Wilco
I believe in Conn you need to be a licensed Plumber or LP installer to install LP gas piping. You'll needs permits pulled for both the piping and the LP Tank. The town plumbing inspector and Fire dept. will inspect the job and sign off on the permits. No gas company will fill your tank without proper permits. I'll assume you are purchasing a 100gallon tank not a 100lbr...??...Purchase a ASME tank as they do not have to be re-certified. This is how Mass does it and I'm almost positive its the same in Conn.
