More weight for my disc harrow
/ More weight for my disc harrow #1
def38
woods and mountains of Alabama
M-F 231S
I have found that disc harrows are usually a bit light when attempting to bite deeper in the red clay soil we have here in Alabama. So, I'm going to add some weight to my disc.
My idea is to weld some pipes vertically at the corners of the frame then, make some weights from plastic coffee cans with a center hollow tube (PVC pipe) poured full of concrete. Question is, how many of these concrete weights will I need to add a total of 200 lbs to the disc?
Also, does anybody have a better idea for adding weight to my disc? I had thought of using cast bar bell weights but they're too expensive.
Comments and ideas welcome.
/ More weight for my disc harrow #2
Scrap lead, if you can find it ...free.... or cheap.
Iv'e got lots, but you would have to drive 1500 miles to get it.
/ More weight for my disc harrow #3
Some steel and about 5-7 bags of 80 lb concrete, maybe $35-$50 or so. ~500 lbs:
/ More weight for my disc harrow #4
ETA: Where are you located in AL? I'm about 10 miles north of the border around I-65. I still have the form if you want it.
200 lbs /145 = 1.4 cu ft. Or about 2.3 80 lb bags of concrete.
Given how the disc reacted with this 500 lbs, I'd up your weight by about double, if not more. But a lot of that depends on a) the size and HP of your tractor and b) the size and ruggedness of your disc.
/ More weight for my disc harrow #6
My suggestion would be to search Craigslist (or?) for used cast iron tractor wheel weights.
That way you can add or deduct whatever weight is necessary to achieve implement penetration.
Most modern implements aren’t designed for extra weight. No point in fatiguing your disc unnecessarily as well as consuming more fuel.
I have a pile of them. There’s most likely some in your area.
/ More weight for my disc harrow #7
I just went to lumber yard and bought some solid cement blocks , and made a contraption to hold them on . I used them in the back of pick up in winter for traction and on harrow in summer .
I agree that adding too much weight in the wrong places will likely cause stress failures at welded joints. Therefore, I'm likely going to have to add some gussets and other structure to strengthen the frame as I add weight. I'm thinking that I'll merely create an additional rectangular frame on top of the existing frame using square tube and attach the necessary boxes, brackets and other appurtenances to hold the weights (likely concrete blocks similar to FTG-05's suggestion) about 50 lbs each (I have no means for lifting heavy stuff and I'm 80 years old...I don't lift like I used to).
Thanks for the offer. I'm at about the 282 mile marker on I-65, then 8 miles east.
/ More weight for my disc harrow #10
Are there any scrap / recycle metal yards in your area ? A few months ago , I bought some nearly new 1/2" plate for $ . 60 a pound . The 5 100 pound weights I have on my 6' + king kutter disk were homemade tractor weights . Thing now weighs around 1,100 pounds , which , if our clay is wet , is all that my TC 30 wants to pull . I only use mine for fire breaks around property in spring , which , with the notched blades , it works great for .
Price of scrap steel varies weekly , thus one can monitor it weekly and buy when price is down .
Fred H.
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
Detroit Diesel Auxiliary Hydraulic Power Plant Generator (A59317)
Detroit Diesel...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
Kubota RTV X900 (A53317)
Kubota RTV X900...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
