Woodworking crosscut tools: Feedback needed
/ Woodworking crosscut tools: Feedback needed #61
A rip cut or "ripping" is any cut or cutting with the grain...does not matter what kind of saw is used...it's mostly about the blades or band blades...
Fair enough... but in context to the discussion above... resawing is generally done with a bandsaw. Ripping (dimensional lumber) generally is done with a circular blade. I think that is where most were going with this. And... we aren't even talking on the subject of cross cutting. :D
/ Woodworking crosscut tools: Feedback needed #62
What you are showing is "resawing" not "ripping".
The cutting is with the grain. How does that differ from ripping?
What is the difference in the cuts being made??
/ Woodworking crosscut tools: Feedback needed #63
FWIW
"Ripping dimensional lumber"...if you're referring to the average Joe amateur wood worker you're likely correct...
Commercial mills producing common framing dimensional lumber do not rip out every 2x4, 2x6 etc., etc...one board at a time on a table saw...
Again FWIW...
Anytime you rip a stick of dimensional framing material 1x, 2x etc...you are "re-sawing" the lumber...
/ Woodworking crosscut tools: Feedback needed #64
FWIW
Again FWIW...
No argument. :drink:
/ Woodworking crosscut tools: Feedback needed #65
All these great saws...but finding decent lumber.
/ Woodworking crosscut tools: Feedback needed #66
Skillsaw and a 2x4 work well for this. Lots of folks now use tracksaws.
In feed/out feed tables. No long fence needed; just a post opposite the blade works for many people.
With the right blades one can get a pretty clean cut.View attachment 575756
One of these is very easy to make and very accurate plus there's no need to account for any offset, just put the edge on your marks, clamp it down and run your circular saw along it. The fence is one edge of a piece of plywood and so far I have never came across any plywood that wasn't straight as an arrow. Make the bottom piece wider than your saw's offset and then make a cut to give you a reference edge. After that it's easy peasy.
/ Woodworking crosscut tools: Feedback needed #67
That is a handy jig... especially for remote work. I have built a few different wood jigs for circular saw, router, and a drill.
/ Woodworking crosscut tools: Feedback needed #68
I use a old steel cast rockwell RAS from the sixten, it have a larger 240V, 2hp motor. Allway’s stay adjust. The table is heavy but it is very stable. Probably scary but I like it.
Deere 772CH (A64126)
2016 Caterpillar 304E2 (A64126)
2016 Caterpillar...
ASV Engine & Parts (A66285)
ASV Engine & Parts...
2014 FVCG TRAILER (A61567)
2014 FVCG TRAILER...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
