newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,850
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
Any comments on their pipe wrenches?
No experience with their wrenches but the quality/hardness of tool steel is germane to the overall quality of the tool...as soon as the teeth on a pipe wrench get rounded over the wrench is basically worthless...just sayin...!Any comments on their pipe wrenches?
The ones I got were definitely NOT tradesman quality. If you will use it frequently, avoid frustration and pay far more for pro tools. That said, if you need one for a special project, these inexpensive wrenches will do the job. I bought the first 24" aluminum pipe wrench just to unscrew the end off a loader hydraulic cylinder. I had to add a cheater pipe, and got the job done.Any comments on their pipe wrenches?
<snip>
After completing the farm plumbing replacement I took the photo below comparing the first 24" HF wrench against an 18" pro pipe wrench - Blackhawk brand- that I bought in an auto parts store (comparable to NAPA) in 1966. The teeth on this wrench I have used for decades in occasional automotive-type work (against hardend steel) are in better condition than the rounded off teeth on the HF that maybe has seen a week's work. After that photo of the rounded teeth I swapped in the tooth set from an ancient rusty Ridgid 24" pipe wrench since those 50 year old teeth were in better shape than the two-project HF wrench.
Summary buy HF pipe wrenches if they will pay for themselves in the first project. But not for daily tradesman work.
Here's the post where I originally posted this photo.
You don't need more space,you need an intervention...:laughing:
The teeth on the left are the original HF and the tips of the middle teeth are flattened to where they slide instead of bite. You might need to download and expand the photo to make this more visible.Are you saying the teeth on the left (pittsburg) are the ones you swapped in from the old Ridgid?
The Blackhawks teeth on the right look pretty rounded.
Your link doesn't get me anything about pipe wrenches.
Fyi, you can still buy replacement teeths for ridgid. I stripped, re-painted and replaced teeth on 3 old ridgids a friend inherited and gave me.The teeth on the left are the original HF and the tips of the middle teeth are flattened to where they slide instead of bite. You might need to download and expand the photo to make this more visible.
Later I was assembling a bunch of Dad's old junk tools to trade in at a used tool store for something I could use, and salvaged the teeth from a Ridgid 24" which fit the HF perfectly. The HF now works as well as the iron Ridgid did and I like the much lighter weight.
The post I linked is #2777 - June 2012 - in this HF thread.
I bought one of their cement mixers with a 40% off coupon. It's not a Kobalt, but it works fine for one 60# bag at a time. Two overwhelms the motor. Still better than a wheelbarrow
We have the 3 1/2 cubic foot version. I think it was $189 on sale.
It will do 2x 60lb bags, but I prefer to do them one at a time. I think that's around .45 cubic foot each. I'm happy with it.
Runs off a little 1600w generator.
I dump the mixed concrete directly into the BX2370 bucket, then drive it to the destination and dump / shovel it out.
Wrench Parts | Wrenches & Tubing Tools | RIDGID ToolsDo you have a link for the ridgid teeth?
FWIW I bought the HF 18" for $8. I really needed to get an outside faucet off. My only other "immediately available" choices in that size were $20@ Lowes, and $43 at Home Depot. Based on 50 years of home repairs, (plus the fact I have a better one about 1,000 miles away) I expect to use this maybe 3 times. But it's good to know I can buy quality replacement teeth.
Of course before I went to HF I perused the hfqpdb coupons and ended up getting a lot more stuff I've been needing. :laughing:
THANKS!!
And a comment on the mixers - I have used concrete mixers since the 1960's. One of the best "advances" was the use of plastics so they rinse out EASILY. About 5 years ago I bought a "Kobalt" from Lowes for about the same price as a HF only because of the plastic tub. Although I don't use it frequently EVERY time i rinse it out I wonder why all mixers are not at least lined with HDPE
I just assembled the HF mixer. For once the instructions were good and no missing fasteners. I see a big potential problem area with the axle and wheel assembly. The wheels are junk. I determined the tube that is the axle will receive a piece of 1/2" schd 40 pipe. A 5/8 axle most after market wheels are made for is a tight fit . Plan to heat the pipe and drive 5/8 axle stubs about 4" then weld. Add pneumatic tires/wheels and it will a lot handier and hold up under the pressures of heavy concrete. I have quite a few projects for it plus a friend also needs. Save a bundle over rental coats.
Ron
Found an old photo. As I mentioned above, the HF 24" aluminum pipe wrench's handle snapped when I used a cheater pipe over it.
But the next one I bought to replace it is noticeably beefier.
