road to my house which is mostly dirt with some limerock. I share this road with one neighbor and a cattle farm and it takes a beating throughout the year. The initial primary purpose of a tractor would be to fix and maintain the road and my driveway. Within the next year I hope to fence off 2-4 acres and turn it into pasture and would use the tractor to manage that as well as the assorted work and gardening. The land seems to be mostly rock free and there are only a few stumps I am working on removing. I would have to have a Box blade and would love to have a FEL and tiller.
There is a possibility I could acquire 10-21 acres of adjacent property (mostly pasture) if the right opportunity presents itself.
So I have had several questions:
1. whether I should purchase an older model tractor that I can probably do most of the work/repairs on myself (except hydraulics) for a few thousand bucks and just hope I dont get a lemon? Or fianace a new tractor for significantly more but would have more features and warranty? (Additionally most of the old tractors I find around here don't have FEL's which isn't a deal breaker but I would love to have one)
2. While I would like a 35-40 HP tractor, would something in the 25HP range get done what I need at a reduced price?
I have JD, Kubota, TYM, RK, dealers all within a short distance but I have had a negative experience at the JD place. I was leaning toward either the RK24 or RK37 or equivilent TYM if I decided to do new.
I have located a few Ford 3000's around me that may work out for the right price.
Ive only had one cup of coffee this AM so I hope some of this made sense. Thanks in advance for any advice.
/ First tractor recommendations #2
The most efficient way to shop for tractors is to define potential tractor applications first, then determine bare tractor weight necessary to safely accomplish your applications. Your primary application is road maintenance for which tractor and implement weight are key.
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Heavier tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range. I spreadsheet tractor and implement specs, often a revealing exercise. I have a column for cost per pound.
Most tractors under 3,000 pounds bare weight operate in residential or hobby farm applications on one to ten flat acres. Tractors under 3,000 pounds bare weight will enter a residential garage with an 84" header, with the tractor ROPS down.
I suggest buying a tractor with a bare tractor weight of at least 2,600 pounds and at least 12" of ground clearance. Tractors in this weight range are available with engine power outputs of 24-horsepower through 40-horsepower. Tractors in this weight range with <25-horsepower are exempt from costly Tier IV pollution control technology. In Kubota's line these are the models L2501, L3301 and L3901. All the same tractor. L2501 naturally aspirated engine, L3301 and L3901 sport turbocharged engines with more power output.
LINK: https://www.kubotausa.com/docs/default-source/brochure-sheets/l2501.pdf?sfvrsn=34e9b1d_8
When considering a tractor purchase, bare tractor weight first, tractor horsepower second and (narrowly) rear wheel ballast third.
(Usually, but sometimes not.)
/ First tractor recommendations #3
:welcome:
To the TBN forum. You have come to the right place as we love to spend other peoples money, :D
You will get a lot of differing opinions as to which tractor to buy.
No mater which tractor you finally decide on, go to the different dealers to drive as many different tractor as you can to get a feel for each one. This will help you to see the differences between each of them.
/ First tractor recommendations #4
TYM makes Rural King's tractors. Rural King claims to be developing a tractor service center in Williston, Levy County, Florida but this service operation may not be operational for several years.
Our most knowledgeable Ford tractor contributor, SOUNDGUY, ordered a new RK earlier in December.
A quality dealer, reasonably close, available for coaching, is important for tractor neophytes. Most new tractors are delivered with a glitch or two requiring correction. My kubota dealer is six miles away. I feel my local dealer continues to add value to my equipment after seven years. Dealer proximity is less important for those experienced with tractors and qualified to perform their own maintenance.
Tractors used in ag or forestry operations may be sales tax exempt. Speak with the dealers about ag exemption qualifications as you shop. Florida is one of the more liberal states with ag sales tax exemptions.
/ First tractor recommendations #5
For tasks I see: road maintenance (more weight is better), maybe mowing (more HP is better), soil preparation, some non specific dirt work, building fence, up to you to list others.
To me getting an older tractor is very much a personal choice.
If you love working on machines, then getting an older machine and doing your own work is of course fine. Just be sure you are ok with taking the time to work on it. If we are talking 10 years old or so, look for single owner, non-rental, low hours. Yes, these are often hard to find (think estate sales, craigslist, local ads). If older, just be ok with working on it!
The RK37 should be a good choice from a spec perspective, but they are relatively new to the market as a tractor brand. They have sold rebranded MF, maybe other in the past. My biggest concern is support longer term. They could be around for a long time, and they could decide to switch from TYM or stop selling tractors entirely. Only time will tell. Personally I am most concerned with dealer and parts support on these newer machines with all the electronics. I don't want a machine I cannot get parts for, or a dealer that is no t willing to work on a line of tractors they dont sell anymore. That said if this is not of concern to you, then go for it! I would just make sure the RK dealer is in fact a full service tractor repair center as well. Some Rural Kings sell tractors, but don't service them.
This size machine would give you room to grow, but not be big enough if you do stay at 5 acres. You could consider the Kubota L series, as these should be in the same range of price. Perhaps a few less HP on the Kubota to match pricing. L3301 or L2501? You really dont need the HP based on what you have described. A JD 3 series would be the equivalent there, but as you mentioned the negative experience...I am only suggesting as to not be partial to one brand. TYM builds the RK tractors.
/ First tractor recommendations #6
Welcome to the forum bboyette!
What’s the budget?
First off, thanks for the lightning fast responses.
While interested in the RK I am most definitely concerned that there may be problems with service and parts. The service staff in my local RK are very reassuring but talk is cheap.
The Kubota may be a safer choice if they can get close to the price.
For a cash tractor the best I can probably do is $6k. The main limiting factor here is the timeline. I will have to do something one way or the other by the first half of next year. The drive is really bad and has even been impassable to none 4x4 vehicles a few time since April.
Acquiring financing for a new one wont be a problem but I want to keep the price to around $15-20k or less than $300 a month.
I will definitely have to look into the weight for the various models.
/ First tractor recommendations #8
$20,000 enough for an L2501 with a Loader, especially if you qualify to purchase sales tax exempt.
/ First tractor recommendations #9
Buy used 20-25 hp as someone said graigs list estate sales. take someone with you that knows tractors.
In the distant future if you decided to buy a newer bigger tractor odds are you will make money on your purchase
and the experience gained will be worth more than your investment
Leave the new stuff for those that like keeping up with the Jones ;)
/ First tractor recommendations #11
I have an L2501 that I bought for road and forestry projects. I don't need the added PTO horsepower. I needed the frame size.
The PTO on the 2501 is only 19 horsepower in the geared model. Less in the HST model. Keep this in mind if your considering a 25 horse tractor.
/ First tractor recommendations #12
To me - L2501 has a lot of pros here
- decently sized for the possible application
- available finance options and insurance
- ease of resale if no longer needed
- support is amongst best in industry
JD 2 series or a Massey also worthy of consideration. Other brands new based on your local dealer support.
Used is a crapshoot. Since you’ll be without if something goes wrong with a “used” units - it’s probably better to finance new and keep the limited savings towards future expenses/payments.
New prices are inflated - someone’s paying for that 0 percent promo financing. That said used prices increasingly are inflated by the comparison price shopping of new. Yes, there are lots of great low hour - 5-8 year old units out there with no emissions controls....finding one for under 10k though is tough...your budget is half that range cash.
A new unit minimizes risk (insurance and warranty cover unexpected repairs) at an added cost. If you can absorb the cost long term, pass on risk. If your capable of regular maintenance yourself - you should be able to keep things clean and when/if the time comes to upgrade down the road..you’ll have a clean unit that will sell easily.
/ First tractor recommendations #13
Used is a crapshoot. Since you値l be without if something goes wrong with a ç*¥sed units - itç—´ probably better to finance new and keep the limited savings towards future expenses/payments.
New prices are inflated - someoneç—´ paying for that 0 percent promo financing. That said used prices increasingly are inflated by the comparison price shopping of new. Yes, there are lots of great low hour - 5-8 year old units out there with no emissions controls....finding one for under 10k though is tough...your budget is half that range cash.
A new unit minimizes risk (insurance and warranty cover unexpected repairs) at an added cost. If you can absorb the cost long term, pass on risk. If your capable of regular maintenance yourself - you should be able to keep things clean and when/if the time comes to upgrade down the road..you値l have a clean unit that will sell easily.
This touches pretty well on my own thoughts. I just spend my third weekend with my new L2501. Thoroughly enjoying it. There's a lot of choice out there. I wrote up a review on why I went with the L2501 here:
https://www.tractorbynet.com/forums...risons/405243-pulled-trigger-l2501-today.html Package.jpg20181216_160320.jpg
/ First tractor recommendations #14
I can't give advice on tractors but I think you found a fantastic resource in this forum. A lot of big brains here and very helpful. Good luck in your search.
/ First tractor recommendations #15
If you are serious about the additional land purchase I would definitely lean more toward something like the RK37. I have considered it myself, but it will be at least later next year before I buy anything new. The Ford 3000 is a solid tractor. I have a 3000 with a FEL and also a MF245 without. The biggest issue with FEL's on the Fords is that they really weren't built with a FEL in mind so if you find one pay attention to wear in the steering. Replacing a power steering box is very expensive on those tractors. The older loaders are not easily removed so you have to put up with it being in the way at times. The 3000 will do the things you need to do and won't depreciate much, if at all, before you buy it's replacement. Really, any of the Fords from the 600 series on up would be good choices for your use and there should be some really solid examples available. The Massey Fergusons are also really solid tractors so keep those on your radar. $4-6000 should buy a nice example of either one. Around here you can pick up a solid 600 or 800 series Ford or older MF for $2-4000. If you are looking to fill an immediate need and put off that new tractor purchase for a year or two that might be something worth considering.
New is nice, but there is obviously a cost associated with it. The biggest reason I am looking to buy something else is that I am mowing a lot of mountain land and a 4WD with ROPS would be a lot safer. The 2WD will mow a lot of it, but I have to be very careful about how wet things are.
/ First tractor recommendations #16
Seems like having a TYM dealer nearby would hedge some of the risk of buying RK
Thanks again for all of the great information.
I am looking very hard at the L2501 and have found several lightly used ones in the area at reasonable prices.
The RK24 is out after taking a look at the bare weight and ground clearance.
Rk37 is still possible but I will have to see how things are looking at the beginning of the year as this would cost a good bit more than the L2501.
Also still considering an older tractor but am now mostly leaning toward new/newer.
It will likely be January or February before I am able to pull the trigger either way.
While absolutely serious about the additional land purchase, it would require that the current owner to significantly reduce the price his is asking for as it seems extremely high.
/ First tractor recommendations #20
Why don't you ask the cattle farmer for advice? Presumably he knows the tractor dealers in the area and also what would be required to repair and maintain the road.
2023 KOMATSU PC490LC-11 EXCAVATOR (A65056)
2023 KOMATSU...
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
IRanch High-End Tricycle (A64119)
IRanch High-End...
2021 JCB 3TS-8T TELESKID (A65056)
2021 JCB 3TS-8T...
2012 INTERNATIONAL PROSTAR+ 122 6X4 ROAD TRACTOR (A65054)
2012 INTERNATIONAL...
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
