Tractor backhoe - homemade
/ Tractor backhoe - homemade #1,062
The boom profile hes building, is comparable to a Caterpillar M314 mobile excavator, which is considerably stronger than a TLB. Unless its a Huddig:
HUDDIG schafft Lagerflache fur Stammholz - YouTube
SMALL CHANGES MAKE A BIG DIFFERENCE | Huddig
These beasts weigh 12.5 ton without buckets, which means a 15 ton operating weight, and are built to take a beating in harsh scandinavian frost. It has the same ZF axles as a 13 ton wheel loader like a Case 621 and arent comparable to any of the regular backhoes, both in durability as well as in price.
I thought this was going on a tractor that’s half or less that weight. Have I really missed it here?
/ Tractor backhoe - homemade #1,063
Mostly, I'm thankful you guys speak such good English.
Same here, I've read some pretty informative stuff on this thread from people that use English as a second language, usually much better than I find on your average FB post.
/ Tractor backhoe - homemade #1,064
I thought this was going on a tractor that痴 half or less that weight. Have I really missed it here?
No you got that right, the Belarus weighs about 4.3 ton, the front loader adds another 700 which makes 5, and the backhoe will weigh somewhere near 2 ton, which makes it still 1 to 1.5 ton less than a full size backhoe. I dont know what cylinders Bfreaky uses, but judging on his boom dimensions, he must think that overkill is underrated 😁
/ Tractor backhoe - homemade #1,065
You can do so much with overkill. My full size backhoe will easily pull its self backwards or pull the front end off the ground lifting with the boom.
Renze, main cylinders on the new backhoe will be 115/50-800 mm, all brand new. Bucket cylinder is 80/50-800 mm. The booms will have the same width (220-200-170 mm) but the height is smaller then rk 525. I'm carefully calculating the weight of every part. Main frame will be built with tubes 150x100x8 mm, stabilizer legs dimensions will be 150x150x8 mm. I'm hoping to get under 1500 kg with everything...
Yes. Got no problem with that. They have great supply with a wide range of sizes
Well I don't know, I live in Europe :)
I won't be moving anywhere...but I did make some moves regarding this backhoe build. Here are tubes for the main frame and stabilizers...more pictures coming after the holidays...
/ Tractor backhoe - homemade #1,074
I just ran across this and wow...how amazing. To be able to go from pencil and paper is truly a gift.
Yes, alot. I hate digging by hand...time consuming...low effect. I will rather weld for a week just to dig easy :)
/ Tractor backhoe - homemade #1,078
I'm glad your English is so good. Have you been stateside? Can you speak it as well as you can type it?
Yes, it makes no difference to me. I've always been interested in foreign languages. My German is on the same level as English...huge curiosity is the trigger for all of this. Anyway, I can't wait for these holidays to end so I can work on my backhoe ;)
/ Tractor backhoe - homemade #1,080
I didn’t get along very well with shovels, so.. I definitely feel your pain. IMG_0786.JPG
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
2015 Ford F-250 Pickup Truck (A61568)
2015 Ford F-250...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A60352)
2004 International...
