Tractor Buying Advice for 1 acre Lot
/ Tractor Buying Advice for 1 acre Lot #41
John Deere chainsaw? I have a couple of those, I like them..
Yup, won one over at Arboritsite.com
/ Tractor Buying Advice for 1 acre Lot #42
I have the same CS62 and I have a little CS38.. Made in Italy I believe.. Efco-Oleomac I think mine are..
/ Tractor Buying Advice for 1 acre Lot #43
You mentioned in your post that the John Deere tractors are inferior. Can you please explain in what areas? Are you referring to the larger tractors or the John Deere 1025R. I have look at many sub compact tractors and they all look pretty similar, but there is some slight differences and think the John Deere is pretty well built when looking at the loader and backhoe construction such as it is larger loader arms compared to others and it is well attached to the tractor. I have been leaning towards towards the John Deere 1025R and maybe I am missing something that I should checkout. So I am curious if I am missing something that you may have seen otherwise with the John Deere 1025R being inferior?
There is a lot of Anti-John Deere bias overall on this board. Deere makes good compact tractors. The 1025R works just fine as a SCUT. In raw loader specs it may be less than some of the other brands but they have the easiest loader, backhoe and especially mower (auto-connect drive over deck) to attach and un-attach. The diesel fill is on the left rear fender instead of on the hood like some of the other brands. It all depends on what you are looking for and what tractor is a nice fit for you. You don't have a lot of ground and tasks to justify a SCUT that you can't mow with as well - I believe that needs to be your primary concern if you decide to get a SCUT.
Tractor Time with Tim
- YouTube
<-- Here is a YouTube channel (Tractor Time with Tim) where they use a 1025R in their handyman business. That's real world.
Decisions, decisions..... :)
/ Tractor Buying Advice for 1 acre Lot #44
A SCUT maybe useless for you but a lot of people including myself find them to be very useful for many things. Considering what the OP has outlined what he wants to do with it, a SCUT is more than adequate.. As far as "child like snow blower capability", I run a 3pt 54 inch rear blower that clears a 250ft driveway of 30 inchs of snow in short order..
There are many people that consider your 4010 a useless toy, it's all in the task at hand..
I did establish that the compact CK 4010 is, in my opinion, at the lower end of the usefulness continuum. It痴 an oversized toy.
A SCUT is even more marginal for doing real work. They are easy to store, though.
/ Tractor Buying Advice for 1 acre Lot #45
Bias: prejudice in favor of or against one thing, person, or group compared with another, usually in a way considered to be unfair.
I came to TBN with a huge pro-Deere bias, not based on facts but because it was the only brand I had ever heard of. However, I found the specs to be disappointing.
There's quite a bit of pro- and anti- brand bias here in general. Specs are specs and facts are facts, but people are also entitled to their preferences. I try not to confuse the two.
I do agree the gas fill on the fender is a plus.
Does anyone have any recommendations of a good new or used make a model garden tractor with rear differential lock with a after market front end loader? I am looking for something is a commonly available and easy to get parts.
/ Tractor Buying Advice for 1 acre Lot #47
I bought an X495 24hp Diesel and have never regretted it. These are true Deere workhorses.
They are available with 3 pt hitch, rear PTO and front hydraulics and a 62" mowing deck. This is my go to yard machine.
I use a 6' landscape rake for gravel and dirt leveling as well as a 54" hydraulic front bade for snow, mulch, loose dirt and gravel. There are several nice aftermarket front end loaders (see JOHN DEERE X475 X485 X585 X595 X700 ultimate ) reasonably priced that will do a surprising amount of work. With the PTO and the 3 pt hitch the implements available are amazing.
If I were in your position right now I would seriously look at the x700 series (diesel) mowers. great mowers that will also do a lot of other work.
There are a lot of videos of the X series on youtube moving snow, digging dirt, moving rocks, etc . ..
I hate to repeat myself but the "X" series mowers (especially the diesels) are amazing machines.
The aftermarket FEL will lift 700# without a problem (not bad for $3,500). Take a look at the videos on the CTC site.
Hydro-static transmission, locking differential, power steering, cruise control, 3 point hitch, PTO, front hydraulics, etc ... These mowers have/do just about everything.
Also take a look at john deere x495 with 54 blade snow ploughing - YouTube .... I have filled "bar tread " tires on my mower and we live at the back end of a rugged 1.5 mile gravel road. when we get 8" to 12" of snow, this machine really shines. I plow circles around my neighbor with his 50HP farm tractor with a rear blade.
I have looked at the x700 series tractors and they are near the same price and the sub compact tractors such as the John Deere 1025r. When looking around on the internet I can find 1025R at the same price or even cheaper on the used market. So by the time you get the x700 series with a CTC loader you are almost at the same price as a John deer 1025R, which I would rather have the 1025R.
/ Tractor Buying Advice for 1 acre Lot #49
Yes the X700 with just a mower and gas engine was about 12 grand which is crazy and no loader option that I know of.
JD 2305, Massey 2300, 2600, JD 755, 855, 955 that's what I would be looking for on the used market..
/ Tractor Buying Advice for 1 acre Lot #50
When looking at SCUTs, i would recommend looking beyond the specs.
I would recommend looking at ease of connection for attachments as the #1 feature in this size unit.
2nd is user friendly operation (avoid joystick on the loader...get the joystick on the rear fender. Much more comfy)
Please check out our videos on YouTube if you have not done so. We show the 1025R in every possible situation. However, most of the information applies to all brands.
We do not show a tone of “Deere or bust” on our channel.
All of these SCUTs are very similar in actual capability. The difference is in the detail.
For example. The auto-connect deck (while unfairly blasted by lots of folks) is an incredible feature which makes the tractor more functional. If it is too painful to remove the deck, folks will attempt to do loader work with the deck on...which will limit the usefulness of the loader. This type of thing won’t show up in specs, but it DOES show up in real life usage. “Oh, I just have this one thing to do...not worth removing the deck...I’ll just leave it on...”
That is just an example. Kubota BX’s Single point connector is another excellent example. Making the loader a little easier to remove / attach makes the tractor more functional. ...but it won’t show up in the specs.
Tractor Time with Tim - YouTube
http://tractortimrwithtim.com
Tim
/ Tractor Buying Advice for 1 acre Lot #51
Much more comfy for some, not so comfy for others and sometimes in the way..
When we are talking SCUT’s, I would call 2hp more at the PTO with 2hp less enigine hp, substantial. All SCUT’s similar yes, but not the same, loader lift is another concern. I’m not bashing Deere, just comparing the obvious differences, it is what it is..
/ Tractor Buying Advice for 1 acre Lot #52
There is a lot of Anti-John Deere bias overall on this board. Deere makes good compact tractors.<snip>
I've only been on TBN a short while, but over those 9 years I have very read little bias (per GWWT 's definition) against JD. Most of the comments are along the lines of JD is expensive for what you get. Like comparing Kubota to Jinma. I think most of us believe Kubota is better than Jinma. But if you needed a new tractor the Jinma might have been within your budget.
Many of us here would like champagne but we are on a beer budget.
The JD dealer I'm familiar with carries CUT's almost as a sideline, real tractors have dual rear wheels and 3 steps.
JD makes great equipment and has great support but someone has to pay for it.
/ Tractor Buying Advice for 1 acre Lot #53
As far as SCUT's go, I know two farmers that have the 1025R they use around the farm for small chores. I asked them how they liked them because online I see a lot of folks saying they are not that good of a tractor, overpriced, and nothing but plastic. Both farmers said they use them everyday for something. They both had good things to say about them and they both put a lot of hours on them weekly. This is coming from folks that farm for a living and have been running tractors for decades.
I looked at and drove a lot of SCUT's last year. I was contemplating getting one for smaller jobs and just because I eventually want to get a small tractor. I stayed away from looking at the Deere because of all the bad things I heard about them online. Well, one day I stopped by the Deere dealer to get some chain lube and they had a 1025R sitting there. I got up on it and sat down. It felt better than any other SCUT I sat on. I then got on one they had outside and drove it around. Handled just fine and felt really comfortable (good ergonomics). If I do decide to buy a SCUT, the John Deere will definitely be in the running.
I also liked the Massey but I did not like how the seat felt on the 1720. It felt really high and uncomfortable. The Kubota BX was also a nice machine but again I did not like the ergonomics on it. The Mahindra's I looked at were pink and showing signs of rust. I was just not that impressed with them, however I was at my New Holland/Mahindra dealer the other day getting parts and saw one of the new Max26's sitting outside. That looked to be a nice machine but I did not get on it and try it out so I cannot comment on it. (These are just my opinions on the research and test driving that I have done, all these machines seem to be quality machines).
Like stated before on here, when it comes to these SCUT's I believe all of them will do what they were designed for (yard maintenance on a large house lot). There is not a huge difference in any one of them when you really look at it in a real world situation with what they are designed to do. I write technical specifications for a living and when you look at any manufacturer's stated specs, they are always at MAX of what the machine is capable of and rarely are the machines operated at MAX specs 100 percent of the time.
If you decide on a SCUT for your 1 acre, you will be very happy with it and who knows, the neighbors might start asking you to come over and move something or dig something up. You will find plenty of uses for it. Good luck in your search.
/ Tractor Buying Advice for 1 acre Lot #55
If you're interested in equipping a garden tractor with an aftermarket FEL and rear hitch you can raise and lower, I recommend you contact Johnny Products to ask which models can best handle them. He has always been very responsive and helpful. For example, after purchasing the rear sleeve hitch for my Husqv garden tractor, I inquired about adding a Johnny Bucket as well. He actually sent me a drawing that showed how to tell whether mine had the stronger frame that can take the bucket, or the weaker frame, which cannot. Turned out I had the weaker frame. When the little switch/controller corroded (my fault--not really properly installed and exposed to rain) he sent me a new one for free, very quickly. My wiring harness that goes from the hitch to the switch came loose from the TAPE I used to secure it under the tractor and got shredded by the mower; the replacement cost around $15, again shipped very quickly.
So I recommend Johnny Products because they provide good support, reasonably priced replacement parts, and even free advice. My Brinly box blade (which I bought to go on the hitch) not so much. The C-hitch was out of square so was very difficult to slide the pin through. After literally 2 years of messing with their "support" I gave up and purchased one from Johnny Products, which works great. So, four years later, still happy with the Johnny hitch, but I would buy a different box blade--not the Brinly--if I had to do it over again. There are a couple companies that make rear implements for ATV's that might work for a GT.
I hope this information is helpful.
/ Tractor Buying Advice for 1 acre Lot #56
Tim
I think this is personal preference. I actually like the joystick on the loader. The joystick on the 1025R seemed like it would be too easy to bump with an elbow or a leg, but I may be unusually uncoordinated. :)
/ Tractor Buying Advice for 1 acre Lot #57
/ Tractor Buying Advice for 1 acre Lot #58
That Massey's a clean looking tractor. I questioned the price at first but they haven't made them since 2008. It will be a good deal for somebody.
Actually I found a bunch more in the 500 hour range for $7000, and that's asking price.. If you have cash or a credit union with 3.50%, that would be the way to go..
/ Tractor Buying Advice for 1 acre Lot #59
Here in Indiana, Deere & Kubota are essentially the same "buy" price. I think the Deere dealers must be more competitive here than in the Northeast and other areas. 1025R with loader and mower can be purchased new with 0% financing for $16k.
I don't care what brand folks buy. I'm sure any of them will do the job. We just don't see the price difference between the big two (Kubota-Deere) here in Indiana.
Tim
/ Tractor Buying Advice for 1 acre Lot #60
Tim
In this area Kubota is fairly static on pricing. Depending on the model you might get Deere to sharpen their pencil. Smaller tractors play a larger roll in sales in this area than they do in some parts of the country so all the dealers are competitive. Ergonomics, features and, of course, the dealer count for a lot. The good news is that most all of the manufacturers make a solid SCUT, so don't discount a brand because it is a smaller player. Some have better or different features than others, but they will all do what you need to do.
Location, Tampa, City of Tampa .** Title MUST be transferred into buyer's name INCLUDING DEALERS. (A59231)
Location, Tampa...
1990 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1990 Lufkin...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
2008 VOLVO VHD64B CRANE TRUCK (A59905)
2008 VOLVO VHD64B...
2017 Ford Transit Connect Cargo Van (A59230)
2017 Ford Transit...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
