Ballast To load or not to load. That is the question.
/ To load or not to load. That is the question. #61
Tractor shop I use has say a 5 gallon tank you unscrew the lid, fill you antifreeze in it, replace the lid and then use air pressure to push the antifreeze in the tire. I bought the anti freeze there and they loan me the tank. Even told me how much needed for the size of my tire. Then top fill the water.
If your TSC does not have the valve which I am 99% sure they do go to NAPA and they do.
/ To load or not to load. That is the question. #62
Thanks KT
Pretty sure with the SKU number TSC can get me one. I do have a NAPA just 15 minutes away though.
/ To load or not to load. That is the question. #63
/ To load or not to load. That is the question. #64
Had tires loaded this week, he said it was beat juice but mixed with something so it doesn't get to thick in the colder weather. He called it agralime or something? I'm pretty sure they are using vodka to thin it down.
This added somewhere between 800 to 900 lbs:)
While doing this I flipped the rims and gained probably 8 to 10" in width. I didn't measure before but I really like the extra width.
Welded on some pipe nipples for valve stem protection, I'll paint it when things warm and dry up some, next June probably.
IMG_20161201_154701.jpgIMG_20161201_154717.jpgIMG_20161201_165041.jpgIMG_20161201_165124.jpg
/ To load or not to load. That is the question. #65
View attachment 490211View attachment 490212View attachment 490213View attachment 490214
Well, unless it gets to below -35* F, you wouldn't have to worry about freezing. My guess would be that it is easier and cheaper for them to fill with a diluted mixture.
/ To load or not to load. That is the question. #66
Its always interesting to note that no one ever talks about the sloshing, waterbed like feeling and the definite increased compacting that occurs. The sloshing forward and backward needs to be paid attention to.
That said, my tires are filled. I decided that stability on the slants and tilts and hills, was more important than the occasional unfortunate tracks I may leave in my wake.
/ To load or not to load. That is the question. #67
We have never talked about the sloshing waterbed like feeling, because we have never heard nor felt any such thing.
/ To load or not to load. That is the question. #68
Since sloshing has been mentioned...Is it wise to always fill rear tires to the valve stem or do some choose to only 50% fill their tires.
I am about to load mine before winter. The tire shop strongly advises filling to the top.
/ To load or not to load. That is the question. #69
Sometimes I can hear fuel sloshing in the fuel tank when I park the tractor ( my truck does it worse ). Aside from that it’s a solution looking for a problem.
/ To load or not to load. That is the question. #70
Have never had a sloshing sound, feeling or problem with the Rimguard in my rears.
/ To load or not to load. That is the question. #71
We always fill to the valve stem. That will be approximately 75% of the total volume.
/ To load or not to load. That is the question. #72
Really? Drive forward at moderate speed, STOP. Unless your tires are 100% filled that water is gonna move. It does the same thing as you traverse uneven terrain. Is it huge? No. But it occurs.
/ To load or not to load. That is the question. #73
Never noticed it.
/ To load or not to load. That is the question. #74
I will fully loaded the tires tomorrow. Around here (Canada) RV antifreeze is $4 per US gallon so for my tire size that is $200/tire plus installation. Still, it sounds like the safest thing to do, especially for a rookie.
/ To load or not to load. That is the question. #75
Yes, it occurs. But it should be in a proportion that is almost just theoretical in nature unless the tire has a rather low fill ratio. It seems you would need highly inflated underfilled turfs running on concrete to notice it.
At normal 75-80% fill the fluid actually begins to flow around the tire and the slosh when stopping is nearly balanced - - effectively, an extremely small oscillating mass in proportion to that of the tractor, and with the inherent rolling friction acting as a damper.​
/ To load or not to load. That is the question. #76
Howdy, Yes getting a heater and a big cheater bar for the filter wrenches. The CK35 took 2 of us to get one off. Put an 3 hours on it so far today!! Feel like a 12 year old again!
/ To load or not to load. That is the question. #77
Quick. Find out where this belongs and put it there.
/ To load or not to load. That is the question. #78
Based on everyone's great advice I loaded the rear tires on my new-to-me DK5010hs - 50 gallons/400 lbs per side. Spreading crushed rock with the FEL showed that I am still a little light and could use a ballast box. I connected the 3Pt snowblower (600lb) for winter and gave it a test run with Friday's 6 inches of snow. Now I suspect I am light in the front end.
Should I consider loading the front tires as well? Would it be worth the effort? Other advice?
A word of thanks to TBN. I have read up on many topics as I have waited to press my tractor into action. It has been on site for two weeks now and I am having fun. I am a complete rookie but learning as I go. I reworked and graded my gravel driveway using my neighbour's blade and it turned out great - a bit to my surprise. Then I used it to grade the crushed rock in front of the garage saving a great deal of raking. I've only put 10 hours on the tractor so far but there are many jobs ahead come spring. With an average 8 feet of snow per winter, it will get a winter workout too.
/ To load or not to load. That is the question. #79
... I connected the 3Pt snowblower (600lb) for winter and gave it a test run with Friday's 6 inches of snow. Now I suspect I am light in the front end. Should I consider loading the front tires as well? Would it be worth the effort? Other advice? ..
For reference, I do most snow removal with the FEL & std bucket w/3 small 'Edge Tamers' on it's lip. 550' here, another 100' and half a dozen parkings spaces for the folks 'up front'. All gravel except a 20' approach to my garage. I have Rim Guard in rear R-4s.
Until you decide whether you need to fill the fronts for blower use, just start a job pushing as I do until you get a good packed bucket full and carry it a foot or so above the ground as you run in reverse. Not all tires work the same in variable plowing conditions.
If I thought I'd ever want chains for Winter I'd as soon do fronts vs rears. :cool: Lo buck car crap would work, steering would be as good as ever if not better, and on/off seems easy with FEL to lift axle for stands as usual.
btw, welcome to TBN PEJ5, and what did you mean by 'other'? :) t o g
/ To load or not to load. That is the question. #80
View attachment 579520View attachment 579523
Your place looks nice. :thumbsup: Looking at the tires, they look over inflated. Full tread width should be touching the ground and an ever so slight bulge on the rear tires.
I personally have all 4 tires filled on both of my utility tractors. That little extra weight gives you that little additional bit of traction. Very few people do this, but I have found it to be beneficial for my uses.
Enjoy your new equipment. ;)
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59912)
2022 GREAT DANE...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
KMC 4R ROLLING CULTIVATOR (A63291)
KMC 4R ROLLING...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
Tube Line Manure Spreader Nitro 750 (A63688)
Tube Line Manure...
LMC Ag 400 Gal Front Mounted Tank (A64119)
LMC Ag 400 Gal...
