Bucket Hooks
/ Bucket Hooks #21
I needed a good chain connection on the tines of my log grapple. I was going to just drill a couple 3/4" holes and use a shackle. I didn't know what the steel was but when I tried to drill an 1/8" pilot hole with a hand drill and a good bit I found out it was Kryptonite. A definite no-go with a hand drill - for me at least. Thought about burning a hole but my torch work is a little crude for a 34" hole. So I made a couple 1/2" weld lugs instead.
Now I have a slip connections with just the shackles or I can add a grab links big enough to pass a hook thru to get a grab connection.
gg
NICE, gg
/ Bucket Hooks
I needed a good chain connection on the tines of my log grapple. I was going to just drill a couple 3/4" holes and use a shackle. I didn't know what the steel was but when I tried to drill an 1/8" pilot hole with a hand drill and a good bit I found out it was Kryptonite. A definite no-go with a hand drill - for me at least. Thought about burning a hole but my torch work is a little crude for a 3/4" hole. So I made a couple 1/2" weld lugs instead.
gg
Looks interesting, what is source for slip connectors (the red ones)?
Dale
/ Bucket Hooks #24
Thanks Terry !
Yes - there you go DL. I get them at a real hardware store in St J called Dad's that we are lucky to have. You can get them at BaileysOnLine in CA too or any logging supply place. Look under Grab Link like you did or Main Line Slider Assemblies. The 3/8" size is good for 5/16" chain like I use too.
gg
/ Bucket Hooks #25
I've been using slotted angle since back in '02 when we bought the B7500. When we replaced that with the L3200 ten years later, I made another set. Today I was doing some cleanup and getting the tractors ready for Winter.
The Ford still had a 5' RFM on it. I removed that to put the York rake on to gather some flood debris down by the creek. Then the York rake came off and the 6' rear blade went on.
The Kubota had the bigger rear blade hastily installed when the first snow of the season hit before Thanksgiving. That had to come off so I could put the 6' RFM back on to grind up some leaves. Then the RFM came off and was put in storage and the rear snow blower was installed.
The point of that long-winded recap is that I moved a bunch of things around this afternoon. A nice addition was a pair of 1/4" GR70 chains (bought a 16-footer and made two 8's). These are plenty strong and much nicer to handle than my long 3/8" chains. The slotted angle reduced the number of times I had to get in and out of the cab. I parked with the bucket over the implement that was to be moved, and connected it up. Picked the implement and took it to where I wanted it and set it down. Then lower and dump the bucket and back away and leave the chains on that implement while I went and parked at the next one. Hop out and retrieve the chains, take them to where the tractor was waiting, and hook up.
I snapped a couple pics of the heaviest load today (and it was also rigged with the most strain on the chains and slotted angles). That was the 6' RFM. With it hanging way out front like that, it was easy to drive right into the shed and slip it under a shelf till Spring.
/ Bucket Hooks #26
Looks good, chim! I will need to remember the slotted angle 'trick'. Sure seems it would give you more hooking scheme flexibility than the two hooks I have on my bucket.
/ Bucket Hooks #27
I like the slot idea also. Here is another way to locate/attach hooks. I have them low so I can run a chain ACROSS the bucket and hold stuff in the bucket. I also have a made up bridle with a center pull if I need it.
/ Bucket Hooks #28
Lot's of great ideas & executions here! I also like the angle/slot method, chim's looks really handy. Been debating what to put on my BX, leaning heavily towards something like chim's. Thanks for all the info & pix gentlemen!
/ Bucket Hooks #29
The left picture below is the original install on the B7500 and there were only 5 slots total. There were times that I could have used more slots - especially at the ends. The additional slots in the angles used on the L3200 provide a lot more flexibility.
I'm sure that these pics of the brush forks on the L3200 have been posted before, but they may be of interest to some newer people. The front edge of the bucket slips into the attachment, and an old ratchet binder with a chain bridle is what holds them on. The two chains and two tabs where the forks meet the bucket were added this year to make the forks self-install by dropping them in slots and curling the bucket. Prior to that, I had to lift the (rather heavy) fork assembly and set it on the slightly raised and curled bucket. At 69, I'm putting more thought into making things easier:)
/ Bucket Hooks #30
Thanks chim, I like the way you think! Do you have a background in fabrication? Also, what are the dimensions of the (newest) angle you used? Nice touch with the square holes for carriage bolts!
/ Bucket Hooks
One thing I noticed on my install was I put slot bracket right over where welded supports for bucket attachment to lift arms/hydraulics, my thinking was for strong point on bucket... I also notice when operating the other day I had a hook dangling on back side of bucket, and at full curl IT WAS AWFULLY CLOSE TO HYDRAULIC FITTING on ram for curl/dump of bucket.... Close enough if the hook was cocked just right it could actually shear off hydraulic fitting... Maybe pictures if rain stops..
Would suggest caution in placing brackets and relation ship of chain to any hydraulics close to chain slots...
Dale
/ Bucket Hooks #32
Dale
Good points, Dale...will definitely pay close attention to layout & component location. Since the BX has a single cylinder for the bucket, things are a bit cleaner behind the bucket.
/ Bucket Hooks #33
Thank you. I have no formal training outside of electrical, but have always enjoyed tinkering.
The angle is 4x4x1/4. It is a full 4" on the vertical and the horizontal leg is trimmed off at the bend of the bucket.
Hate to disappoint you on the bolts. They're rib neck bolts and not square. These are easily set with a hammer after drilling a plain round hole.
Here's a shot from today hauling a tree branch that was stuck in our creek.
/ Bucket Hooks #34
Awesome, thanks! Still looks nice & green up there in PA. We've been covered in light snow & ice all week, but rain moving in for the weekend should fix that.
/ Bucket Hooks #35
/ Bucket Hooks #36
gg
Nice weld job with your Everlast stick machine. 125 amps... hm... 7018 I assume?
/ Bucket Hooks #38
Everyone needs and loves bucket hooks. I've had this tractor a couple years now. The guy I bought it from had just one bucket hook. It is in the center. A little hard to use for a lot of things so I finally put hooks on the ends. After I welded the first one on backwards (Duh - I have an excuse but it is pretty lame.) I decided to just go with it and put a second one backwards in case I ever want to hang chains off the back of the bucket. So I ended up with a reverse pair and a forward pair of hooks plus a pair of lugs for a 1/2" shackle. The first chance I get I will use the backwards hooks just to make me feel better.
gg
/ Bucket Hooks #39
I just cut one eye off some 3/8" HF hooks and welded them on. They look just like the ones that were already on my backhoe loader.
/ Bucket Hooks #40
Provided your bucket is sturdy enough, a hook in the center makes the most sense in many cases. If I were to lift something heavy, I would link a chain between two hooks anyway to get a central lift or pull for that matter.
2016 Ford Taurus Sedan (A61574)
2016 Ford Taurus...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
