Is she too big??
/ Is she too big?? #1
Cavjock22
Seabrook, TX
Kubota M6060, Bushhog 3210, Deere offset disk, Deere B drill, forks, bucket
I have an opportunity to purchase this used cutter.. It might be a steal.. I even have the complete svc history.. But..... Is she too big for Kubota M6060. I知 thinking the weight for sure.. Maintaining pasture with grass and light brush...
Thoughts 65C7D7B7-72F2-4B77-82B0-7DC5F954A9CD.pngBC82BEC7-D566-49C0-991F-CB506D26F092.png
/ Is she too big?? #2
Thoughts? Since it says minimum HP rating = 50, and you might get it at a great price, I say go for it. Worse case is you don't like it and you sell it for what you have in it. But that's just me, spending your money. ;)
Edit to add... I've researched those Modern Ag mowers in the past and they have some very nice features.
/ Is she too big?? #3
Wow, that is heavy. According to that sheet and google it is 1600lbs too heavy. It weighs almost as much as your tractor. HP seems to meet the minimum.
On the bright side, you can get aircraft tires for it. :D
/ Is she too big?? #4
It is heavy, but his tractor probably weighs 2,000 more than this. Why do you say it is 1600lbs too heavy?
/ Is she too big?? #5
Its gonna be all your tractor wants and in thick stuff , it will be a challenge
/ Is she too big?? #6
Looking at the picture more closely I see you just drag it around so my thinking is flawed. I was figuring it was a 3ph type. Still looks quite big at 12' wide.
/ Is she too big??
The one i’m looking at has aircraft tires on it.. Yes, i’m worried about the weight..
/ Is she too big??
It’s 10 wide..
/ Is she too big?? #11
I would go for it. I have a 7040 and pull a ten foot cut simi mount bush hog. It cuts all but the thickest with ease. If I hit a tuff patch I just slow down a little.
/ Is she too big??
I appreciate it..
I’ll see what happens.. Also considering a 10’ bushhog 3210.. going to inspect in next week
/ Is she too big?? #14
You just have to be rational in what you expect,,
Here is my 90 inch mower on my little JD 4105,,,
I do not try to mow 6 inch oak trees with it,, :confused2:
/ Is she too big??
Pulled the trigger on the 10.6’ Bushhog.. After giving her several hrs of TLC, put her to work..
Previous owner hasn’t serviced the gear boxes. Used 5 gal of gear oil running and draining after it would get warm.. Oil seems still milky even after 5 drains and re-fill. By the way, sucking the oil out with outboard engine oil sucker tank.. Im thinking I cant get all the fluid out.. I looked underneath and I don’t see any drain plug above the stump jumper..
Other than that.. My kubota can handle her very well..
/ Is she too big?? #16
I run a 96 inch I picked up used ( twice) on my 70 hp tractor. Weighs 2400 pounds. Perfect match.20180911_172837.jpeg
/ Is she too big?? #20
you wont run a 12 foot mower on a 60hp tractor around here unless its dry burnt off august and you are clipping the tops at 12 inches tall - I run a 6.5 on my 65hp and its all it wants in 2nd gear if I am mowing it down to 4 to 6 inches - and that is only mowing at about 2.5mph - you couldn't get me to put anything less than 100hp PTO on a 15' batwing mower around here unless I was topping grazed pasture.
Bobcat 709 Backhoe Attachment (A64047)
Bobcat 709 Backhoe...
2014 Jarraff Geo-Boy Mulcher (A64047)
2014 Jarraff...
2012 Ford E-350 Passenger Van (A61573)
2012 Ford E-350...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
Eddins 77350 Grain Buggy (A64047)
Eddins 77350 Grain...
