Anti Splatter Fluid...
/ Anti Splatter Fluid... #11
You shouldn't have a "lot" of dross under your sheets. Are you using air cooled plasma?
Yes a Hypertherm 85. Most of it is on the tight corners/fine detail.
/ Anti Splatter Fluid... #12
Gotcha. Yeah without hole optimization dross is going to be a problem. Air cooled compounds it too. ( my interest is from being a long time Plasma / Robot Automation guy )
/ Anti Splatter Fluid... #13
Curious about the WD40. If you spray it on your work, It keeps the spatter beads from sticking? Or are you using it on your nozzles?
It works on the surface and nozzle.
I always clean anything I cut/weld with mineral spirits before I paint it anyway.
/ Anti Splatter Fluid... #15
Unflavored PAM. I know. But it is cheep and it works.
I went even cheaper than that. I got a bottle of Kroger's version of Pam, and it works just fine. Not a trace of splatter on the work. :)
/ Anti Splatter Fluid... #17
I like the Bio Circle product on the left which I get from my LWS. It’s nice that it is NON aerosol and at the time it was the same price as a can of PAM from Costco.
The real upside is I can avoid the temptation of a cheap hot dog. after my purchase. :)
and enjoy a BETTER one at home....
/ Anti Splatter Fluid... #18
Re: Anti Spatter Fluid...
Did you use the Bio Circle on your hot dog?
Mahindra 6065PST (A53317)
Mahindra 6065PST...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 Heil Heavy Duty Aluminum Tank Trailer (A61307)
2007 Heil Heavy...
2022 Kubota M5-111 (A60462)
2022 Kubota M5-111...
