Engine Oil Drain Valve
/ Engine Oil Drain Valve #1
paine
SE Michigan
Case DX33 Farmall
Has anyone user an engine oil drain valve like the valves at oilers oildrainvalve.net?
The Fumoto valve are high quality and I use them on my diesel truck and other vehicles but I am a little worried about the drain protruding down further then the normal drain plug and getting hooked on a stick or something in the woods.
/ Engine Oil Drain Valve #2
I have but given my use for my tractor, I do not want to run the risk of tripping the safety, then tripping the valve and draining my engine oil in the field.
/ Engine Oil Drain Valve #3
I like the Fumoto valve but do not have them on things I get off road. Tractors are easy to access most often so the valve just slows down the drain process.
That's exactly what I was thinking I am not going to go with the valve on the tractor!
I guess I was just feeling around see if anybody ever had one actually fail on a tractor.
/ Engine Oil Drain Valve #5
I don't use mine. I use an oil extractor. Use it on everything. Only vehicle I tried it on where it didn't work was my VW Cabrio. On my JD 4010, I used the extractor, unscrewed the oil drain plug; nothing came out.
Ralph
/ Engine Oil Drain Valve #6
Used the Fumoto valve for the first time on the 2010 F150. It was so easy to drain without making a mess.
Plan to use the 22 foot tilt trailer to gain better access the the engine oil filter.
/ Engine Oil Drain Valve #7
Love my Fumotos
/ Engine Oil Drain Valve #8
There’s no way I’m putting some stupid oil drain valve on anything own. It’s going to get knocked off and ruin a multi thousand dollar engine. What’s the benefit, you save getting a little oil on your hands?
/ Engine Oil Drain Valve #9
I have seen some of them. Just go with a smart Fumoto oil drain valve.
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
(2) 330 GALLON POLY TOTES W/ CAGES (A62131)
(2) 330 GALLON...
UNUSED WOLVERINE TD-13-36R STUMP DIGGER (A62131)
UNUSED WOLVERINE...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
2020 ASV RT120 Forestry Skid Steer (A61166)
2020 ASV RT120...
2015 Hustler Raptor Zero Turn (A63116)
2015 Hustler...
