constant login issue
/ constant login issue #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I have noticed the last week that each time I visit I have to login, and I do check the remember me button.
Today it made me login literally 4 times in a row, as in enter name/pw, hit login, be sent to another login screen, with data pre entered. After 4th time , finally got in.
Odd??
/ constant login issue #3
I had the same a couple months ago after an update, I'm assuming a browser update (firefox). Eventually it cleaned itself up enough that all I have to do is hit the login button but still not as seamless as it was. I have not tried it in another browser but probably should.
Got on just now no issues. Maybe a browser upgrade?? Will see what tomorrow brings.
/ constant login issue #7
I have had to log in every time I want on TBN. I check the little "remember me" box - it never remembers. Six years.......... I've used Safari, FireFox, Opera & Chrome. Same result with each................
/ constant login issue #8
That is weird, I have used both Firefox and Chrome and except when I have cleared cookies have had to log in very few times.
Aaron Z
/ constant login issue #9
You need to make sure you don’t have your browser set to clear passwords and cookies at closing. Check in your settings. Let us know what you are using and we can go deeper in detail.
/ constant login issue #10
mpham - it probably has a lot to do with one setting I have - blocks all cookies. I've got Apple - OS is High Sierra 10.13.6 - and I'm currently using Safari V 12.
However - I also run with FireFox - Opera - Chrome. I'm also running AdBlock Plus.
I just last week updated Safari to V12. I just checked and I got my system set up so tight - when I get a minute I'll have to relax some of the parameters.
Use Firefox or Chrome, not Edge.
Aaron Z
I don't use edge, but I do use explorer, UC and a couple other browsers, doesn't matter which browser. And It's only this site that is doing it.
No joy. 4 login attempts in a row, literally. One after the other after the other. Each time my info is pre-filled in, I just hit remember me and login. It then takes me back and forth to 3 more login pages, then finally says thanks for logging in.
Very weird...
/ constant login issue #13
Very weird...
Which version of FF? I'm up to Quantum 62.0 and do run an ad blocker, uBlock because Adblock was not playing nice.
i am using UC browser, not FF. ( I do run explorer as well )
4 is apparently the magic number. That's what it takes.
Sad part is, it will pop up a login screw over top of the screw I'm already trying to login to. Hit login, then see another, and another.
Weird...
/ constant login issue #17
just curious if all the browser cache and cookie directories have been purged ?
/ constant login issue #18
Good point, I have had the weird misshapen web page issue from time to time and clearing the cache, then the TBN cookies always seems to fix it.
Aaron Z
I'll have to figure out how to do that.
/ constant login issue #20
It's been happening to me for the past week. I have to log in every time. This is the only site I use that it happens.
