8N Replacement
/ 8N Replacement #1
tderrick
Nashville
L3901 , Ford 8N and 640
I am looking to retire my Ford 8N from the bush hogging duties of the farm. What model Kubota would be a good step up in power
over the 8N. I guess about 30 hp would be good, as the Ford was 20hp in '48
Thx for any help narrowing down the choices.
AJ
/ 8N Replacement #2
About 30 hp would be good, as the Ford was 20hp in '48
Kubota L3301 or the de luxe Grand L3560.
L3301: https://www.kubotausa.com/docs/default-source/brochure-sheets/l2501.pdf?sfvrsn=34e9b1d_8
VIDEO: Kubota Standard L Series VS. Grand L Series - YouTube
INSIGHT: https://www.tractorbynet.com/forums/buying-pricing-comparisons/397672-ford-8n-vs-kubota-l2501.html
L3301 and L2501 are essentially the same tractor. L3301 has increased power and mandatory Tier IV emission controls.
/ 8N Replacement
/ 8N Replacement #4
The L has been earmarked for this segment both in size and capability...
We bought the L3800 and are pleased we the decision... this model has been superseded with the more recent enhanced emission package.
The L and the NAA Ford Jubilee sit side by side in the barn...
/ 8N Replacement
Why do you say the Tier IV emission controls are mandatory?
thx
/ 8N Replacement #7
During 1998 offroad engine regulations reducing emissions were structured as a 3-tiered progression. Offroad regulations use the metric system of units, with regulatory limits expressed in grams of pollutant per kWh. Examples of regulated applications include farm tractors, excavators, bulldozers, wheel loaders, backhoe loaders, road graders, diesel lawn tractors, logging equipment, portable generators, skid steer loaders and forklifts.
Each tier involved a phase-in (by engine power) over several years.
Tier 1 standards phased-in from 1996 to 2000.
Tier 2 standards phased-in from 2001 to 2006.
Tier 3 standards phased-in from 2006 to 2008 (Tier 3 standards applied only for engines from 37-560 kW).
Very stringent Tier 4 emission standards, phased-in from 2008 through 2015, require substantial reductions of Particulate Matter above 19 kW power output.
Every tractor brand includes a model in the 2,600 pound to 2,900 pound (bare tractor) range with 100 cubic inch/24 horsepower engine. Tractors under 19 kW ( 19 KW = 25.4794-horsepower) are presently exempt from stringent Tier IV emission controls which abruptly increase a tractor's cost some $2,000 above the 19 kW power demarcation.
In Kubota's product line this is the model L2501.
/ 8N Replacement #8
Same. I had a L3200 (same as the L2501 with a few extra HP). I upgraded to a L4060. I upgraded more for the cab than the extra HP. & weight.
Weight is what makes a tractor work. Hp just defines how fast. That goes for pulling & lifting, less so for PTO work like mowing.
TractorData.com Ford 8N tractor information has an 8n at under 3,000lbs & 27hp. That matches up with a L2501 or L3301 pretty well. The modern machines have better loader & 3pt lift capacity. Not to mention manuverability with 4wd.
A L3560 isnt quite double the weight of an economy L. It also has a lot more bells & whistles than the economy machine.
/ 8N Replacement #10
I purchased a nice used Kubota L2900 30hp diesel. No comparison in power, though my old Ford is a little tired. I figured a well cared for used tractor would likely outlast me and my uses for it and I don't want any part of emission systems or fancy electronic control systems. In that way the old Ford and the 20 year old Kubota are very similar!
/ 8N Replacement #12
AJ
I replaced an excellent 1951 8N with a Sherman combination transmission (12 speed/3 reverse/3 speed PTO) this summer. I had owned this tractor for 35 years but in recent years it was used exclusively to pull a 5' rotary cutter for use in areas that did not look right if mowed with one of my larger tractor combinations. The 5' cutter had not been removed from the 8N in years.
Be advised that a late 8N was rated at 27 PTO HP at rated engine speed when new so a 30 PTO HP tractor is not much of a power increase. I would expect that you will find that a 3301 is little more than a wash in PTO power if your 8N is not too tired, whereas the 3901 should be more noticeable.
In my case, I chose a B3350 for multiple reasons, some likely not relevant to your situation. I bought a FEL with third function valve and hydraulically angled snow plow for snow work. I may also buy a MMM for lawn duties sometime in the future but have not yet done so.
The 27 PTO HP 3350 handles the (not too heavy) 5' cutter nearly as well as did the 8N from a power standpoint but is considerably lighter so the mower does push the tractor around more. It also bounces me around more due to smaller tires and shorter wheelbase. That said, the improved seat with arm rests are a noticeable improvement. The mower also tends to scalp more due to the shorter wheelbase and smaller tires of the tractor. I'm still sorting this out but will eventually.
SDT
/ 8N Replacement #13
I’m still using a ‘52 8N but am planning a new tractor purchase in the next year. After several years of research I’ve narrowed my choice to either a Kubota L3560 ROPS (3500lbs) or a Yanmar YT235 Cab (3000lbs). Both $27K.
/ 8N Replacement #14
Amazing just how many old tractors and especially 65+ year old Ford Tractors there are still earning their keep...
A real tribute to honest engineering and American Quality...
I have a soft spot for antique iron... cars, tractors, hit and miss engines... etc.
Are those upgrading keeping or selling the old iron?
/ 8N Replacement #15
My 52 8N is mechanically in great shape, motor must have been rebuilt in the past because it doesn’t burn a drop of oil. Hydraulic pump was rebuilt so it lifts my 620lb bush hog like nothin. It’s been converted to 12V and completely rewired. All the lights and gauges work.
When I get the new tractor I’ll probably have to sell it because I don’t have room in the barn for two tractors plus all the implements.
/ 8N Replacement #16
I sold my 51 after sorting out the B3350 but kept my truly exceptional 52, also with Sherman Combination transmission. The 52 has just over 1,100 original yours and is hardly broken it. I'll never sell it.
SDT
/ 8N Replacement #17
I was a Ford collector and user for many years and consider myself an early Ford expert. I no longer use the Fords as all of my real users are now orange.
I sold a very good 961 about 18 months ago and am planning to sell my very good 860 complete with heavy F & R weights and dual (yes, dual, which means two spools, two levers and 4 couplings) remotes soon. Sorry about the explanation of dual remotes but this is a pet peeve of mine. One lever and two couplings is a single remote, regardless of what one routinely sees in advertisements.
I will keep my exceptional 52 8N forever and my 64, 4 cylinder 4000 is to be my retirement project. The 4000 has a Select-O-Speed 10 speed power shifting transmission, F & R weights and dual remotes. It also has NOS Ford early power adjust rims (made of unobtanium) and power steering. The 172 CI gasoline engine has never been rebuilt and is tired but I have a very low hour industrial 192 CI engine for it. The 192 was originally a natural gas (high compression) engine but has been converted to gasoline. It should be good for 65+ PTO HP. I have a complete set of matching duals for it. It will not be a user but, rather, a toy.
SDT
/ 8N Replacement
Thx for all the replies
/ 8N Replacement #19
My 1951 8N with Sherman transmission, is now 67 years old, and still looks (engine rebuilt, and tractor repainted) and runs like a top!
I rarely use it, but will NEVER sell it!
/ 8N Replacement #20
Would you know the difference between a Sherman and Howard unit?
I see some older Fords with Sherman and others advertise Howard...
Set of 4 Unused ST205/75R15 Radial Trailer Tires (A66734)
Set of 4 Unused...
Apparently a YTM dealer went out of business.
Apparently a YTM...
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2019 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A69167)
2019 HINO 268 4X2...
2025 JMR 38in Hydraulic Rock Grapple Bucket Mini Skid Steer Attachment (A66734)
2025 JMR 38in...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
