PJ Trailers
/ PJ Trailers #42
Your original question was about PJ Trailers in general...
It's been my observation that here in the Northeast PJ Trailers have a real problem with their paint peeling in sheets quite badly. Otherwise they appear to be a well-built trailer.
My opinion this their powder coating just doesn't hold up here. Once the corrosion gets under the powder coat it just comes off in sheets. Automotive paint and primer is a much better combo.
/ PJ Trailers #43
OK, a bit of embarrassment here. It's not PJ, but Sure-Trac...
This is the model I'm looking at:
Sure-Trac | Tilt Bed Equipment - Sure-Trac 10K, 16+4
I can’t speak on the quality of sure-trac, but that is a beauty of a style. That currently would suit my needs the best. One thing that makes me hesitant with gravity or electric tilt is my cold weather. I’m not sure how the hydraulic systems will work at -40 in the winter.
Parts of me want a 16K gooseneck but I don’t haul anything requiring one.
/ PJ Trailers #44
When considering a new one I looked closely at sure-track dump trailers. I would've either bought a Cam Superline or Sure-track.
/ PJ Trailers #45
I don’t advise buying a trailer that’s gross overkill for the load. I’ve got a 10 ton gooseneck which is required to pull my backhoe but I don’t like to use it unless required. It pulls hard, turns wide and weighs twice as much as a lighter duty trailer.
/ PJ Trailers #47
I also am not a fan of the powder coating that comes off in sheets because it rusts underneath. I think a good rust preventative paint put on with a brush is better here.
/ PJ Trailers
I'm not looking at PJ now, but did notice that they offer powder coat by default, but optional Primer + Powder Coat.
I won't be using this trailer too often, and hope to store it indoors, so longevity of the finish is probably not as important to me as to others, but it's definitely a consideration.
/ PJ Trailers
Understood, and agree. Additionally, I have a very steep approach angle to both my regular driveway as well as my second entrance. I do have a relatively flat entrance available, but it's a few hundred yards away, and no real "road" to the main part of the property. I think a slightly heavier than needed capacity, in the length that I need, is the way to go.
Lots of good advice here, thanks all. Will certainly be checking back in and let you know my final decision.
/ PJ Trailers #50
I know this is a bit late, but I weighed my B3000 TLB this summer, and it came in at 4760 lbs - much heavier than I was expecting. I have loaded rear tires, and did a dynamat soundproofing project years back, but can't imagine that added even 100 lbs.
I also had calculated around 3600 lbs based on information I found online, so some part(s) of that info I found was definitely wrong.
FYI, I have an 18' bumper pull (16+2), and it is definitely on the short side. I've also removed the subframe extension plates to pull the backhoe in 9" closer to the machine, so I'd recommend nothing shorter than 20', but if you want to throw another implement on the trailer along with the TLB setup, I'd say 24' minimum.
/ PJ Trailers #51
MY Deere 110 TLB was sold as a package deal and came with a PJ trailer... nothing bad to say about the PJ
It is 18' with two 6k axles and plated for 9,990 lbs due to State Commercial Regs
The 110 fits perfect and the trailer is a joy to use with the tilt up ramps... which I didn't like the looks of at first but sure makes loading easy...
Does the empty trailer actually weigh 2710 lbs., or less? T(ractor Data shows the JD110TLB as 7280 Lbs.)
/ PJ Trailers #52
I've never weighed it...
My PJ is bumper pull 18' with tip up ramps... GVW plated just under 10k for California non-commercial non-RV limits with two 6k axles.
The 110 has quick attach loader and backhoe... tires are not loaded.
I imagine it would be very close and easy to go over.
/ PJ Trailers #53
I would suggest getting a little more trailer than you think you'll actually need/want. The future may require it for one reason or another.
I own a few different trailers but I do love how well this PJ tows.
/ PJ Trailers #54
Agree get more trailer than you think you need...but then the Gov comes along and clusters that all up with more and more regs as GVWR goes up.....So trying to be safer augers you into this rabbit hole
/ PJ Trailers #55
^^^Often the case... lots of well built trailers and pickups de-rated here in California to avoid CDL and other restrictions.
/ PJ Trailers #56
I will bet it is over, every time you pull it.
A full fuel tank will add 150 lbs.
/ PJ Trailers #57
The few times I have been weighed has been hitched up... with a load... so quite a bit of tongue weight on the Super Duty Diesel...
I imagine the only way to accurately scale is with the trailer loaded and not hitched?
/ PJ Trailers #58
I tried to imagine my longest hauling length, and other potential needs and wants. I measured the tractor with FEL, added the length of a 6ft bush hog, and added a couple feet of leeway. After waying pros/cons for ramps I decided against flip up's in case they got in the way but now I'm im sorry for that as I do not like the slide in ramps. They do not stay secured when loading, they are too short, and of course heavy. This winter I'll fabricate a longer, adjustable flip-up ramp set with spring assist.
Here's my PJ 16,000lb GN 22ft+2ft beaver tail and tow rig:
And loaded with some gear:
/ PJ Trailers #59
At first I did not like the flip up... but it was a package and though OK... I will just sell the trailer.
After using it I am glad I didn't sell... I find the tilt up easy to use, secure and always at the ready...
/ PJ Trailers #60
I don稚 advise buying a trailer that痴 gross overkill for the load. I致e got a 10 ton gooseneck which is required to pull my backhoe but I don稚 like to use it unless required. It pulls hard, turns wide and weighs twice as much as a lighter duty trailer.
I resemble that remark!
I bought a B7610 with a 5K Hudson trailer in 2007.
<snip the pic>
And I also resemble that remark!
In 2012 I bought a second tractor, which filled the trailer.
I was very glad the tractor was able to fit the trailer.
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
