Quick Attach Tree Spade
/ Quick Attach Tree Spade #1
AndyMA
Elite Member
Windham County, Conn
Ford 2120 , Kubota MX5200 , Deere X748SE. 1956 Economy Tractor
Today I hooked up my Tree Spade and moved a large Fig
Note the hooks & handles I welded on years ago it is quite useful for not only trees and shrubs but also setting large rocks. The hooks and handles allow chains or nylon straps
I’ve had it about 20 years. Only occasionally use it
I bought it. Can’t remember brand. I’ll see If I have any records
Andy
Maybe. The factory one is pretty thick steel with a hardened plate welding on at the cutting edge
/ Quick Attach Tree Spade #11
I wonder if a scrap propane tank could be cut down to make one. Anybody ever done this?
I thought about doing the same thing for a mini tree spade. I've had the tank for years. I'm just chicken to cut it. :laughing:
/ Quick Attach Tree Spade #12
I don't really understand. How would you cut a propane tank to make a tree spade? Slice it vertically and then weld it to a SSQA?
/ Quick Attach Tree Spade #13
Think of a 2d drawing of a cylinder.
Stand it on end.
Draw a line from the top right corner down to the lower left corner.
Draw a corrresponding line on the other side.
Cut along the lines.
You'll have two scoops.
Determine the angle you want it mounted at, make some spacers, and weld it to a QA plate.
/ Quick Attach Tree Spade #14
Stand it on end.
likewise with a clorox jug...make great scoops for liquids or dry goods... :thumbsup:
Stand it on end.
I'm sure it would work. The factory one weighs about 250 pounds and has a welded on cutting edge. I go in vertically just ahead of the ball and then slope it under as I drive toward the tree or shrub.
I've never bent it
Andy
/ Quick Attach Tree Spade #16
Been planning on building one myself. Once I get some funds. Money’s short after purchasing tractor. Mine won’t be quite that big. Thinking around 2ft.
INOP/NON-RUNNING 2015 International DuraStar 4300 Lab/Chassis Truck, VIN # 3HAMMAAL3FL514548 (A61165)
INOP/NON-RUNNING...
GENIE GS-2632 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-2632...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
iDrive TDS-2010H...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
