Cutting Fluid Film
/ Cutting Fluid Film #1
JJZ 109
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
I've got a gallon can of Fluid Film that I mostly use to paint the underside of 2 riding mower decks after pressure washing every fall. I had some FF in a pump sprayer and cut it with denatured alcohol, as that was the only thing I saw hanging around the garage at the time. It worked somewhat, but could have been much better. Should I have just watered the FF down more with the alcohol or is there a better cutting agent for sprayer use?
/ Cutting Fluid Film #2
Fluid film is petroleum based. Use a petroleum based thinner, if you have to cut it. Paint thinner, kerosene, mineral spirits, etc.
Thanks for the reply. I just visited their FAQ page (which would have been a smart thing to do in the beginning!). Here's what they have to say:
"The first recommendation is to thoroughly mix the product. FLUID FILM is thixotropic, and will get heavier upon sitting. Achieving room temperature with the product will help as well. If a thinner version is wanted, start by mixing a small amount of vegetable oil to the product until the desired consistency is reached. It is not recommended that FLUID FILM be used in a pump type sprayer even after thinning. Airless paint spraying equipment is what is recommended for proper application, applied at approximately 2000 PSI as a minimum."
For my current use, right out of the bucket with a paint brush works just fine for mower deck undersides. I was curious in case I ever decided to spray the underside of the truck.
/ Cutting Fluid Film #7
Thixotropic. That's a new one for me. "Will Get Heavier Upon Sitting". I know a lot of folks like that!
/ Cutting Fluid Film #10
Nope. Fluid Film is made from lanolin. Which comes from sheep. Looks like the OP has already found the thinning instructions.
True. But in fairness to Michael, FF's website also says "FLUID FILM® is formulated from specially processed wool-wax, highly refined petroleum oils and selected agents."
/ Cutting Fluid Film #12
I sprayed the underside of my truck with a graco airless sprayer.
Took awhile to prime, but once primed it sprayed real nice
/ Cutting Fluid Film #13
I sprayed the underside of my truck last year w/ a Fluid Film sprayer when it was about 80° F and was thinking of doing it again this year. But the darn temps went from the 90°'s to the 60°'s :(
/ Cutting Fluid Film #14
Goal of the post wasn't to be unfair to him but there is still a significant problem inherent in his response. Lets revisit :
He is recommending use of solvents to thin it, because its based on petroleum however you really don't want to do that. The basis of Fluid Film, and why many people choose it over other products, is that it does not contain any solvents.
/ Cutting Fluid Film #15
They make sprayers for fluid film, and other similar thick fluids. I have one. It was not expensive. No need to thin it at all.
/ Cutting Fluid Film #16
I have the Fluid Film sprayer and a undercoat sprayer.
Fluid Films sprayer works OK, but my car undercoat sprayer works great for oil or Fluid Film.
1660 (A59213)
1660 (A59213)
Tandem Axle Rear Truck Frame (A61568)
Tandem Axle Rear...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63118)
2017 Cadillac...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
Coyote Renegade Trailer (A63116)
Coyote Renegade...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63118)
2023 Kubota U48-5...
