Forks Unusual pallet forks
/ Unusual pallet forks #1
rsl360
Cape Cod, MA
electrak e12, e15, e20, Terramite T9 4WD
I just bought a used pallet fork attachment. It's old, it's beat up, but it's fine for what I need. However, it has a feature(?) that I've never seen before, and have not been able to find any examples of. Google has failed me on this one. Basically, it's got an upper and lower set of attachment points for the forks. I cannot imagine what you would ever use the upper ones for, other that it has about 1' more reach. Any ideas? See picture. (and please don't tell me that I have the forks on the wrong way. :) )
/ Unusual pallet forks #2
You will have a bit more height if you need to place something at the end of the FEL upper reach. Also, maybe the are the right height for some type of pallet, where if you float the FEL that height allows you to go straight into the pallet at the correct height? Just guessing here.
/ Unusual pallet forks #3
Home made solution for a low lift tractor loader. Probably couldn’t lift stacked pallets off the back of a tractor trailer.
/ Unusual pallet forks #4
Sometime you just need a little more lift height.
Over 30 years ago I ran spotlight crew for rock concerts that came to local colleges. One show (BOC?) we had to turn the fork truck blades over because they wanted taller staging. I got to ride the forks up to max height to steady the lamp heads and pass it to guys on the staging.
Home made solution for a low lift tractor loader. Probably couldn稚 lift stacked pallets off the back of a tractor trailer.
I'd agree, if it was homemade. But it's not, nor has it been modified. It may be old and beat, but what's left of the paint matches everywhere, the welding is consistent, and there is a label on the back for the loads. Clearly a factory label, but no brand information.
/ Unusual pallet forks #6
Perhaps it was setup for moving cinderblocks where the fork pockets are partway up the stack?
Aaron Z
/ Unusual pallet forks #7
One high fork and one low fork may be useful in the field for putting pallets in a /\ without getting off the tractor.
Bruce
/ Unusual pallet forks #8
I would say it’s probably designed for use with two different sizes of forks. They aren’t all the same.
/ Unusual pallet forks #9
Bruce
That is where you need a rollover head for the forklift :D
Could be, I have seen the rails anywhere from 8" to 24" apart.
Aaron Z
/ Unusual pallet forks #10
This. There are different classes of forks, the rails are different widths depending on the class.
Hmmm. OK, best idea so far. I measured it, and I can put 16" forks in the lower position, 16" forks in the upper position, and 23-5/8" forks in the top-to-bottom combo. But none of these ideas account for the lower fork rail in the middle of the frame. Any forks using that position will be about 8" off of the ground.
/ Unusual pallet forks #12
Im leaning towards the cement block idea, for the upper set of 16" rails, and lower rails for standard skids.
/ Unusual pallet forks #13
Looking, there are 4 standard spacings:
https://store.intellaliftparts.com/c/forklift-terminology.html said:
Carriage (Forklift Carriage)
There are four sizes of forklift carriages available: Class 1, Class 2, Class 3, and Class 4.
Class 1 Carriage: Can hold loads of up to 2,000 lbs. Carriage bar spacing is 13 inches.
Class 2 Carriage: Can hold loads of up to 5,500 lbs. Carriage bar spacing is 16 inches.
Class 3 Carriage: Can hold loads of up to 10,000 lbs. Carriage bar spacing is 20 inches.
Class 4 Carriage: Can hold loads of up to 15,500 lbs. Carriage bar spacing is 25 inches.
Probably 2 positions for Class 2 forks.
Aaron Z
2019 John Deere 835R Gator (A63116)
2019 John Deere...
KBH Tank Trailer (A63118)
KBH Tank Trailer...
2023 John Deere 9RX 640 Track Tractor (A63109)
2023 John Deere...
KBH 1600 Gallon Water Trailer (A64047)
KBH 1600 Gallon...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63118)
Magnolia Trailer...
2005 KENWORTH T800 T/A 6X4 DAY CAB TRUCK TRACTOR (A59911)
2005 KENWORTH T800...
