Tractors and wood! Show your pics
/ Tractors and wood! Show your pics #6,681
Wow, lots of good ideas, guys. I was just going to use a big carpenter’s triangle, keeping it level, and sighting along the 45 degree hypotenuse. Will try these other techniques as well
/ Tractors and wood! Show your pics #6,683
OK, you got me. What's the "inverted pan of water" used for?
When u was in the boy scouts, the handbook references a trick to guage the height of a tree.
1. Place a pan of water on ground away from a tree approx the distance you think it is tall. So you guess the tree is 40 feet tall, then place pan 40 feet away from tree.
2. If you are say 6 feet tall, then you stand 6 feet away from the pan of water on the opposite side of tree. So pan is between you & tree in a straight line.
3. Look into pan & the reflection will be 40 feet in air, so if you see top of tree, then tree is in fact 40 feet tall. If you see below top, then move pan back & reset. If you see over tree, then move closer to tree & reset. Once you find sweet spot, measure distance from pan to tree, that is the height of tree.
Now as you stated, this is hard to be accurate with this method, technically it's not your actual height, it's where your eyes are off ground, so 2-3 inch error here could result in being off true height of tree by feet. If it cloudy, this is useless, if the sun is directly behind the tree, you are now blind. If it's breezy, then the pan could have ripples so you can't see anything in the reflection, ground needs to be level etc... I think it was more of a lesson to try new things, maybe get us kids to think outside the box. Either way, it stuck with me for over 30 years. Still not something I'm willing to try anywhere near mine or your house. Nor do I recommend anyone to try it near theirs.
THat's quite an interesting technique. I've never heard of it, and I don't think it's a regular scout thing today (at least they never showed my son that technique).
/ Tractors and wood! Show your pics #6,686
If that's an 8' wall next to that tree, I'm going to estimate it at about 72' tall.
/ Tractors and wood! Show your pics #6,687
Along with some "other" jobs, I got these taken care of today,
Anyone wanna guess what kind of log, the long one is??
SR
/ Tractors and wood! Show your pics #6,693
SR
I never heard of Sourwood before so I'll guess Ash, if you could put the top back on with the leaves I'd have a better guess. What did you do with the log by taken care of it?
/ Tractors and wood! Show your pics #6,694
SR
Wood looks to dark for ash or popple but it was cut a while back. Walnut seems a better guess but I am not familiar with it or sassafrass or sour wood. So I will say I don't know.
gg
/ Tractors and wood! Show your pics #6,695
A fresh cut of the butt would help but I’m guessing sassafras or walnut.
/ Tractors and wood! Show your pics #6,696
hickory, ash, or a slight chance that it's butternut.
/ Tractors and wood! Show your pics #6,697
Wanted to get some slabs in so when I hooked on my trailer a small tab broke off that locks the pin in that lock the hitch in position, dont know where that piece went so I cut another piece out of old truck spring, another two hr delay. Once the hitch is locked in straight I can run a 1/2" case harden bolt through for heavy loads, the load must of caught on something a I suppose after ten years of use, metal/weld fatigue set in, bout like I get at times....
View attachment 577485 View attachment 577484
Now I get to load the slabs just before dark, so now they'll be ready to cut next weekend........
View attachment 577492 View attachment 577493 View attachment 577494
View attachment 577495 View attachment 577496
How do you weld the leaf spring so neatly to the softer metal? I once tried to make an ice chisel using a piece of leaf spring for the blade , but ended up with some very ugly bubble gum welds that stuck about as well as recycled duct tape.
Wow, lots of good ideas, guys. I was just going to use a big carpenterç—´ triangle, keeping it level, and sighting along the 45 degree hypotenuse. Will try these other techniques as well
You also can do a variation of MossRoad's method using a yardstick instead of your hand. (I use a clinometer.)
/ Tractors and wood! Show your pics #6,698
...or a slight chance that it's butternut...
Butternut...AKA 'White Walnut'...
/ Tractors and wood! Show your pics #6,699
I asked a couple co-workers who were Eagle scouts, the younger left about 2001. He vaguely remembers the technique, but never actually tried it. The other guy never heard of it. They both were taught the thumb method MossRoad mentioned.
/ Tractors and wood! Show your pics #6,700
sassafras
AND THE WINNER IS...??? Sassafras...
I couldn't have guessed it, as I've not seen a Sas that big before, although my brother got a nice one a few years ago, (that I never got to see) so they are around.
I "took care of it", by getting it cut into two logs the size I wanted and staged to, (at some point) to go on the BSM.
SR
Tree Boom Skid Steer Attachment (A61567)
Tree Boom Skid...
2014 CATERPILLAR 320EL RR EXCAVATOR (A62129)
2014 CATERPILLAR...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
