Forks Unusual pallet forks
   / Unusual pallet forks #1
rsl360
Cape Cod, MA
electrak e12, e15, e20, Terramite T9 4WD
I just bought a used pallet fork attachment. It's old, it's beat up, but it's fine for what I need. However, it has a feature(?) that I've never seen before, and have not been able to find any examples of. Google has failed me on this one. Basically, it's got an upper and lower set of attachment points for the forks. I cannot imagine what you would ever use the upper ones for, other that it has about 1' more reach. Any ideas? See picture. (and please don't tell me that I have the forks on the wrong way. :) )
   / Unusual pallet forks #2
You will have a bit more height if you need to place something at the end of the FEL upper reach. Also, maybe the are the right height for some type of pallet, where if you float the FEL that height allows you to go straight into the pallet at the correct height? Just guessing here.
   / Unusual pallet forks #3
Home made solution for a low lift tractor loader. Probably couldn’t lift stacked pallets off the back of a tractor trailer.
   / Unusual pallet forks #4
Sometime you just need a little more lift height.
Over 30 years ago I ran spotlight crew for rock concerts that came to local colleges. One show (BOC?) we had to turn the fork truck blades over because they wanted taller staging. I got to ride the forks up to max height to steady the lamp heads and pass it to guys on the staging.
Home made solution for a low lift tractor loader. Probably couldn稚 lift stacked pallets off the back of a tractor trailer.
I'd agree, if it was homemade. But it's not, nor has it been modified. It may be old and beat, but what's left of the paint matches everywhere, the welding is consistent, and there is a label on the back for the loads. Clearly a factory label, but no brand information.
   / Unusual pallet forks #6
Perhaps it was setup for moving cinderblocks where the fork pockets are partway up the stack?
Aaron Z
   / Unusual pallet forks #7
One high fork and one low fork may be useful in the field for putting pallets in a /\ without getting off the tractor.
Bruce
   / Unusual pallet forks #8
I would say it’s probably designed for use with two different sizes of forks. They aren’t all the same.
   / Unusual pallet forks #9
Bruce
That is where you need a rollover head for the forklift :D
Could be, I have seen the rails anywhere from 8" to 24" apart.
Aaron Z
   / Unusual pallet forks #10
This. There are different classes of forks, the rails are different widths depending on the class.
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A53421)
2025 GIYI VR66...
Miles exempt on title. Year: 2019 Make: Ford Model: F-550 Vehicle Type: Truck Mileage: 170889 (A55852)
Miles exempt on...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A53422)
2007 Ford F-150...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
CATBKTSSL_78 (A55787)
