Welding Table?
/ Welding Table? #41
Pretty tables. The table isnt that useful without all the clamps, pins, and tooling made for the holes. I have never found that type or the platen type with the square holes to be that useful. A mag drill can easily add a couple of holes to your diy table if you need them some day. Carr Lane and McMaster sell the pins with the shoulder also.
Some jobs are best done on a couple of beams or sawhorses anyway. Make all your tables the same height and move them around in clusters for long or oversized jobs.
/ Welding Table? #42
I have scored some excellent local deals by meeting or befriending owners and shop foremen at charity or enthusiest groups. Even traded beer and bbq for capabilities I dont have.
Tab and slot is common. There are more than a dozen waterjet or lasers within 50 miles of my door.
/ Welding Table? #43
Drops around here are $.0.35 to $0.40 per lbs.
Two things about this thread that jumps out to me.
A welding table is made from steel. You are going to be welding steel.
Weld up your own table.
Your metal supplier is x miles to far away for you to go get the metal.
Where are you going to get the metal for your welding jobs?
/ Welding Table? #44
Those are about the same prices I see here for the scraps/drops/recyclables/leftover stuff too small to make what they normally make (whatever you want to call them).
OP's table site says the table he wants is 84lbs. At $.40/lbs that's $33.60 in material.
I personally look at those tables and the supplied videos and I see something that is geared for someone looking to spend a lot of money to start a new hobby and the assembly of the table would be their very first "project".
Sadly, it really isn't a good introduction to welding since most things you build or put together are not going to have all the assembly tabs to make it all fool proof. The company simply does these tabs to cover their own arses because they know they are marketing to people entering the hobby field.
I think the company marketing them simply purchased a big laser cutter for specific purposes, but with their purposes it left the machine with a lot of downtime, so they decided to create something for market (likely out of their own scraps) to decrease the downtime of their laser.
The software they use on some of those laser cutters allows someone good with the system to set down and design anything they can imagine, in very little time. After they design it, the software will automatically layout all the pieces so there is as little scrap left over as possible. A box with a grid of holes would literally be 5 minutes of work for a skilled operator to layout. The machine wouldn't take much longer to cut the parts for a small table like OP is looking for. Paying them $120 for an hour of their time, $33.60 for the materials; I think all parties would leave pleased with themselves.
/ Welding Table?
Most of my welding projects come from odd accumulations of scrap....
Dale
/ Welding Table? #46
Dale
Most of my projects never need anything large. I go to the local metal recyclers for a lot of what I need. I have four places within 30 minutes. They typically pay between $0.01 and $0.03 per pound for steel, I pay them double and can typically find what I need for less than $5.
/ Welding Table? #47
I think you are quite optimistic in figuring 40cents/lb for the material required to make the table and also the finished weight is going to be quite bit less than the raw material required.
You say the CNC PC will auto layout the pieces... but you are also figuring on gathering drops to make this part. How are you going to lay out the drops??? :confused3: One hour labor... I don't think so for a one off assembly.
/ Welding Table? #48
I never have bench space in my shop so I keep a welded together, lightweight, cut down to working height, section of racking, in behind the shop. Probably weighs 40# and I carry it by getting inside and holding each side, probably 36" X 72". I just throw on a plank or plywood to suit the job.
/ Welding Table? #49
I keep a section of pallet racking set up same as you. It will accept a 4x8 sheet of plywood. Handy for temporary benches or work surfaces.
/ Welding Table? #50
I think mine is a bit lighter, but will still carry probably a thousand pounds. It looks a tad wonky in the picture, but it's not. The trick is the welded joints. I drag it out for painting quite a bit.
I have this heavier clamp table from a furniture factory, used here to assemble a hot water solar collector. I welded stake pockets to it, but the other frame is much handier.
BIG BARN, Interested in parting with a vice? My lady friend just bought a house, and was happy the owner had left a vice on the work bench. On closing day, it was gone! Now I need to find a vice and yours seems like a dandy!
2023 GMC 1500 Seirra Elevation Crew Cab 4X4 Pick-up Truck (A60352)
2023 GMC 1500...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
iDrive TDS-2010H...
2014 Timpte Hopper Bottom (A61307)
2014 Timpte Hopper...
