sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 15,858
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Looking at the original pics in post 517 and enlarging them, it looks like attempts to remove it didn't have a good "bite" on the plug. You can even see where it looks like the wrench was mis-positioned and caught the edge of the drain pan. This would be typical of an awkward position and limited access. But it leaves me with some thoughts and speculations.
I'll bet not a lot of torque has been applied and that the right tool properly positioned by someone who has done this before might be successful. I'll bet a BIG pipe wrench would fit in there and take limited effort for just the small turn to break it free. Then use a smaller wrench. I do these things with a 30" or 36" pipe wrench and never been defeated.
A different way that's more work would be to find a large nut that would fit over the square end of the plug and then weld in place. There probably is enough room to get a mig wire in to weld there and that's worth a thought. Clean the end of the plug first for good contact.
Another way to use that nut would be to first drill some cross holes sideways in the nut. Sine it would be fairly big nut, I'll bet 3/8" holes would work. Then, if you can't weld the end of the nut, weld in the holes to the pan plug. Maybe weld the end too if access permits. You would still have the same access after this so no change in approach afterwards.
Just some thoughts.
Just some thoughts.
