Decent quality grease gun?
/ Decent quality grease gun? #1
davedj1
Jackson, NY
Kubota L2501
I'm not sure i this is the proper place to ask but I figured you all would know and I need a decent grease gun.
All the ones I have bought over the years have all turned to crap in short order.
Tractor supply has a new battery one on sale but no one there knows anything about them.
I have a Jeep, a Lull (telehandler), truck and the Kubota to grease.
Thanks
/ Decent quality grease gun? #2
I use a Dewalt 18v grease gun w/ a lock-n-lube coupler-best money I ever spent
/ Decent quality grease gun? #3
I've had a Lincoln air-operated grease gun and a Lincoln manual pistol grip grease gun for many years, no problems with either one.
/ Decent quality grease gun? #4
Thanks
I have been told that the DeWalt battery powered gun is very good, but for me it was a bit too pricey.
I bought the Lincoln model 1162 air operated gun. It is $70 on E-Bay, with free shipping/no tax.
Has hundreds of excellent reviews.
The 20V DeWalt on Amazon is $199, but $139 0n E-Bay, and it has excellent reviews.
The newer model DeWalt is 2 speed, and is more money.
With your 4 machines to grease, I think I would favor a battery powered DeWalt, and definitely get a "lock-n-lube".
/ Decent quality grease gun? #5
How does a grease gun turn to crap?
/ Decent quality grease gun? #6
Battery is the way to go. They are really that much nicer. Hopefully find one to match your tool set. Air is good too but 1) it is easy to blow dirt in your eyes if you're not careful as it exhales if you are in a dirty environment and 2) you need do deal with an air hose.
/ Decent quality grease gun? #7
Kind of wondering the same. I have several, including a mini. I have bought a couple at garage sales for cheap and they look to be well used. Cleaned them up and they are good as new. I sort of wish I could justify a Dewalt battery powered one just to be cool but I can't see me ever wearing out one of mine, let alone 4!
x2 on the 'locknlube' regardless of your set up and needs.
/ Decent quality grease gun? #8
I have a nice lever type I bought at NAPA a few years ago. The addition of a Lock n Lube last year has made me very happy. Got a couple of zerks on my brush hog drive shaft that it won't work on, think that I may need to replace them...
/ Decent quality grease gun? #9
I havent used my locknlube yet.
/ Decent quality grease gun? #11
I have a old Alemite lever gun that has a 2-way pivot near the pump. One position is for high pressure and the other position is for volume. It's a nice heavy duty gun.
/ Decent quality grease gun? #13
Thanks
I've had multiple lever action grease guns that simply did not hold up.
About 25 years ago I bought one at a JD dealer and have had absolutely no trouble with it since. I've put literally hundreds of tubes of grease through it with no problems.
It says JD on it but is probably made by Lincoln.
Been considering an electric one (lots of fittings on a BW mower) but have not yet bought one. I would of course never buy one with a NiCad battery.
SDT
/ Decent quality grease gun? #14
Not sure what i have. Its about 20 yrs old. My dad still uses one from probably the 50s, don't recall him ever replacing one, but maybe he has.
/ Decent quality grease gun? #15
I have the Milwaukee 12vt and 18 volt brushless grease guns. I love them both. The 18 volt has a lot of nice features. The high setting has cleaned a lot of plug fitting's. Have the other Milwaukee cordless tools so going with the grease guns mad sense to me. I am not at all trying to say the Dewalt in not a good unit. For me you go with which ever grease gun battery system you have.
/ Decent quality grease gun? #16
The JD (handraulic) pistol-grip grease gun has been flawless in its operation for me. The 'green' grease tubes are trouble free to change out and, once you've loosened the tip, I've never had a problem with it fitting a nipple or removing it.
Several non-green tractor owners on TBN have JD grease guns too. The cartridges/tubes are very convenient.
/ Decent quality grease gun? #18
I have a manual Lincoln and a battery powered DeWalt. I really enjoy the new DeWalt. Makes the job so much easier - definitely more positive results - takes about half the time - I don't get near as greasy myself.
WOW! I had no idea there would be this much response. I'll look into the Dewalt as I have a ton o Dewalt cordless tools anyway.
The Lock-n-lube looks interesting, I'll check it out.
Thanks
/ Decent quality grease gun? #20
Thanks
X10 on Dewalt electric WITH Locknlube. I zoom through 30+ zerks on my 2 ztr mowers in no time.
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2016 Bobcat E20 Mini Exacavtor (A61572)
2016 Bobcat E20...
2019 Caterpillar 349FL Hydraulic Excavator (A61572)
2019 Caterpillar...
UNUSED WOLVERINE HYD AUGER (A64281)
UNUSED WOLVERINE...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2015 Ford Fusion AWD Sedan (A61574)
2015 Ford Fusion...
