JEEP GARDEN TRACTOR PROJECT
/ JEEP GARDEN TRACTOR PROJECT
Yes it was a Wheel Horse 10hp riding mower. The mower was junk and I bought it for $85.00 . I puttered on the motor one afternoon and got it running great. I put big tires on it and eventually made the grader, ha,ha. Today I trimmed a bunch of sheet metal from the inside of the Wheel Horse Go- Cart. I fabricated all new frame work to support the two high back seats. Going to be a tight fit and I already trimmed a inch off the sides of the first seat. I also built the mounting brackets for the bottom of the seats. IMG_9474.JPGIMG_9475.JPGIMG_9476.JPG
I got the new seat frame work welded in place and got the seats mounted for the first time. It's a tight fit but I like them. I decided this week to work on the Mini Loader bucket. I am adding 16" to the bottom of the bucket and several inches to the sides. We get a lot of light fluffy lake effect snow and it would be nice to be able to move more of it each pass. I saw this cool bucket on line today , Sweet. IMG_9491.JPGj.jpg
Taking a break from the Mini Jeep project to work on the mini loader bucket extensions. I'm trying to keep it light as possible. I don't actually plow with it , mostly move the snow piles from the front to the back yard when the snowbanks get too high. I am very limited where to stack the snow in front. We get 160+ of snow every winter so the banks get high and it is dangerous pulling out on the main road. The bucket looks rough yeat but will look much better when finished.IMG_9494.JPG
/ JEEP GARDEN TRACTOR PROJECT #64
Taking a break from the Mini Jeep project to work on the mini loader bucket extensions. I'm trying to keep it light as possible. I don't actually plow with it , mostly move the snow piles from the front to the back yard when the snowbanks get too high. I am very limited where to stack the snow in front. We get 160+ of snow every winter so the banks get high and it is dangerous pulling out on the main road. The bucket looks rough yeat but will look much better when finished.View attachment 577099
Is this just going to be a removable extension for the bucket or are you welding it on?
The new extension will be welded on. I have forks for it for summer use. This bucket is 100% snow use and mostly lake effect snow that is light and fluffy. I have used the smaller bucket for 7 years and it is going to be great to have this larger bucket. I will be curious if I will be able to carry a full bucket of heavy wet snow without lifting the rear of the machine .
If not it will still be nicer filling the bucket with the larger bottom floor even half or 3/4 full .
/ JEEP GARDEN TRACTOR PROJECT #66
Thought you should know that when you click on your YouTube videos link it does not work. It simply says that the channel does not exist.
Snowing the last two days so back in the workshop. I cut out more of the center tunnel today and now I have plenty of leg room . But the drive belt shield will stay leaving a little less leg room on the passengers side. I finished the bucket extension project and I am excited to try it out.IMG_9521.JPG
This progress photo today shows the brake and clutch pedals now moved in the new spots. Also new sheet metal for more leg room. I added 3 fake shifting levers just for looks. The two real shift levers are between the seats. I ordered a 17" steering wheel to help with the manual steering . Next I will work on the passenger side adding new sheet metal.IMG_9531.JPG
My new 17" steering wheel arrived today and that should give me more steering leverage. But if it still steers hard I may get a Vega style steering box like the hot rod guys use. I trimmed the Wheelhorse dash and attached it to the new dash panel. I also attached most of the wiring left over on the side . That will get a cover to enclose all that.IMG_9539.JPGIMG_9538.JPGIMG_9534.PNG
I got the new steering wheel attached today after building two support brackets for two upper shaft bearings. Very comfortable sitting in the drivers seat.IMG_9546.JPGIMG_9545.JPG
Time to pull off the front wheels today and remove the spindles. I attached the new thrust bearings and also fabricated a new tie rod. Tomorrow I will locate the gear box location and build mounting brackets close to the center of the frame. This is all trial and error but hopefully it will work. It's always fun to use parts in the shop that have sat around for many years.
Steering design FAILED !!! This afternoon I got everything connected together for the first time and it did not work smooth at all. Too many u-joints and too tight of angles. So I started cutting out metal from the frame and tomorrow will start over. This time the geag box will be in direct alignment with the steering wheel. This will eliminate most of the u-joints and angles. I still think it will all work. But if not , then I will order the Vega parts. It's always more fun to make things work without having to spend a bunch of money.IMG_9555.JPG
The steering gear box is now mounted in the new location in line with the steering wheel. When turning left the big tires rub on the tie rod. Friday I will finish building a bell crank and mount it in the center below the frame. Then the tie rods can connect to it for plenty of clearance.IMG_9560.JPG
I decided to hold off on the bell crank design and just put two kinks in the tie rod . I also welded more 1/4" bracing around the steering gear box. Next I will cut away more of the old grader frame and weld in new metal from the radiator to the cowl . This will give the fenders much more support and the new battery box and fuel tank support will have more to attach too in the front.
/ JEEP GARDEN TRACTOR PROJECT #77
And this is why I subscribe to your projects. You document everything, including the learning opportunities. This is valuable stuff; much better than the "hey, look what I can do" posts & videos that make it seem like everything went exactly according to plan.
Thanks , I know my projects are rough around the edges but I love puttering . Sharing them is fun because I know there are so many people who love to putter just as much as I do. And I try to do it at minimum cost with parts I have around the shop. My tools are basic , no milling machine or lathe . It's nice when someone takes a idea of mine and tweaks it to there own project.IMG_9567.JPG
The new battery box is built and attached along with the battery. The new gas tank brackets are also installed along with the tank. You can see the vertical mounted muffler mounted behind the right side fender. And yesterday I mounted the choke and throttle cables on the dash for the first time. Now back to the wiring to see if I can get it running . It has been a excellent running little engine.IMG_9573.JPGIMG_9572.JPGIMG_9571(1).JPG
/ JEEP GARDEN TRACTOR PROJECT #80
Waldon - its guys like you that elevate the rest of the group. No kidding, I re-built my loader mounted snow plow as if I was presenting it here on TBN. Not only is it functional, but it looks good too. I attribute my new found attention to detail and quality, to the high caliber fabricators like you on this site.
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
2012 Ford E-350 16ft. Box Truck (A64556)
2012 Ford E-350...
17601CFL (A61572)
17601CFL (A61572)
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
