Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #9,831
I bought one of their cement mixers with a 40% off coupon. It's not a Kobalt, but it works fine for one 60# bag at a time. Two overwhelms the motor. Still better than a wheelbarrow
We have the 3 1/2 cubic foot version. I think it was $189 on sale.
It will do 2x 60lb bags, but I prefer to do them one at a time. I think that's around .45 cubic foot each. I'm happy with it.
Runs off a little 1600w generator.
I dump the mixed concrete directly into the BX2370 bucket, then drive it to the destination and dump / shovel it out.
I think I finally found the answer I was looking for. I had no idea how many bags it would do in one batch. Now I see ... not enough. I was doing 3 50s or 2 80s in my wheelbarrow and was hoping one of these would save time. Now I see it won't.
   / Harbor Freight Tools that don't suck #9,832
Do you have a link for the ridgid teeth?
FWIW I bought the HF 18" for $8. I really needed to get an outside faucet off. My only other "immediately available" choices in that size were $20@ Lowes, and $43 at Home Depot. Based on 50 years of home repairs, (plus the fact I have a better one about 1,000 miles away) I expect to use this maybe 3 times. But it's good to know I can buy quality replacement teeth.
Of course before I went to HF I perused the hfqpdb coupons and ended up getting a lot more stuff I've been needing. :laughing:
Wrench Parts | Wrenches & Tubing Tools | RIDGID Tools
   / Harbor Freight Tools that don't suck #9,833
Deleted
   / Harbor Freight Tools that don't suck #9,834
THANKS!!
And a comment on the mixers - I have used concrete mixers since the 1960's. One of the best "advances" was the use of plastics so they rinse out EASILY. About 5 years ago I bought a "Kobalt" from Lowes for about the same price as a HF only because of the plastic tub. Although I don't use it frequently EVERY time i rinse it out I wonder why all mixers are not at least lined with HDPE
   / Harbor Freight Tools that don't suck #9,835
Hmmmm, they came out with a new utility box I think I'll try:
Tactical Ammo/Utility Box item#64113
Picture shows a tray inside which most of them don't have and this one also has smaller storage compartments on top.
   / Harbor Freight Tools that don't suck #9,836
THANKS!!
I just assembled the HF mixer. For once the instructions were good and no missing fasteners. I see a big potential problem area with the axle and wheel assembly. The wheels are junk. I determined the tube that is the axle will receive a piece of 1/2" schd 40 pipe. A 5/8 axle most after market wheels are made for is a tight fit . Plan to heat the pipe and drive 5/8 axle stubs about 4" then weld. Add pneumatic tires/wheels and it will a lot handier and hold up under the pressures of heavy concrete. I have quite a few projects for it plus a friend also needs. Save a bundle over rental coats.
Ron
   / Harbor Freight Tools that don't suck #9,837
Ron
My solution. Had a piece of 5/8" rod and wheels from a recycled fertilizer spreader. It's very easy to move now.
   / Harbor Freight Tools that don't suck #9,838
Found an old photo. As I mentioned above, the HF 24" aluminum pipe wrench's handle snapped when I used a cheater pipe over it.
But the next one I bought to replace it is noticeably beefier.
   / Harbor Freight Tools that don't suck #9,839
You'll be lucky if you don't break it too. No aluminum pipe wrench will take a cheater pipe and not break in short order. Get a steel one and you might bend the handle if you need to use a cheater. A friend owns a sprinkler business and warns everyone he hires that if he catches them using a cheater on an aluminum pipe wrench they will be fired. Of course he has a combination of Ridgid and Reed that cost about $100 for a 24". He does buy plenty of HF tools like large sockets, just not pipe wrenches.
   / Harbor Freight Tools that don't suck #9,840
Going to buy a wood stove from Northern Tools. No hydraulic experience with NT. Do they do coupons like HF?
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
JLG Lift 450AJ Series II (A57148)
JLG Lift 450AJ...
2825 (A58376)
2825 (A58376)
2012 Terex TA400 Articulated Dump Truck (A59213)
2012 Terex TA400...
Ammco Brake Machine (A55758)
Ammco Brake...
