Tractor tire tubes
/ Tractor tire tubes #1
Wasmeneh
After a long search I located some turf tires and wheels for my Kubota B1750. One if the rears, a 29 X 12.50 - 15 turf, has a leak around the rim. The tire is loaded with Calcium/ water. I need to find the right tube for it but so far no luck. Any ideas, I've looked at Ebay and Amazon, and can't find anything online from Tractor Supply. My local sources are few with only Tractor Supply within 30 miles.
Thanks in advance
Mike
/ Tractor tire tubes #3
Thanks in advance
Mike
Where do you live? West of the Rockies there is a tire chain name of Les Schwab. They have or will get you anything you need in tires/tubes. Great family owned Co. Some tire companies cater to the farm community.
Ron
Found a local tire place that has been around for ever had a tube that would fit. Getting them done as we speak. Just found it odd that I couldn't find a tube online.
Thanks for the replies.
Mike
/ Tractor tire tubes #5
Yes - here in Cheney, WA (Amber, WA also) the go to place for tires/tubes, etc is Les Schwab. If they can't get a tube - there is most likely nothing available.
/ Tractor tire tubes #6
I tried to do business with the local Schwabs this last summer for a pair of 7:50-16's They were a 100% more than on line, even with shipping, AAnnd Schwabs said they'd be over two weeks out for ordering. Shwabs won't be seeing any more of me!
/ Tractor tire tubes #7
Not bashing here, just facts, I have very poor luck with TSC small tires. You can check for yourself country of origin.
Would large tires of the sort have the same problems????? No idea. My local has a tire for every application shop gets his tubes from Korea and I am not having any problems with them.
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
Challenger 425B/445B/455B Tractor Service Manuals (A63117)
Challenger...
2007 Genie AWP-30S 30ft Manlift (A61572)
2007 Genie AWP-30S...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
