Bucket Hooks
/ Bucket Hooks #1
WranglerX
Super Member
A Little Bit West Of Yosemite NP
MF GC1715
NOTE: This is copy and paste of thread in different forum.. Please don't shoot me!...
This is what I did for bucket hooks...Thought long and hard about adding "bolt on hooks" and just could not seem to make that purchase...
Materials are 2 x 2 x 1/4 steel angle and all bolting materials are 1/2 inch Grade 8... Slots were drilled 5/16 about 1/2 inch from edge of angel (targets for saw work) and hacksaw was employed to cut slots... Angles were also heated and curved over a bit for for better chain retention (I hope)...
Center "eye" is two pieces of angle welded back to back to form inverted "T" and drilled 11/16 for 1/2 inch shackle... Funny part is 1/2 inch shackle has 5/8 pin...
Since bucket materials is actually thinner than brackets I have no fears in brackets failing, my only concern will be not bending bucket lip....
And if you were wondering spring clip holds tarp in place when tractor parked...
Dale
/ Bucket Hooks #2
I like the chain slots. I welded large angle iron across about 4 feet of the bucket with 6 or so slots cut in on my previous fel.
Slots are very convenient.
/ Bucket Hooks #3
Nice job.:thumbsup: Great idea using chain slots, perfect!
/ Bucket Hooks #4
Very nice
/ Bucket Hooks #5
Just curious and I really like the work you did,, but why bolt and not weld? just asking.
/ Bucket Hooks #6
I used Kens bolt on on my GC, the top of the GC bucket is pretty rugged and doesn't need any added stock so the bolt on work just fine.. I have lifted 600 lbs with them and they work great..
/ Bucket Hooks
Just seemed the right thing to do, if one fails its easier to replace....
Maybe its a trust issue with my welds at high stress points though I really have not had any fail...
Dale
/ Bucket Hooks #9
I like the chain slots too. :thumbsup:
No experience with them but I would think they would be easier/more convenient than the bucket hooks I have, since one could come straight at them vs. having to bend the chain 90deg to secure.
/ Bucket Hooks #10
LOL the title should be “Bucket Slots”, not hooks!
Good job :thumbsup:
/ Bucket Hooks #12
Your slots are a great idea - nice work too. I like RjCorazza idea too with a row of slots. I have a tooth bar and I'm always using the teeth to position the chains from my two bucket hooks. If I didn't have that tooth bar a row of slots across the bucket would be a mighty convenient way to position the chains.
gg
/ Bucket Hooks #13
Just a thought, there are a few ways to do this. I havee used these in many applications before and find them quite handy. If you visit a truck upfitter that does heavy trucks and semi trucks there will probably be a few options on their shelf for you to pick from. These are normally only a couple bucks each and work wonders.
Chain Grab / Plate
/ Bucket Hooks
Chain Grab / Plate
This one looks pretty good as you don't have to thread chain through hole...
Chain Grab / Channel
Use "chain grab" as search string pops up more options....
Dale
/ Bucket Hooks #15
Those channel grabs make a pretty rugged chain connection. But what ML did with the slotted angle is plenty rugged enough for his Massey and most other CUT bucket work. I would rather bend the chain hook than the bucket or torque the FEL frame.
I use slotted angle to make chain hangers. Light duty though. Keeps the chokers organized on my winch so it is easy to grab what I want and not have to pull them out of a tangled ball.
gg
/ Bucket Hooks #16
A little different application but I am currently building a slip on carpet pole attachment for the farm. The two hooks and “eye” pad are not for lifting or pulling but merely to keep the attachment from slipping off the forks when retracting the pole from the roll.
Here it is at the moment. Just have to prep for paint.
/ Bucket Hooks #17
Chain Grab / Plate
Dale
One issue with those is that a grab hook often will not fit through them, so you need raw ended chain. Not a big deal, but be aware.
Also they are often called "Banjo Eyes" or Keyhole Plates".
/ Bucket Hooks #18
LOL the title should be 釘ucket Slots? not hooks!
Good job :thumbsup:
Kenny, you should expand your product line with slotted angle iron and sell it by the foot! It would also give you an excuse to buy an ironworker. (I'm projecting here)
/ Bucket Hooks #19
For myself, I have always found it handy as I will just need one grab hook on a chain. I have also torched out the top hole larger in some applications.
Many ways to skin a cat!
/ Bucket Hooks #20
I needed a good chain connection on the tines of my log grapple. I was going to just drill a couple 3/4" holes and use a shackle. I didn't know what the steel was but when I tried to drill an 1/8" pilot hole with a hand drill and a good bit I found out it was Kryptonite. A definite no-go with a hand drill - for me at least. Thought about burning a hole but my torch work is a little crude for a 3/4" hole. So I made a couple 1/2" weld lugs instead.
Now I have a slip connections with just the shackles or I can add a grab links big enough to pass a hook thru to get a grab connection.
gg
CASE INTERNATIONAL 183 - 6R DANISH TINE CULTIVATOR (A63291)
CASE INTERNATIONAL...
2025 SF60 60in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
2025 SF60 60in...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
2022 EZ-GO ELITE...
58in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
58in Hydraulic...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
